Old 05-27-2013, 06:10 AM   #16036
Greg Bender
Oddometer: 1,162
Originally Posted by nickgindy View Post
My buddy just bought a 99 dirt model we are converting to be street legal. Anyone know if the tail lights are the same and I can just add the rear brake light switch and wire itnin?
I think so. The PO had an 1157 bulb in my tail light and it works great. The switch was one of those pathetic spring/mechanical devices that I've learned to loath. Instead, I fit a hydraulic switch like this one (10 x 1 threads):
http://www.mgcycle.com/product_info....oducts_id=1583
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 05-27-2013, 06:43 AM   #16037
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,774
Greg, you run Tusk T-10 bars on your bike? I've read reviews that these bend easily... any more info or alternative?
Learn to ride. Ride to learn.
a1fa is online now   Reply With Quote
Old 05-27-2013, 07:33 AM   #16038
Greg Bender
Oddometer: 1,162
I have not had any trouble with them bending "too" easily. I've crashed a bunch of times and so has my father in law. I think I'm on my second set. I'm pretty sure the first set got tweaked during a crash, but it wasn't like it was horrible or didn't get me home or forced me to cobble together some kind of contraption with tire irons and hose clamps or anything like that. In short, I'm quite pleased with them and I'd buy them again. They are cheap enough that I have a brand new "spare" hanging on the wall in my garage :>
Perhaps my expectations are too low?
Photos here:
http://thisoldtractor.com/gtbender/d...m-_cr_mid_bend
Regards,
Gregory Bender
Old 05-27-2013, 06:11 PM   #16039
FireDog45
Mid-life crisis sufferer
FireDog45's Avatar
Oddometer: 688
A big thank you to whoever suggested cracking the throttle a little to make hot starting easier!
I don't know who posted this advice but it worked perfectly for me today. I'd been having issues when starting my 99 DR when it was hot and thought I had corrected it when I readjusted the idle mixture setting (after talking to Jesse).
It made the little tractor fire right up every time!
FireDog45 is offline   Reply With Quote
Old 05-27-2013, 07:44 PM   #16040
redleger
Horrible Mechanic
redleger's Avatar
Oddometer: 570
I can tell you what bars not to use. fly racing. They bent the moment they hit the ground.
Sent from my KFJWI using Tapatalk HD
2006 Suzuki DRZ 250
redleger is offline   Reply With Quote
Old 05-27-2013, 11:04 PM   #16041
RuggedExposure
Now with more rugged
RuggedExposure's Avatar
Oddometer: 1,242
Messing around with the slow-speed setting on my camera...
Dr350 goodness (with s***-a$$ tires)
http://www.youtube.com/watch?v=ISEdF...ature=youtu.be
The fear and dread of you will fall on all the beasts of the earth
RE Fotowerks
Border Road 100 Border Road Rally Raid
'13 Husky Terra 650, '08 Kawasaki Meanstreak 1600, '95 DR350S
RuggedExposure is offline   Reply With Quote
Old 05-28-2013, 05:53 AM   #16042
Greg Bender
Oddometer: 1,162
Does this mean it is all running right again? I guess I missed whatever the fix happened to be. Can you point me to that post?
Regards,
Gregory Bender
Old 05-28-2013, 11:48 AM   #16043
RuggedExposure
Oddometer: 1,242
Regards,
Gregory Bender
Eh, its kinda running. I wouldn't trust it on a ride longer than I'm willing to walk. (about 15 miles). Its more of a ranch bike now, no way reliable enough to be a commuter.
When Bullitman281 was down here in March he fiddled around with the jetting and made it a little richer. It runs OK now, but doesn't like constant throttle at mid or high RPMS. I might go up a step in the jetting to see if that makes it any better.
Its a mystery as to why it ran fine for 4,000+ miles then one day didn't like the jetting.
RE Fotowerks
Old 05-28-2013, 01:00 PM   #16044
Nortonbrian
Oddometer: 32
Originally Posted by _CJ View Post
I do the same thing in stock-ish form now too, but the difference between this bike and my XS650 Scrambler at higher speeds is night and day. That bike is super stable, but with the DR I'm seriously concerned for my welfare.
Last year a couple of guys rode out here from CT, rode a bunch of trails, then rode home. All on fairly stock DR350's. I just can't imagine that kind of time slabbing it on the DR, but six plus hours on dirt roads and such is as good as it gets for me. So it's not position on the bike or anything, more or less just the instability of the bike at high speeds with cross winds, etc.
Will a windscreen straighten the bike up, and help it fly right? Do I need to adjust the bike for my, ummm, prosperous physique?
Remove the high front fender and install a low style. The high one acts like a rudder!
Nortonbrian is offline   Reply With Quote
Old 05-28-2013, 01:45 PM   #16045
thump!
thump!'s Avatar
Oddometer: 1,275
That's ok for pavement or dry dirt/sand but not really a good idea if you ride wet clay. There's a reason that fender is way up there. ;)
thump! is offline   Reply With Quote
Old 05-28-2013, 03:33 PM   #16046
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,774
Does anyone have keintech clutch arm for sale? Jesse is all out.
Old 05-28-2013, 04:06 PM   #16047
mustangwagz
mustangwagz's Avatar
Oddometer: 242
PM sent. Just took mine off
-WagZ-
'93 DR350S
My attempt to roundup Local Riders..
https://www.facebook.com/dualsportridingwesternpa
mustangwagz is offline   Reply With Quote
Old 05-28-2013, 04:08 PM   #16048
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,774
PM replied. Why did you take if off, if you don't mind me asking?
Old 05-28-2013, 06:24 PM   #16049
Zane Neher
Zane Neher's Avatar
Oddometer: 163
TM33 pumper?
I forgot my calipers at work so can't measure. Im getting some constant high idle issues (5-6k according to my acewell) after she gets hot which made me think of a vacuum leak. I did the spray trick and got nothing. Pulled the carb off to replace vacuum hoses and the 2 ports are T'd together and venting near the neck so I decided to toss the carb into a bath since I was getting some overflow if I left the petcock on.
The slide has a little wear but no groves, just missing paint.
Jets are 125 and 42.5
I did notice the enricher doesn't seat all of the way, but I figure high idle means too lean anyway.
Also, if I sometimes pull the enricher slightly, I can make it go down to normal idle. Too much and shoots back up. (Worked until Sunday, nothing helped after she warmed up.)
Zane Neher is offline   Reply With Quote
Old 05-28-2013, 08:08 PM   #16050
letank
Oddometer: 47
Originally Posted by motolab View Post
It's not the petcock's fault alone, but primarily the float valve's (after all the petcock is open when the engine is running, and something must stop the overflowing then, right?).
Regards,
Derek
Same here 91 model bought 3 years ago w 4700 miles, pulled the bike out of storage -no gas in tank or carb for a few months- pour gas.... prime and it does not stop dripping.... It used to do it for a few minutes... but not anymore. On on it does leak until the engine is running... so I rotate the carb, pull the bowl, and guess what the float valve inlet drops to the ground.... cooked o-ring.... get the box of o-ring and found a matching size 1/8. Installed no leaks, did 100 miles over the weekend. Will order a set of o-ring to replace the choke o-ring.
As the newer float unit, does anybody has any ideas of the changes to 13240-14D20 ?
letank is offline   Reply With Quote
Times are GMT -7.   It's 09:59 PM.
