Old 06-13-2013, 02:31 AM   #16261
mwilliamshs
Oddometer: 243
my guess...
Originally Posted by Anonawesome View Post
Ouch! Were those mounted with the TCI rack or just resting on the panel?
No side rack in his pictures.
mwilliamshs screwed with this post 06-13-2013 at 01:50 PM Reason: fat fingers & skinny buttons
mwilliamshs is offline   Reply With Quote
Old 06-13-2013, 11:59 AM   #16262
gladesteen
Padawan
Oddometer: 35
Spark plug preferences - NGK 5329 vs 5545
Is the higher priced (new design) NGK 5545 aka DPR9E1X
or is the 'standard' NGK 5329 aka DPR9EA9 just as good?
If the higher priced 5545 has benefits, i have no problem spending the extra $ on it.
Thank you!
Mark
gladesteen is offline   Reply With Quote
Old 06-13-2013, 03:27 PM   #16263
boboneleg
we can rebuild him.
boboneleg's Avatar
Oddometer: 886
Yesterday on a rather overgrown lane in Wiltshire......
Brrmmmmmmmmm Brmmmmmmmmmmmmm
boboneleg is offline   Reply With Quote
Old 06-13-2013, 04:14 PM   #16264
brianjonesphoto
Single Track Noob
brianjonesphoto's Avatar
Oddometer: 1,576
Thank you!
Mark
I believe that is an iridium plug. I don't understand the justification for 3x the price especially in a 20 year old engine it ain't going to make more power. It might help if you gave a rough time starting it but that's all. Run the recommended Ngk and replace often. This method has worked for decades.
Typos and nonsensical words courtesy of fat fingers on a make believe keyboard.
Brian
Mine: 07 DL650 ABS, 99 DR350SEx, 05 Montesa 4RT Her's: 02 KL250 Super Sherpa
www.PhotoSupportNW.com
brianjonesphoto is online now   Reply With Quote
Old 06-13-2013, 04:16 PM   #16265
Ghostyman
Ghostyman's Avatar
Oddometer: 255
Originally Posted by Greg Bender View Post
Don't forget the two bolts under the valve inspection covers.
Regards,
Gregory Bender
That was it. Thank you.
Ghostyman is offline   Reply With Quote
Old 06-13-2013, 05:39 PM   #16266
mustangwagz
mustangwagz's Avatar
Oddometer: 247
HID lights?
sup guys, hey i thought i recalled reading about someone doing a HID conversion here in this thread...or am i thinking wrong? can anyone point me in right direction? also read that the HID's our bikes use (H4) only come with 1 beam...as in low beam..thats it. any input on this boys?
-WagZ-
'93 DR350S
My attempt to roundup Local Riders..
https://www.facebook.com/dualsportridingwesternpa
mustangwagz is offline   Reply With Quote
Old 06-13-2013, 06:30 PM   #16267
redleger
Horrible Mechanic
redleger's Avatar
Oddometer: 588
I know this is wrong forum but the DRZ forum has kinda dried up. I recently switched from a CV carb to a TM28 pumper. I had to change out the intake inlet. It is tight in there and I thought that I had it tight but when I was out riding I noticed the idle moving up and down. I looked and saw what looked like a pressure blow from the vicinity of the inlet. Question is is there a special way to get in there with a certain tool? I just can't seem to get it with a normal screwdriver. I am afraid I will strip the rinky dink Phillips head screws. Some advice would be great from the geniuses here.
Sent from my KFJWI using Tapatalk HD
2000 KTM 200EXC
redleger is offline   Reply With Quote
Old 06-13-2013, 07:16 PM   #16268
SloMo228
World Class Cheapass
Oddometer: 1,854
Can't help you on the HIDs, but I don't see much reason why you couldn't do it. As for the stock bulb, mine definitely has a high beam ('96 SE).
--------------------------- Steve----------------------------------------
'96 DR350SE
SloMo228 is offline   Reply With Quote
Old 06-13-2013, 08:29 PM   #16269
jackanory
I am Jack's wasted life
jackanory's Avatar
Oddometer: 480
Nope, no side racks. lesson learned. these 4T exhausts get HOT! Never achieved those kind of temps on my 2T bikes.
jackanory is offline   Reply With Quote
Old 06-13-2013, 09:28 PM   #16270
skirecs
Oddometer: 39
hey folks, those of you that have removed the rear fender/plate mount, did you remove the undertail frame as well?
I was thinking about taking it off, and just putting a fender washer to hold the tail plastic up on to the upper rear frame
And where do you keep your reg/insurance, in the airbox, tool holder or tail bag? the tool holder looks like the cap might pop off easily...
skirecs is offline   Reply With Quote
Old 06-13-2013, 09:30 PM   #16271
skirecs
Oddometer: 39
Originally Posted by jackanory View Post
oops.
[IMG]http://jackanory.smugmug.com/Motorcycles/DR350/i-2rTkxjq/0/L/P1040426-L.jpg
[IMG]http://jackanory.smugmug.com/Motorcycles/DR350/i-nFSh6b7/0/L/P1040427-L.jpg
melted it right to my brand new wolfman panniers
[IMG]http://jackanory.smugmug.com/Motorcycles/DR350/i-QwPnxmn/0/L/P1040436-L.jpg
could have been worse. I imagine I was only a minute or two from melting a nice big hole in my brand new wolfman pannier
Did I mention they were brand new? Well, they're broken in now.
Going to slap some adhesive heat shield on that section of the pannier and the new side panels that should be on their way from Brazil.
Still managed to get out here...
[IMG]http://jackanory.smugmug.com/Motorcycles/DR350/i-Bffmk5Q/0/L/P1040408-L.jpg
... which definitely did not suck.
ouch, i recently had big saddlebags from my sv1000 on my dr, i moved them pretty much all the way forward so they were tucked under my knees, and it kept it off the exhaust enough not to melt anything, i was a little worried however
also had to hold them up out of the way to give it a kick!
Old 06-13-2013, 11:41 PM   #16272
Anonawesome
Scenic Rider
Anonawesome's Avatar
Oddometer: 1,360
I didn't remove mine personally but it was done by a PO. The sub frame hasn't been removed. It interferes a little when screwing on a plate but that's not very often and shouldn't be a problem unless you have very long bolts. I keep my reg/ins in the tool holder. It has never fallen off even though the rubber cap is cracked along the edge.
Anonawesome is online now   Reply With Quote
Old 06-13-2013, 11:47 PM   #16273
Anonawesome
Scenic Rider
Oddometer: 1,360
Thank you!
Mark
I don't believe it will have a noticeable effect (if any). The only spark plug related tip I've heard is removing the resistor in the spark plug cap and replacing it with a length of wire. I haven't bothered to replace mine since I haven't felt the need, but I would recommend just getting a new NGK cap and wire. I don't know about yours but mine is pretty dry from all the heat and barely flexes at all. It will be a repair I'll make sometime in the future.
Old 06-14-2013, 02:13 AM   #16274
Greg Bender
Oddometer: 1,235
I keep mine in my wallet. I don't like it there (along with the reg/insurance for all my other motos), but it stays with me and is dry. I don't mind the glove box on my cages, but I never felt comfortable stashing those documents anywhere on a motorcycle.
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 06-14-2013, 03:14 AM   #16275
thump!
thump!'s Avatar
Oddometer: 1,649
Regards,
Gregory Bender
I keep my documents in the tool box in a ziplock plastic bag. Haven't lost anything but it dies get wet in there. As far as theft goes, I don't worry about anyone stealing my DR350. It's homely by any standard and being a kicker only a tiny fraction of the world's population could possibility start it and ride it away. ;-)
thump! is offline   Reply With Quote
Times are GMT -7.   It's 07:42 AM.
