Old 06-29-2013, 07:45 PM   #16411
redleger
Horrible Mechanic
redleger's Avatar
Oddometer: 588
Originally Posted by jungleplant View Post
xr650r
my neighbor is the GM at the suzuki/kawi dealership. So those are my two choices. He is gonna square me away with a better deal than the guys at the honda shop can. so staying with my suzuki theme I got going, those 3 bikes are my choice for the moment.
2000 KTM 200EXC
redleger is offline   Reply With Quote
Old 06-29-2013, 07:46 PM   #16412
jungleplant
Motorcyle Stuff
jungleplant's Avatar
Oddometer: 1,858
DR650 then
www.manracks.com
jungleplant is offline   Reply With Quote
Old 06-29-2013, 07:47 PM   #16413
Ghostyman
Ghostyman's Avatar
Oddometer: 255
Originally Posted by groundrules View Post
1) Trying to remove the kickstart lever so I can pull the clutch cover (gotta get at that dang shift drum bolt). schematic indicates there's nothing holding the lever assembly on the splines once the outer screw is removed, but it only comes half way off before getting stuck. The first half of the movment is quite loose, then it sticks hard, like there's something solid in the way. I'm about to put a 3-jaw puller on this, but someone stop me if I'm about to break something.
I used a puller on mine as well. You won't break anything.
Ghostyman is offline   Reply With Quote
Old 06-29-2013, 07:49 PM   #16414
Ghostyman
Ghostyman's Avatar
Oddometer: 255
Originally Posted by 2sos View Post
For anyone who is interested. Here is a picture of the fairing from the guys over at globetrottin.org. I am extremely happy with this so far. I recently did a trip of about 200 miles of mixed terrain that included, fire roads, trails, and highways and never felt as if it was in the way. There was almost no wind on my body at $65 mph just on the top of my head. No buffeting and the lights are extremely bright. This and the seat concepts have made cruising on the road a lot more enjoyable.
I'm not affiliated with them at all, just thought I would let in on how it worked for anyone who was curious.
That looks really nice. Could you post pictures or describe how you mounted it? I'm going to put mine on this weekend.
Old 06-29-2013, 09:09 PM   #16415
teeveecasualty
Oddometer: 4
Am I missing something painfully obvious here?
New here and already really impressed with the quality of this thread. I have a 96 DR350SE and this week I replaced the clutch cable, or tried to. My local shop had the Parts Unlimited cable K28-2122, which has the funny little bent metal tube end that feeds the cable to the clutch arm atop the motor case. I'll gladly don the dunce cap if someone can help me to feel very stupid and let me in on the secret to making this cable work with the clutch cable bracket. For the life of me I can't figure out how these two fit together. The old cable simply had a threaded end and two lock nuts to hold the cable in the bracket. Can anyone help shed some light on this cable?
[IMG]Uploaded with ImageShack.com[/IMG]
teeveecasualty screwed with this post 06-29-2013 at 09:21 PM
teeveecasualty is offline   Reply With Quote
Old 06-29-2013, 10:04 PM   #16416
2old2Bbold
was 2bold2getold
Oddometer: 1,912
Looks like you have the wrong cable. You need one just like came off of yours. Don't think that ones going to work.
2old2Bbold is offline   Reply With Quote
Old 06-29-2013, 10:37 PM   #16417
jackanory
I am Jack's wasted life
jackanory's Avatar
Oddometer: 480
Hey gang, two questions, one quick and one that may require someone doing me a favor and taking some photos. both apply to a '91S, kicker, CV carb.
2) I'm trying to figure out what the correct throttle cable routing is. I'm getting throttle 'effects' at full lock, which makes me think a PO might have done something goofy. either it's the wrong cable or it's routed wrong. Anyone happen to have some photos of the relevant areas of the bike that might help? Clymers and the manual are not helpful in this regard.
Thank you!
I used a puller to remove the kickstart lever on mine the first time I pulled the clutch cover.
My throttle cable routes down the left side of the frame and under the gas tank tunnel. If you are really stuck I can remove the tank tomorrow and get you a pic.
jackanory is offline   Reply With Quote
Old 06-29-2013, 10:40 PM   #16418
jackanory
jackanory's Avatar
Oddometer: 480
here is how mine is mounted. Looks like the same cable you have.
Old 06-30-2013, 02:47 AM   #16419
mustangwagz
mustangwagz's Avatar
Oddometer: 247
still searching for a muffler boys...if anyones got one, lemme know please. It can be pretty much junk, just looking to score the end that slides on the header pipe.
-WagZ-
'93 DR350S
My attempt to roundup Local Riders..
https://www.facebook.com/dualsportridingwesternpa
mustangwagz is offline   Reply With Quote
Old 06-30-2013, 05:47 AM   #16420
Greg Bender
Oddometer: 1,235
Actually, the manuals should be pretty helpful in this regard.
For the dirt model, routing is covered in sections 7-9 to 7-12.
For the street model, routing is covered in sections 8-41 to 8-45.
Later yearly sections may also have updates as well.
http://thisoldtractor.com/gtbender/d...ervice_manuals
If you have specific questions after that, please let us know. I hope this helps!
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 06-30-2013, 06:29 AM   #16421
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,901
I got one. I probably won't use it. Freshly packed too.
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 06-30-2013, 06:42 AM   #16422
mustangwagz
Oddometer: 247
Originally Posted by a1fa View Post
i got one. I probably won't use it. Freshly packed too.
pm sent!
-WagZ-
'93 DR350S
Old 06-30-2013, 07:20 AM   #16423
mwilliamshs
Oddometer: 242
clutch cable
Push it through the bracket and slide the rubber cap back on. Then connect to clutch arm. Tension of cable keeps it seated in bracket. Good luck to ya! It really is pretty simple.
mwilliamshs is offline   Reply With Quote
Old 06-30-2013, 08:25 AM   #16424
2old2Bbold
was 2bold2getold
Oddometer: 1,912
Here's my "98SE. So there's two configurations.
Old 06-30-2013, 09:59 AM   #16425
smc5735
Oddometer: 50
Starting problems
Hello everyone,
My 97 dr350SE is having some starting issues...
heres the scoop..
Had an issue so I cleaned the carb, new oil, and cleaned the air filter.
Put everything back together which I have done multiple times.
Now it will not start and run. It starts only if I connect it to my car battery, pull the choke and adust the air screw to almost max. It idles for 1 minute then shuts off.
I checked the spark plug and it was pretty sooty which would indicate its rich.
Any ideas?
smc5735 is offline   Reply With Quote
Times are GMT -7.   It's 10:26 PM.
