Old 02-15-2011, 11:33 AM   #7201
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 16,773
interesting, I wonder if thats all that wears, or does the carb body wear too?
I cant ifnd a price on that throttle valve slide, I need to make some calls I guess.
Originally Posted by pablo83 View Post
Sudco sells a replacement TM33 slide if that interests you (PN 002-948)
http://www.sudco.com/CatalogJPG/103.jpg
Tilt your head, not the taco. - Pati Jinich
Charter member: T.O. club.
mouthfulloflake is offline   Reply With Quote
Old 02-15-2011, 11:34 AM   #7202
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
I'm not a Mikuni expert, but I know the Keihin's typically wear the slide long before the body wears.
Pablo83 is offline   Reply With Quote
Old 02-15-2011, 11:52 AM   #7203
PHILinFRANCE
PHILinFRANCE's Avatar
Oddometer: 1,131
Cheers Farmer Fred and Shearboy2004 for the feed back .....i'll run this set and see how it goes now that iv'e bought them !!!!!! So much choice
Phil
I,M HERE FOR A GOOD TIME NOT ALONG TIME
PHILinFRANCE is offline   Reply With Quote
Old 02-15-2011, 12:01 PM   #7204
shearboy2004
KIWIINUSA
shearboy2004's Avatar
Oddometer: 4,393
I wish this was the case with Mikuni carbs Paul but I have found by the time we realize we have a problem the body is worn and a new slide will only halve the problem , this is one reason I would never touch an E Bay pumper.
88 R100GS
75 Norton Commando Roadster
98 DR450
07 Sherco 510 called Holy Shit .450 Sherco called Bling .
13 Sherco 300i called The Bee's Knees .
shearboy2004 is offline   Reply With Quote
Old 02-15-2011, 12:10 PM   #7205
MiteyF
MiteyF's Avatar
Oddometer: 1,978
I'm running the stock 43 in the rear with my 15 up front for my street setup. I can cruise at 70 without REALLLY brappin' her out, but can still lift the front with a quick throttle hand in 1st.
I did just buy a 49 rear for my set of dirt wheels, we'll see how it does with my 13 front. Hoping I don't have to buy another chain!
MiteyF is offline   Reply With Quote
Old 02-15-2011, 12:11 PM   #7206
mouthfulloflake
Not afraid
Oddometer: 16,773
good to know, thank you.
Old 02-15-2011, 12:14 PM   #7207
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
+1 I have managed to get mine running ok with a worn body and a new slide but it will not idle quite right. Hey Shearboy, what were the idle characteristics that you were having with the carb I now have on my bike?Just curious if they are the same as what I am dealing with now...
jessepitt is offline   Reply With Quote
Old 02-15-2011, 12:29 PM   #7208
shearboy2004
KIWIINUSA
Oddometer: 4,393
Oh crap you asking an old man to remember something that happened more than a week ago
I am an anal prick when it comes to idle tuning I think and don't want any popping or climbing rpms at all. This comes into play when facing a rock wall and you have to have dead predictable throttle response in order to get up it .
I have had a bunch of DR's and have learnt over time that a new pumper is a beautiful thing so I tend to ditch the old ones quickly when they are playing up with worn slide symptoms.
That said i seem to remember that carb not idling evenly enough no matter how much i played with it , just worn but hopefully not as badly as your old one.
Let's hear what it's doing for you?
88 R100GS
98 DR450
Old 02-15-2011, 01:22 PM   #7209
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
Basiclly as you described. It doesn't idle down quickly, wont idle smooth, isn't reliable when you hit it, sometimes it responds instantly, sometimes it hesitates. I cant seem to get the air fuel screw set right but I think it is the worn body messing me up. It also does a delayed backfire when I shut it off, about a second after the engine stops. I have had it apart about ten times now to change jetting and re combine parts and it is rideable at this point but I think when I can afford it I will be buying a brand new carb. Thanks for sending me your old one tho, I wouldn't be riding at all without it.
Old 02-15-2011, 02:07 PM   #7210
shearboy2004
KIWIINUSA
Oddometer: 4,393
What you have there is a typical E Bay buy ! I'm glad it has you moving at least and I now know for sure you won't get one second hand.
Wish we could come up with a way to recon them but it would be extremely difficult to do .
I have what I assume is a very good CV carb here but I think that might be going backwards for you.
88 R100GS
98 DR450
Old 02-15-2011, 02:16 PM   #7211
shearboy2004
KIWIINUSA
Oddometer: 4,393
I asked this here once before but was totally ignored and i then felt very unloved but have regain some confidence so will ask again.
With all the big bores going on has anyone fitted a larger carb ?
Mine is now a 450 and I have a feeling going up 100cc could require a bigger carb to get full performance ?
Not really a huge issue as most of my riding is tight stuff but just wondering what to spend some more money on as I have far too much of it laying around cluttering the place up.
88 R100GS
98 DR450
Old 02-15-2011, 03:59 PM   #7212
slowsuki1
Oddometer: 118
i have fit a keihin fcr 37mm carb to my dr350 bigbore and love it, only problem is it is a bitch to start if it has not ran for a while. i can,t remember doner bike {ebay carb}, it was a bitch to jet as well, but great way to learn about the puticular carb, had to change every jet and adjust the amount of fuel the pump put out.
slowsuki1 is offline   Reply With Quote
Old 02-15-2011, 04:14 PM   #7213
DisTech
DisTech's Avatar
Oddometer: 616
My DR455 has a FCR-MX37 that I bought off ebay for less than $100. It's from a WR250F. Still piecing things together so it hasn't run yet.
Country Doc has a FCR-MX37 too and I was hoping he would get to his jetting before me.
Hey Slowsuki, do you know the jetting you ended up with? And did you have any top end work done?
DisTech - Suzuki (1993 DR350S & 1994 DR350, 1996 DR650/DR790), BMW (1999 R1100GS)
DisTech is offline   Reply With Quote
Old 02-15-2011, 05:03 PM   #7214
Country Doc
Wanderer
Oddometer: 2,707
My bike lives in California, so the work is being done by Trailtricks. It's a fly-and-ride bike for me, to get away from winter.
Spoke with Javier yesterday and he says the FCR is mounted up and they are experimenting with it this week to see if they can get it working. I'll update as soon as I know more.
My bike is a 441, big valves + ported head, cam, big header, jesse ceramic coated SS header and modded stock pipe.
If they can get it running well with the carb, next comes the WP/KTM front end...
dc
Country Doc is online now   Reply With Quote
Old 02-15-2011, 05:16 PM   #7215
mouthfulloflake
Not afraid
Oddometer: 16,773
How much piecing is required?
did it use the stock Rubber intake boots?
I would go this option if its cheaper, and doesnt wear out like the mikuni pumper.
Times are GMT -7.   It's 08:07 AM.
