02-22-2011, 10:28 AM
#7336 |
www.nouturns.tv
Oddometer: 68
i always thought of neah bay as northwest as you could get! But i guess its really point roberts!
02-22-2011, 01:11 PM
#7337 |
we can rebuild him.
Oddometer: 627
I have a persistant problem with my DR350SEX since it has been laid up for a while. It runs rough below 4000 revs but is absolutely fine from 4000 revs upwards.
So I took the carb from my SEW model (identical) and put it on the SEX and then it ran fine so I stripped the SEX carb and cleaned it thoroughly but the problem persists. I remember some years ago hearing about problems with these carbs concerning the 'throttle position sensor'. Has anyone had a similar problem, any advise? cheers, Bob.
'04 KTM 950 Adventure '00 Honda XR650L '98 Suzuki DR350SEW |
02-22-2011, 01:43 PM
#7338 | |
Oddometer: 135
Make sure all jets and holes in the carb are clear,the float height is set correct,check the diaphram for splits,you can also inspect the ht lead in case its breaking down at high rpm If the engine is running fine above 4k then thats the main jet thats ok,sorry i cant be of more help |
02-22-2011, 01:55 PM
#7339 |
Oddometer: 937
I finally found a DR350
My new DR350, great bike, I love it. Thanks Paul you made this an easy long distance transaction.
![]() Mark |
02-22-2011, 02:29 PM
#7340 |
Rocket Surgeon
Oddometer: 1,519
Very clean looking low mileage DR.
Congrats... the 350's are a great dual sport! |
02-22-2011, 02:31 PM
#7341 |
Oddometer: 1,012
Anybody else have problems with bark busters hitting their aftermarket tank?
02-22-2011, 02:57 PM
#7342 |
Oddometer: 135
Newbie Question, do I need both a decompression and throttle cable...?
I have a '96 DR350 street legal (is that the SE model?) and I'd like to get a spare throttle cable in case mine breaks while on the road.
Do I need both the throttle cable and the decompression cable or do I only need the throttle cable....? What are the part numbers I need for the required cables...? Thanks for helping this newb out!
02-22-2011, 03:17 PM
#7343 | |
Oddometer: 581
Hope this helps! Regards, Gregory Bender |
02-22-2011, 04:05 PM
#7344 | |
Mountain Fan
Oddometer: 392
Did you actually get around by horse??
02-22-2011, 05:21 PM
#7345 |
almost gnarly
Oddometer: 1,481
Sounds like a classic case of gummed up carb. I'd try cleaning it again. Seafoam works great. Make sure you get every tiny little nook and cranny thoroughly cleaned out. When I bought my bike it had been sitting for two years and wouldn't start. I took the carb off and cleaned it and it started right up, but ran a little rough. I took the carb off again and cleaned a little more thoroughly and it ran better, but not perfect. Took the carb off again and completely disassembled it, cleaned even more thoroughly - removed jets and soaked in Seafoam, removed and cleaned the needle valve, replaced o-rings, reassembled and checked float height. Ran perfect after that. I've put 5k+ miles on it since then with no problems.
'97 R1100GS, '99 DR350, '02 DR650, '03 DR650, '04 R1150RT A Few Days Solo to Copper Canyon A Maine Rider’s Arizona Day Trips A Few Days Solo in Baja |
#7346 |
Oddometer: 1,012
02-22-2011, 05:31 PM
#7347 | |
almost gnarly
Oddometer: 1,481
The throttle cable is a dual-cable setup. I'm not sure about a decomp cable for you bike - it wasn't shown in the parts fiche handlebar diagram that shows the clutch & throttle cables. I have a dirt model and I think the decomp may be different than the SE model.
02-22-2011, 05:43 PM
#7348 |
Oddometer: 107
02-22-2011, 05:50 PM
#7349 | |
Mountain Fan
Oddometer: 392
02-22-2011, 06:51 PM
#7350 |
Oddometer: 1,012
