Old 03-08-2011, 12:20 PM   #7576
straight cut
Oddometer: 136
My 350
std tank 86-111miles
cv carb dynoed all ok
65-70mpg
Rider 6ft 2" 189lbs
straight cut screwed with this post 03-10-2011 at 11:49 AM
straight cut is offline   Reply With Quote
Old 03-08-2011, 12:42 PM   #7577
Airvent
Airvent's Avatar
Oddometer: 347
Originally Posted by Speedo66 View Post
Disclaimer: I have nothing to do with this company except as a customer.
Heads up on some amazing sale prices for a few DR350 parts. They have clutch cables for $9 and bigger foot pegs for $15, small LED turn signals for $17/pair. Use this code "WS40" and knock 40% off those prices. Their shipping is a fixed rate of $6 per order.
All good deals I think.
See their site here: http://www.d2moto.com/c-480-dirt-bike-parts.aspx
Thanks buddy, Just ordered an O-Ring chain and a spare clutch cable for 38 bucks shipped. Cant beat it
Heres a few pictures from yesterdays ride. We had a lot of rain up in the northeast.
Airvent is offline   Reply With Quote
Old 03-08-2011, 01:49 PM   #7578
nvr2old
Oddometer: 15
Thanks for the heads up on this. Ordered pegs, clutch cable and 2 sets of grips for $26 shipped.
nvr2old is offline   Reply With Quote
Old 03-08-2011, 02:45 PM   #7579
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
If the clutch cable is a spare you can remove the fuel tank and route the spare along side the current cable from top to bottom.
Seal the ends with a couple large rubber vacuum cap nipples zip tied around the ends.
If your current clutch cable breaks you'll be back in business in 10-15 minutes with the new cable.
Bob Onit is offline   Reply With Quote
Old 03-08-2011, 03:43 PM   #7580
Airvent
Airvent's Avatar
Oddometer: 347
That's the plan for my cross country trip this summer Does anyone know if you can swap the push and pull cables for the throttle? No need to carry another if I already have a backup.
Old 03-08-2011, 04:34 PM   #7581
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
I'm almost positive that the throttle cables are not interchangeable but the good news is that it will likely work fine with the pull cable only.
The pumper kits that Jesse sells are supposed to use two cables but they only come with the pull cable.
No problems at all.
I ran an older pumper years ago on my brothers 350 which had a bad push cable, removed it and it worked great with the pull cable only.
Old 03-08-2011, 04:59 PM   #7582
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,863
Footpegs, spare clutch cable and a manual, all for $37.17 delivered. I didn't even need another clutch cable but for that discounted price will keep it for possible future use.
Thanks for the tip
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is online now   Reply With Quote
Old 03-08-2011, 05:30 PM   #7583
brianjonesphoto
Single Track Noob
brianjonesphoto's Avatar
Oddometer: 1,559
Originally Posted by BikePilot View Post
Brian, the 140 is probably a little fat and Jesse's needle is usually way fat (as is his jetting in general). Try moving the clip up one or two notches and maybe a 137 main.
My old DR had FMF Q exhaust, opened up airbox and high compression piston and seemed just right with a 40 pilot, 140 main and stock needle in the TM33SS. I never really paid attention to mpg, but I am pretty sure I was getting around 45mpg on full knobbies with a mixture of off road and freeway riding (I'd ride a ways on the freeway to the trails, ride moderately hard on the trails, then ride back on the freeway).
Your size is definitely going to hurt mpg (I'm 160lbs and 5'10"). Off road will usually give lower mpg, particularly high speeds - like freeway riding will give lower mpg and you'll get the best on street tires going fairly slowly in a paved surface - say 35-50mph back roads.
Also, go buy the 4.25 gal acerbis tank
Thanks pilot. I figured I would try raising the clip 1 notch at a time until I found a happy medium then try a 137.5 main. The Acerbis tank is on my list but will have to wait until after tax day.
Brian
Mine: 07 DL650 ABS, 99 DR350SEx, 05 Montesa 4RT Her's: 02 KL250 Super Sherpa
www.PhotoSupportNW.com
brianjonesphoto is offline   Reply With Quote
Old 03-08-2011, 06:28 PM   #7584
FlyingWman
FlyingWman's Avatar
Oddometer: 250
I see your running the T63 on the rear, you have the same on the front? I don't like how the front performs on the trail, it dives too easily. Looking for a replacement when the time comes.
___________________
2000 XR650R
1982 GS750TZ
FlyingWman is offline   Reply With Quote
Old 03-08-2011, 06:36 PM   #7585
jungleplant
Motorcyle Stuff
jungleplant's Avatar
Oddometer: 1,844
DR250/350 Rack Design
Well this is most likeley the final design of the rack , i sent greg one finished and powdercoated , Ill wait untill i hear from him, to see about the use of it thanks again to all who helped ,There will be two versions, tool pouch and pouchless, mike
jungleplant screwed with this post 03-10-2011 at 10:20 AM
jungleplant is offline   Reply With Quote
Old 03-08-2011, 08:41 PM   #7586
marksbonneville
marksbonneville's Avatar
Oddometer: 967
Thanks for the info, much appreciated. I also ordered spare cables and foot pegs.
marksbonneville is offline   Reply With Quote
Old 03-08-2011, 08:56 PM   #7587
MadChap
MadChap's Avatar
Oddometer: 441
Clark Tank for Sale
Selling my Clark tank in the Flea Market:
http://www.advrider.com/forums/showthread.php?t=666764
Get it while you can.
I went to Acerbis, that is the only reason I'm selling it.
MadChap is offline   Reply With Quote
Old 03-08-2011, 10:05 PM   #7588
Suzuki Phil
Oddometer: 634
I used a set of 96 Suzuki RMX forks for my conversion. Only needed to turn down the nut on top by .125, add stops to the RMX lower clamp and have a friend weld tabs on the upper clamp for the speedo/tach assembly. You have to use a RMX wheel also. Definitely worth the fabrication. The lower bearing on the stem is the same as the DR's. For the upper I found a bearing that required no machining to use the RMX steering stem.
SP
Originally Posted by frdbronco8 View Post
A buddy has a set of Yamaha WR426 forks he didn't use and it looks like the swap wouldn't be hard. He doesnt have the wheel for it though. It appears that the DR front wheel has a much smaller bearing and would not work. I would really like to keep the stock speedo for not only cost but I like the tach and the stock look. (and dont need any of the features of a vapor and would like to keep the stock mileage on the odo).
Anyone know if the Odometer drive on a WR wheel would fit the DR Speedometer cable? Looks like I could get a wheel on ebay for about $100 with everything on it. Would like to find something local on craigslist but pickins are slim for WR parts here.
Any other options/wheels to look for? YZ wheels are more available, could I use one of those with a WR odometer drive or is it completely different?
1916 Ford Model T
1996 DR350SE
Suzuki Phil is offline   Reply With Quote
Old 03-08-2011, 11:42 PM   #7589
scharfg
Oddometer: 204
Lube Man Chain Oiler for DR350SE...?
Anyone using this on their DR and if so any mounting tips/pics?
I have one on my DL650 and I like it so far.
scharfg is offline   Reply With Quote
Old 03-09-2011, 11:30 AM   #7590
Sloppy
Sloppy's Avatar
Oddometer: 210
Does anyone have a digital version of the shop manual? That, or know the valve clearances for a '92 S model off the top of their head?
Sloppy is offline   Reply With Quote
Times are GMT -7.   It's 08:18 PM.
