Old 03-16-2011, 10:42 AM   #7681
Greg Bender
Oddometer: 1,202
Originally Posted by Greg Bender View Post
Sure, no problem. I've even got a new set of identical bend that I'll take some photos of, too. Once again, I'll wait for it to get light out here in the desert a bit later this morning :>
Regards,
Gregory Bender
Here you go, a few photos of the handlebars. Hope it helps!
http://thisoldtractor.com/gtbender/d...m-_cr_mid_bend
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 03-16-2011, 11:08 AM   #7682
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 2,066
Hi Pablo,
I am far from an expert on suspension set up. But, I tried to find any data in the workshop manual that would answer the supposed to question. I couldn't find any.
I'm sure the suspension experts will chime in, but I couldn't find a Suzuki recommendation. Sorry.
Regards,
Gregory Bender
For my MTB, 20-25% of travel is the recommended sag (with rider aboard - won't sag at all w/o). Surfing found this for MX: "5-10% for bike weight and then 25% for bike and rider weight"
Two roads diverged in a wood, and / I took the one less traveled by, and / now where the hell am I?
This isn't a "you're doing it wrong" topic. (Originally Posted by Human Ills, 7/1/14)
Wadester is offline   Reply With Quote
Old 03-16-2011, 11:10 AM   #7683
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,814
Thanks, is that DR specific, or is that generic for all dirt bikes?
Pablo83 is offline   Reply With Quote
Old 03-16-2011, 12:35 PM   #7684
BikePilot
BikePilot's Avatar
Oddometer: 11,251
That's pretty generic for all bikes, though imho it should be closer to 10% than 5% for bike's own weight imho (this means a stiffer spring for a given rider weight and sag). This works out to about 1" under the bike's own weight and 4" with rider on most 12" travel dirt bikes.
Sag isn't something that you ordinarily alter to suit varying terrain, at least not much. Also note that it isn't a significantly means of altering suspension behavior - its more about messing with chassis geometry (though your suspension will suck if your sag is way off). If you want a bit quicker steering try running 2-5mm less sag, for a bit more stability run 2-5mm more sag. I wouldn't change more than 5mm at a time as that much will make quite a difference. Modern bikes with less flex will make changes in sag even more obvious. The DR is so imprecise its not quite as obvious, but still makes a big difference
Note that more sag will generally make the bike less plush because it sags into the more progressive part of the linkage where it gets stiffer. Also you've got less travel available to soak up hits. Pre-load doesn't alter spring stiffness, it only changes ride height. All this to say running a bunch of sag won't make it more plush.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 03-16-2011, 01:59 PM   #7685
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 2,066
This is generic - and you have to know your full travel to use it. Manual says:
DR350SER ('94):
Front suspension stroke. . . ...............280mm(11.0In)
Rear wheel travel . . . . . .255 mm (10.0 in)
DR350SN ('92)
Rear wheel travel . . . . . .280mm(11.0In)
Basically 1 1/8" w/o you, 2 3/4" with.
The manual tells you to measure the spring length to establish proper preload:
SETTING TABLE
Spring length
STD : 269.2 mm (10.6 in)
Softer: 274.2 mm (10.8 in)
Stiffer: 261.2 mm (10.3 in)
Old 03-16-2011, 04:00 PM   #7686
brianjonesphoto
Single Track Noob
brianjonesphoto's Avatar
Oddometer: 1,563
What's rear sag supposed to be for a 98 kicker?
I'm no expert either, but I've always heard the general rule for a dirt bike is 20-30% of total travel.
Brian
Mine: 07 DL650 ABS, 99 DR350SEx, 05 Montesa 4RT Her's: 02 KL250 Super Sherpa
www.PhotoSupportNW.com
brianjonesphoto is offline   Reply With Quote
Old 03-17-2011, 01:46 PM   #7687
PK
Oddometer: 491
I just received my new foam and cover from Seat Concepts. Thought I'd post some pics of the new foam vs. the old. I won't get it installed for a week or two but so far it looks really good, and the foam is noticably firmer. Good stuff!
Side by side shows how much more there will be to sit on as well as the nice taper inwards at the front of the seat.
Approximate height difference shows much less of a slope towards the front.
PK is offline   Reply With Quote
Old 03-17-2011, 03:50 PM   #7688
Gage
Gage's Avatar
Oddometer: 169
So on the way home today... i lost a screw... an important screw... and it left me stranded! Wooo And it just stopped the bike from running and pissed gas all over the floor. Then if you try to start it again it just keeps peeing gas all over!! woo
I believe it is the fuel screw/air mixture screw or somethin... correct me if i am wrong.
heres a pic.. its toward the bottom of the carb. on a 1995 dr 350se stock carb.
Gage is offline   Reply With Quote
Old 03-17-2011, 03:53 PM   #7689
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,590
Should you put thread-locking compound on the screws that hold the clutch basket together?
Well, I ain't always right but I've never been wrong.
It seldom turns out the way it does in the song.
Old 03-17-2011, 03:58 PM   #7690
juda5
juda5's Avatar
Oddometer: 124
The picture is kind of small, but it sure looks like you are missing your float bowl drain screw! That would definitely cause all the symptoms you described.
juda5 is offline   Reply With Quote
Old 03-17-2011, 04:19 PM   #7691
Sloppy
Sloppy's Avatar
Oddometer: 210
Noob question: The bike must be at TDC to adjust the valves, correct? And I can find TDC by pulling in the comp lever, slowly kicking down til the lever pops, and letting go?
Sloppy is offline   Reply With Quote
Old 03-17-2011, 04:25 PM   #7692
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,590
I would watch the intake valves. TDC is just after you see them close.
Old 03-17-2011, 04:54 PM   #7693
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,639
What he said.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 03-17-2011, 05:45 PM   #7694
Gage
Gage's Avatar
Oddometer: 169
Yup ive come to the conclusion that the float bowl drain screw is what i am missing. Thanks!
Do you have any recommendations for cleaning the carb?
Old 03-17-2011, 06:24 PM   #7695
brianjonesphoto
Single Track Noob
Oddometer: 1,563
You too. I lost a front brake caliper bolt today! Luckily I was only 3/4 of a mile from home, but it was at the end of a 75 mile ride. Not to self check bolt torques more often. I also added some thread locker to the new bolts just to be sure.
Having your lever bottom out without slowing down is an unnerving feeling.
Brian
Times are GMT -7.   It's 11:06 AM.
