Old 11-17-2011, 10:13 AM   #10216
MrPulldown
MrPulldown's Avatar
Oddometer: 3,165
Non-O ring chain.
I rencently installed a new X-ring chain with master link. My old chain was a whole link streached out and floppy as hell. I assumes all the O rings had worn out and disentegrated over time. Took her for a test drive and noticed how much power a stiff new chain ate up. Now after about 500 miles on it it seems like things are back to normal, or at least I am use to the lack of power.
My DR brother is planning on getting a non-O-ring chain next. In fact he says he is planning on getting 2. The price of 2 chains will be about the same as one O-ring chain. Then is plans to swap them out often, having one sit in a bath of kerosen (or similar).
Sounds like a bit more maintance, but not a bad idea. He thinks he will get alot less power rob out of the deal. Sounds like a decent idea. What do you guys think?
MrPulldown is offline   Reply With Quote
Old 11-17-2011, 11:01 AM   #10217
Rode2Nowhere
Rode2Nowhere's Avatar
Oddometer: 2,208
Linky
Not a DR, but still real-world research on an O-ring chain vs. Non O-ring chain. Very scientific.
Be sure to click the "Sprocket and Chain Wear" link when you get to the bottom. Thats where he compares the two.
Originally Posted by MrPulldown View Post
Non-O ring chain.
- Jonathan
'88/'96/'08/'09 KLR650 Amalgamation
IBA #45896
Adirondack Tags
Rode2Nowhere is offline   Reply With Quote
Old 11-17-2011, 11:02 AM   #10218
Greg Bender
Oddometer: 1,173
Non-O ring chain.
I've also noticed that the friction of the o-rings does make the chain "stiff". I suppose enough use will loosen things up somewhat, but I doubt it would ever because a loose as a non-oring chain (o-rings must be squeezed at least a little bit in order to be useful as a seal).
As far as I know, no o-ring chain seals the rollers themselves...only the "links". It also isn't like o-ring chains are maintenance free. I doubt I would go to the trouble of keeping a chain soaking in kerosene. I'd be much more likely to use one up and replace it with a new one when the time came.
An actual dyno test both ways would be quite useful :>
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 11-17-2011, 11:06 AM   #10219
BikePilot
BikePilot's Avatar
Oddometer: 11,251
There is a slight difference and this is why folks racing 125s never use sealed chains (well this + the weight diff). Imo the extra work and limited life of non-o ring chains make them a silly idea for anything but a dedicated race bike with limited power. When I was racing a 125 in the woods I still used an o-ring chain as the difference was slight in terms of drag and huge in terms of upkeep. When I raced a 125 in outdoor MX I used a non-o ring chain because there power mattered more and maintenance was less of an issue (15 min motos don't wear a bike out that quickly). A good X-ring chain has rather little drag, especially once warm. Try spinning your rear wheel right after a ride, it moves quite nicely. They'll be a little stiff when cold and just starting out, but loosen right up as the seals and grease gets warm.
I have noted a difference in stiffness between O-ring and X-ring chains with X-ring chains moving more easily.
I find it rather odd to put a high maintenance race chain on the heavy, slow, old, otherwise low-maintenance DR.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 11-17-2011, 11:10 AM   #10220
Rode2Nowhere
Oddometer: 2,208
MHO as well.
- Jonathan
IBA #45896
Adirondack Tags
Old 11-17-2011, 11:23 AM   #10221
Greg Bender
Oddometer: 1,173
Originally Posted by Rode2Nowhere View Post
MHO as well.
Agreed.
Old 11-17-2011, 11:35 AM   #10222
Falcon86
I just work here.
Falcon86's Avatar
Oddometer: 1,679
'99 dr350
Hey guys, I came across a pretty decent deal on a '99 DR350.
It's in great cosmetic shape, I'd just need to replace the rear sprocket and the clutch. Sprocket doesn't worry me, but can anyone chime in with info on replacing the clutch? Is it a complete PITA?
Falcon86 is online now   Reply With Quote
Old 11-17-2011, 11:48 AM   #10223
MrPulldown
MrPulldown's Avatar
Oddometer: 3,165
...on the heavy, slow, old, otherwise low-maintenance DR.
Oh you didn't jsut say that about our beloved iron steed
Old 11-17-2011, 12:04 PM   #10224
brianjonesphoto
Single Track Noob
brianjonesphoto's Avatar
Oddometer: 1,559
Both are pretty easy if you have turned wrenches before. You might get lucky and only need new clutch springs. My 99 had a slipping clutch when I got it and all the plates were in spec but the springs at set and weren't quite strong enough anymore. Just get a clutch cover gasket before you even start.
Brian
Mine: 07 DL650 ABS, 99 DR350SEx, 05 Montesa 4RT Her's: 02 KL250 Super Sherpa
www.PhotoSupportNW.com
brianjonesphoto is offline   Reply With Quote
Old 11-17-2011, 03:03 PM   #10225
mas335
xendurist
Oddometer: 1,971
+1 on the O ring chains vs non O rings.
I finally got my new to me 95 DR350se running correctly, the Carb was dirty and running very rich and it was a float issue, seems the poor language translation in the shop manual was throwing me off and the previous person at the dealership who supposedly serviced this carb didn't have a clue.
One thing I can't find in the 200+ page shop manual is the correct way to check the engine oil level, do you test it with the dip stick sitting "on" the filler port or screwed all the way into the filler cap?
I'm far more familiar with Hondas and you check them with the dip stick sitting on the filler port, not screwed all the way in.
While I am at it I need a Original Right Side Mirror, the one that is on the bike has been changed and just looks odd with the left side being original.
Transalps
mas335 is offline   Reply With Quote
Old 11-17-2011, 03:10 PM   #10226
kobukan
almost gnarly
kobukan's Avatar
Oddometer: 1,712
Originally Posted by mas335 View Post
. . . One thing I can't find in the 200+ page shop manual is the correct way to check the engine oil level, do you test it with the dip stick sitting "on" the filler port or screwed all the way into the filler cap?
Run bike until engine is warmed up. Shut the bike off, wait a minute, insert dip stick - do not screw dip stick in to check oil level.
'04 R1150GS, '97 R1100GS, '99 DR350, '02 DR650, '03 DR650
A Few Days Solo to Copper Canyon
A Maine Rider’s Arizona Day Trips
A Few Days Solo in Baja
kobukan is offline   Reply With Quote
Old 11-17-2011, 03:16 PM   #10227
mas335
xendurist
Oddometer: 1,971
Thanks, the manual was clear on everything except the dip stick position.
I am also looking for a good Mud Guard that attaches to the back side of the air box.
Transalps
Old 11-17-2011, 04:08 PM   #10228
Garthe
ROCKS ARE YOUR FRIENDS...
Garthe's Avatar
Oddometer: 4,364
BP, I see you post up on a wide varity of topics here on ADV. You sure seem to know something about everything. I always read what you have to say, even if the topic doesn't intrest me.
Thanks for taking the time to share your experences...
OK, I'm done kissing your ass....
2007 XR650R
2001 Montessa 315R
Garthe is offline   Reply With Quote
Old 11-17-2011, 04:44 PM   #10229
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,353
Non-O ring chain.
Go to dirt tricks website and read their awsome article on chain wear and o ring vs. non.
Basicly, there is no power loss on an o ring chain and a non o ring chain won't save you any money unless you only ride on the street in clean conditions,and they explain exactly why.
2008 KLR 705-2004 ST1300-2001 FZ1
2001 GAS GAS 321
IBA # 23,716
http://gasguysadventures.blogspot.com/
GAS GUY is offline   Reply With Quote
Old 11-17-2011, 07:26 PM   #10230
Mission1
Twisted and confused
Oddometer: 89
DR 350 thread
Hey Garth what are you doing here? Do you even own a dr these days. . ?
Do it right or go home!
Mission1 is offline   Reply With Quote
Times are GMT -7.   It's 11:09 AM.
