Old 06-09-2012, 02:39 PM   #12151
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
How do you adjust the cam chain tensioner?
I can't find any reference to it in the Clymer.
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy
"Never bring a Nerf gun to a shovel fight." - My Brother
EvilGenius is offline   Reply With Quote
Old 06-09-2012, 03:47 PM   #12152
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,481
Who makes that tank and rear rack?
Originally Posted by Tachedoutoffroad View Post
Got tired o wrecking my SM on the powerlines.
Got this little trail whore this morning. Riding tomorrow!
1995
6500 miles
4.2 gallon tank
You looked down here...didn't you.
MeterPig is offline   Reply With Quote
Old 06-09-2012, 04:05 PM   #12153
jplum1556
Oddometer: 102
It's an automatic cam chain tensioner.
jplum1556 is offline   Reply With Quote
Old 06-09-2012, 07:13 PM   #12154
Tachedoutoffroad
Mr. Parrish
Tachedoutoffroad's Avatar
Oddometer: 649
Believe it's an IMS.
Rack is homemade.
Riding tomorrow! See how she does.
'00 KTM 400EXC --plated!
'89 Honda Transalp
Sikorsky UH-60L
Support your local know-it-all gear guy and give your money to Brian at https://www.atomic-moto.com/
Tachedoutoffroad is offline   Reply With Quote
Old 06-11-2012, 08:43 AM   #12155
WeeMcD
V-Strom explorer
WeeMcD's Avatar
Oddometer: 464
Originally Posted by MrPulldown View Post
The thing about the one-way fuel tank vent is that it also prevents gas from spilling out when you drop it.
For some reason I never had a problem with the stock tank. But then I got the acerbis tank with the dirt bike style vent tube. I crash the bike pretty good on a hill climb and could not pick up the bike immediatly. I think I watch about 1/2 a gallon of gas pour out the vent line before I was with it enough to get the bike upright. Still have not really figured otu a solution to this, other than don't crash.
My Clarke gas cap leaked badly when the bike was taking a dirt nap. I bought a one-way vent and it still leaked around the threads of the gas cap. A quick trip to the hardware store for a rubber seal fixed the problem. After testing the seal for a few trips, I glued the seal to the cap. Voila! A free breathing tank that doesn't pee the bed when sleeping.
Blog of my adventures: www.BestScenicRoutes.com
"When all else fails get a bigger hammer."
WeeMcD is offline   Reply With Quote
Old 06-11-2012, 09:01 AM   #12156
rubberband
Will ride for tacos
rubberband's Avatar
Oddometer: 419
You can adjust it manually. one click.....
http://www.kawiforums.com/how-tos-fa...cct-636-a.html theory is the same....someone once posted a video from youtube....but I can't find it.
2011 UPAT
rubberband is offline   Reply With Quote
Old 06-11-2012, 03:26 PM   #12157
mustangwagz
mustangwagz's Avatar
Oddometer: 247
Get out...that really work on our bikes? you'd figure that if it was to tight to go to the next click by itself, that it'd be to tight to do it that way. Has anyone on here done it?
-WagZ-
'93 DR350S
My attempt to roundup Local Riders..
https://www.facebook.com/dualsportridingwesternpa
mustangwagz is offline   Reply With Quote
Old 06-11-2012, 03:42 PM   #12158
MrPulldown
MrPulldown's Avatar
Oddometer: 3,341
Back from my weekend in the desert. Wheww did a lot of riding, about 100 miles a day. Suspension works good for the bumps and is quite a bit stiffer (98RM250). Hitting small bumps is very plush, as are rollers and whoops. Though I did not have it set up properly for the whoops so that I could hit the series of whoops and have the forks eat them up. They got "stacked up" on. Rebound too slow and compression not quite enough.
Did notice that the longer forks messed with the geometery a bit. The front wheel is lighter and the front end tends to wash out when pushed. Esspically in sand. When cornerering if you moved your body forward it would help. We had two DRs to compare, with the other SE having not only stock suspension but sagged front forks, the front was a lot more grippy. Might preload the rear a little more.
NEver bottomed the fork out, but you can feel the valving. If I hit something hard, like the edge of dry creek cossing, it was not the typical supple hit like when using the first half of the travle. It had a diffenet harshness to it, but it was not bottomed outed. There was quite a diference at higher speeds being confident to hit obsticals without slowing and staying in control. The stock DR forks could not compare in this aspect.
The rear shock I never even noticed. It was able to jsut follow along (Dirt shock, new oil). The old 94+SE shock would bottom out and be noticeable.
Here is a little video of riding on the Playa.
http://www.youtube.com/watch?v=wEB8uYN2Ejc
MrPulldown is offline   Reply With Quote
Old 06-11-2012, 08:37 PM   #12159
shearboy2004
KIWIINUSA
shearboy2004's Avatar
Oddometer: 4,423
I measured the difference between the stock DR forks and my RM replacements and dropped the triples down the RM forks to the original height , problems all went away .
I also fitted a WER steering damper and while not the glory name of Scotts or Ohlins it does a fantastic job on my DR and is the simplest thing to work on , about all they ever need is a couple of O rings and a fluid change .
88 R100GS
75 Norton Commando Roadster
98 DR450
07 Sherco 510 called Holy Shit .450 Sherco called Bling .
13 Sherco 300i called The Bee's Knees .
shearboy2004 screwed with this post 06-11-2012 at 08:51 PM
shearboy2004 is offline   Reply With Quote
Old 06-12-2012, 07:27 AM   #12160
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,886
I've had a bike where the tensioner would not auto adjust when it was getting near the end of its travel. The resulting camchain "thrashing" noise just told you it was time for a new chain. I would not do what was suggested in that video as I'm pretty sure it would result in an over-tight chain, leading to premature wear of several components (even though it would probably be quieter for a while)
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is online now   Reply With Quote
Old 06-12-2012, 08:10 AM   #12161
Greg Bender
Oddometer: 1,201
Agreed. The Suzuki workshop manual provides details on how to check the cam chain for wear as well as how to install the automatic cam chain tensioner. Turning an automatic cam chain tensioner into a semi-manual cam chain tensioner seems to be a very bad idea and one that would lead to more wear on the chain, gears, bearings, and chain guides.
It would have been nice if Suzuki were to have provided a procedure (and minimum value) for evaluating that cam chain life by checking the available remaining length of the tensioner (essentially, remove the tensioner bolts and allow the tensioner to fully extend, then push it back in and measure the resulting clearance between the tensioner body and the cylinder). Alas, they did not. I know when I fit a new chain and gears (reusing the original guides that showed next to no wear), that I still didn't have a whole lot of clearance (though the length of that push rod makes one think there should be inches of room! :> ).
I have a friend with a DRZ400 who read the internet woes regarding the automatic cam chain tensioner. He fit a manual cam chain tensioner to ward off such "wide-spread" disasters. He didn't quite keep up with the manual chain tensioner adjustments during a long trip, skipped a cog or two, and munched his engine.
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 06-12-2012, 09:45 AM   #12162
MrPulldown
MrPulldown's Avatar
Oddometer: 3,341
THere were many times that a steering dampener would have come in handy. Hitting sandy gravel sections at 60 mph and getting "speed wobbles".
When I measured out my RM forks, they were 1.5 inches longer than the stock DR's. I dropped them a little more than half inch in the triples. I would have liked to drop them 1.5 inches but there is that tapered section which would not grab in the triple clamp due to the reduced diameter. I suppose I can drop them a little more and jsut have a smaller diameter section in the clamp area that is not grabed. Make sense?? Is this what you did?
Old 06-12-2012, 10:24 AM   #12163
Rode2Nowhere
Rode2Nowhere's Avatar
Oddometer: 2,213
Got thorough the Roaming Rally on the mightly little DR.
4 days, 1068 miles, and 80 of my closest internet biker buddies . And I beat the freaking crap out of this thing for the 2 middle days.
Couldn't get any more than 70 out of it in the gravel! (bone stock)
not my pic, but stole it 'cause it's awesome.
... and my homemade Giant-Loop-Coyote-ish-type-bag made it through flawlessly!
- Jonathan
'88/'96/'08/'09 KLR650 Amalgamation
IBA #45896
Adirondack Tags
Rode2Nowhere is offline   Reply With Quote
Old 06-12-2012, 10:50 AM   #12164
Rode2Nowhere
Oddometer: 2,213
Big bore kit
For any big-bore kit users, is there any vibration reduction at high RPM? Didn't know if the piston was lighter than stock or not. On the long slab home from the trip, my feet were numb from hours of sitting on the vibrating pegs. Its amazing what a difference between 55 and 60mph can make. No vibration at all at 55.
- Jonathan
IBA #45896
Adirondack Tags
Old 06-12-2012, 12:06 PM   #12165
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,700
Rode2Nowhere
Oddometer: 1,900
Nice pics looks like a blast! I want one of your loop bags for my 350. Got a link to the ride report?
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is offline   Reply With Quote
Times are GMT -7.   It's 08:16 PM.
