Old 07-01-2012, 09:36 PM   #12361
2old2Bbold
was 2bold2getold
Oddometer: 1,689
Originally Posted by Airvent View Post
Battery terminals are good, plug cap was swapped with the coil, known working. Went through the carb thoroughly, spotless. Slide has good dampening, so the diaphragm is good as well. Checked my valves this morning and they were within spec. I'm clueless right now
Symptoms:
It seems to almost backfire through the intake slightly. My Dad tells me this is a timing issue and is pushing for me to open up the magneto cover.
Again, it feels like there is a great amount of resistance on the engine when I try to rev it. Will not rev high. Will not idle without throttle.
Still no tach too.
Oops. You didn't say it wouldn't idle. Or I missed it. Popping back through the intake can be a lean condition. Check the idle/piolet/slow jet. It's really small and hard to clean. Run a small wire or something through it. The tach could be another problem.
2old2Bbold is offline   Reply With Quote
Old 07-01-2012, 10:33 PM   #12362
MadChap
MadChap's Avatar
Oddometer: 441
Personally, I wouldn't buy the street model DR without the electric start.
MadChap is offline   Reply With Quote
Old 07-02-2012, 07:24 AM   #12363
Greg Bender
Oddometer: 1,168
Originally Posted by EvilGenius View Post
Anyone know what the stock mirror thread measurements are or what swaps into the stock mounts?
10mm x 1.25mm
If you are going off pavement, then I would highly recommend a mirror that is not hard/solid mounted.
The Ken Sean Dual Sport Mirror is one good choice. It is fiddly to set up properly, but works pretty well.
I just swapped out my Ken Sean mirror for a ram mount mirror from my friend Mike Sonzini. Total cost is about $50 for a mirror, so it isn't nearly as inexpensive. However, it is very easily adjustable without tools, holds it's position very well, and moves out of the way easily when bumped. So far, it is a better mirror and I like it.
FYI, my DR350 (dirt) model did not come with a threaded mount on the clutch perch for a mirror. But the threaded clamp piece from a street model fits perfectly and is cheaply available from Suzuki. I carry the original non-threaded clamp in case I destroy the other one in a wreck.
I do not fit any mirror on the right front brake perch. I do not wish to risk damaging or destroying the master cylinder. One mirror is enough.
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 07-02-2012, 08:31 AM   #12364
tntmo
Oddometer: 491
I guess it depends on your priorities. The E-start model is quite a bit heavier, so if you're trying to go light weight the older kick start model has a slight advantage.
Buncha dirt bikes with license plates.
tntmo is offline   Reply With Quote
Old 07-02-2012, 08:53 AM   #12365
Greg Bender
Oddometer: 1,168
Agreed. I just fit a CV carb to my DR350 (dirt) to increase my riding range via improved fuel economy. Kick starting it is not a problem at all (though a bit different than my pumper carb). Personally, I very much like not having a battery, starter, etc.
Regards,
Gregory Bender
Old 07-02-2012, 09:16 AM   #12366
muskieken
Oddometer: 176
Hi everyone
i'm new to the dr 350 .. i got a 95 it's a se 1995. so i'm looking for someone close to the buffalo NY area .
my bike just sounds different. I would like to know it's just the way it sounds . i have a honda cfr230l that i got new.
i'm new to dirt bikes.
so anyway i'm looking for someone to tell me it's just the way they sound or that doesn't sound right. I do not want to go to a dealer, just don't trust them. was burned real bad when i got my first MC in 1990. but thats another story.
so if anyone that's close to buffalo that would be great.
crf230l
st1300
muskieken is offline   Reply With Quote
Old 07-02-2012, 11:57 AM   #12367
Hudson7
Oddometer: 31
Unaware as to whether or not the e-start also has the option for a kickstart too, but it is nice not having to worry about being stranded due to a dead battery like I've had to deal with before. Simplicity can be a luxury...
Hudson7 is offline   Reply With Quote
Old 07-02-2012, 01:01 PM   #12368
GaThumper
Road Less Traveled
GaThumper's Avatar
Location: Thumpin' in North GA - headin' for the Smokys
Oddometer: 514
You can add the kick start assy from a kicker, just have to get the parts, the case is ready. I picked up the gear from Ebay a couple or years ago, but have never got around to installing it. Mine has never left me stranded from a dead battery (or anything else) but I guess you could just push start it if needed. Maybe I'll get around to installing the kicker when I tear it down for the 441 kit one day!
http://www.ronayers.com/Fiche/TypeID...p/KICK_STARTER
Two of them on Ebay right now... just search DR350 Kick starter.
I just checked the shaft and it's the same part number on all DR350 kickers from 1990-1999 and DR250s from 1990-1995.
and, it looks like the shaft itself might be discontinued. shows discontinued on all the 350s and available on all the 250s.
Dirtly: 2009 Suzuki DR650SE Road Sofa: 2001 Yamaha (ad)Venture 1300
Dirtlier: 1999 Suzuki DR350SE Old Sport: 1979 Suzuki GS1000E
1996 Suzuki Intruder 1400 (for sale) 1987 Yamaha TT600 (for sale)
GaThumper screwed with this post 07-02-2012 at 01:22 PM
GaThumper is offline   Reply With Quote
Old 07-02-2012, 01:06 PM   #12369
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,709
My 97 Estart has a kicker added and it works. Privious owner installed it and one of the reason I bought it was both options.
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is offline   Reply With Quote
Old 07-02-2012, 01:16 PM   #12370
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,148
Originally Posted by plugeye View Post
no, find something close.
ballpoint pen
other small parts
I scavenged one off of my KTM too. The spring looks similar.
You looked down here...didn't you.
MeterPig is offline   Reply With Quote
Old 07-02-2012, 02:14 PM   #12371
StevieDR350
Tortoise rider
StevieDR350's Avatar
Oddometer: 6
Added a low cost tool tube to the bash plate, works like a charm and keeps the weight low.
New Acerbis 16L tank that only holds 14.6L
No nonsense bar raisers
Solid lever and bar protector - 1 piece, mounted with DR650 bar clamps and bolted into drilled and tapped bar weight
Hardcore reading:
http://www.wilddog.za.net/forum/index.php?topic=78977.0 - Hardcore Volcano Run
http://www.wilddog.za.net/forum/index.php?topic=98416.0 - Kruger Park Fence Ride
StevieDR350 is offline   Reply With Quote
Old 07-02-2012, 02:17 PM   #12372
StevieDR350
Tortoise rider
Oddometer: 6
LOADED FOR THE LONG HAUL - SUNNY SOUTH AFRICA
Hardcore reading:
Old 07-02-2012, 04:40 PM   #12373
lucu
Oddometer: 56
Couple of quick questions.
Will a DR350s frame "fit" a 97 DR350SE ?
Where can i get the original stickers for the side panels ? I mean, can i get them somewhere elser other than a suzuki dealer. Even some kind of model for printing would be great.
lucu is offline   Reply With Quote
Old 07-02-2012, 11:33 PM   #12374
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,148
I rode a dr650 today and it got me thinking about buying one. Hmmmmm
Old 07-03-2012, 05:24 AM   #12375
cwc
Oddometer: 920
It's good to have one of each.
Charlie
DR350 It'll get you there
My Ride Reports Here
cwc is offline   Reply With Quote
Times are GMT -7.   It's 05:31 PM.
