Old 07-11-2012, 11:08 AM   #12481
MrPulldown
MrPulldown's Avatar
Oddometer: 3,060
Originally Posted by devo2002 View Post
I thought the 99 had front and rear dirt suspension, or is that just the showa fronts?
Do you have the rebound adjustment on your shock not jsut the compression?
Are you a memeber of Max suzuki. I started a thread with a lot of pictures.
http://www.maximum-suzuki.com/forums...?topic=85682.0
All 90-99 dirt had a 11 inch travle (not the stroke length of the shock, but what the travel of the rear wheel is, as listed in the factory manual) shock with rebound and compression adjsutment.
90-93 S has a 11 inch travel shock with compresion only
94-99 SE all had a 10 inch shock (most distinguisable by the welded lower clevis mount). It only had compression dampneing adjsutment.
The dirt was valved stiffer than the SE model too.
As for the front. I think they all had the same suspension over the years. The only differnece is the 97 dirt got the single chamber showa fork, which did not show up on the SE till 98.
Right now there is a really clean dirt shock on e-bay.
MrPulldown is offline   Reply With Quote
Old 07-11-2012, 11:22 AM   #12482
Laser145
Laser145's Avatar
Oddometer: 358
Great Idea!!!
I looked at the spare motor the other day... Wiseco piston in it is brand new, never run... The stock forks are in perfect shape and have brand new seals...just leaning against the wall. It has the street version charging system... It has everything except electric start. Tires are also in nice shape.
The title just says "Suzuki Motorcycle" no mention of dirt only, etc, etc...
Someone will enjoy it.
I say we all go in on a group buy in /part out on this thing. I'd buy a few of those upgrades for sure. Whadda ya say
1976 BMW R75/6
2007 KTM 690 Supermoto
Laser145 is offline   Reply With Quote
Old 07-11-2012, 11:43 AM   #12483
MrPulldown
MrPulldown's Avatar
Oddometer: 3,060
Originally Posted by Laser145 View Post
Great Idea!!!
Bad Idea! You have such a nice bike. Don't let someone part it out. Someone needs to buy this and ride the piss out of it. I would if you were in CA.
Old 07-11-2012, 12:39 PM   #12484
go::ahead
go::ahead's Avatar
Oddometer: 69
Originally Posted by _CJ View Post
Recently got into this deal myself after 20+ years of mountain biking. Bought a 1990 DR350 too.
My bike came with the factory tool tube, but no tools. I ended up getting an expandable tool bag that mounts on the fender (Moose Racing) and filled it with a front and rear tube, patch kit, a light assortment of tools, and a hand pump that works with CO2. Mounting on the front fender blocked the headlamp, so I moved it to the rear fender.
Doesn't look like you're too far away. If you ever find yourself in Colorado (for the Westfest for example http://advrider.com/forums/showthread.php?t=737558), give me a shout.
Edit: Here's a link to a thread where I asked the same question and received 5 pages of replies - http://advrider.com/forums/showthread.php?t=776989
Much appreciated CJ! I really dig that adv kit in the first reply, he must be a prepper!
Mountain biking has given me a real fear/respect of being stranded miles from any road, the moto only compounds this by taking my further into the woods with more to go wrong, perfect!
Thanks for the link, I'll holler if I ever cruise up your way
go::ahead is offline   Reply With Quote
Old 07-11-2012, 09:25 PM   #12485
Airvent
Airvent's Avatar
Oddometer: 347
Fellow DR350 riders,
Have a look at my Ride report! I rode my DR350 4700 miles in 11 days. Lots of good DR350 porn in here
Linky
Airvent is offline   Reply With Quote
Old 07-11-2012, 10:39 PM   #12486
boardforever
boardforever's Avatar
Oddometer: 169
Linky
Awesome RR, looks like you guys had a blast.
1999 DR350SE
2006 Kawasaki ZZR600 [sold]
boardforever is offline   Reply With Quote
Old 07-12-2012, 03:14 PM   #12487
MrPulldown
MrPulldown's Avatar
Oddometer: 3,060
Took some pictures on my dirt commute home yesterday.
Check out my leaking fork seals. Only does this if I hit jumps and woops really hard. I have noticed the oil rings on the sliders. They seem to always appear in the same locations. I know those rings are a result of where the travle stops. But do they also correlate with wheneach shim opens up. Looks like I use up all of my travle.
Old 07-13-2012, 10:07 AM   #12488
WeeMcD
V-Strom explorer
WeeMcD's Avatar
Oddometer: 446
Perhaps you need to clean the seals?
Blog of my adventures: www.BestScenicRoutes.com
"When all else fails get a bigger hammer."
WeeMcD is offline   Reply With Quote
Old 07-13-2012, 10:08 AM   #12489
5*DR350
5*DR350's Avatar
Oddometer: 14
The OEM DR350 sprockets have a built in washer to locate the sprocket teeth properly along the splined shaft. I guess you can add a washer, but I would want to use an OEM style if it was me.
Digging a little deeper I see that the DRZ sprocket does have the built in washer, just not as thick.7.1mm vs 10.2
Maybe it would be ok to jsut space out that 3 mm
http://www.ebay.com/itm/JT-FRONT-Spr...ed9ee5&vxp=mtr
http://www.ebay.com/itm/JT-FRONT-Spr...9086f0&vxp=mtr
I used a zinc washer from homedepot for now. It is working so far for 80 miles. I am looking into an OEM style one though. I dont want the washer to cause wear on the shaft or the shaft to cause wear on the washer.
5*DR350 is offline   Reply With Quote
Old 07-13-2012, 10:23 AM   #12490
devo2002
-Devo
devo2002's Avatar
Oddometer: 3,821
Acerbis tank question
So, installed no problem but I've never had to deal with this before
I understand the concept but how do you attach the tube to the vent so it's secure? I can put the hose on the nipple but I don't think it will stay for long. And where are you routing the hose? With the existing clutch/throttle route? I've seen some just six inches with a cap on top, what's with that?
I looked all over and don't see any info, thanks.
2014 DL650 Vstrom
devo2002 is offline   Reply With Quote
Old 07-13-2012, 10:31 AM   #12491
Greg Bender
Oddometer: 1,162
I zip tie a long tube to my crossbar with enough length to allow full turns in both locations. My experience with short tubes that are not secured to the bike is that they get lost very quickly when off-pavement, standing up and sitting down, etc.
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 07-13-2012, 11:01 AM   #12492
AtlantaViking
AtlantaViking's Avatar
Oddometer: 924
I've got the same tank and same issue. The nipple on the cap is too short so the tube always ends up popping off at some point - I just live with it and stick it back on. As for where to route it to - I do the same as Greg and just loop it over the crossbar and hide it between the triple tree and the gages.
I'm here to chew bubblegum and kick ass....and I'm all out of bubble gum
06 Suzi DL1K
99 Suzi DR350SE
AtlantaViking is offline   Reply With Quote
Old 07-13-2012, 11:17 AM   #12493
motolab
motolab's Avatar
Oddometer: 2,524
Originally Posted by MeterPig View Post
It's sounds like a classic needle valve problem. However, you may get away with just dropping the bowl, cleaning it all out and cleaning the needle valve and spraying some carb cleaner up into the carb. This is something that can be done in a pinch if you don't have a garage and such. The needle valve is a wear item (the rubber tip) and does need to be replaced every so often. More than likely, just a bit of dirt. Do you have a fuel filter from the tank? If not, you might want to get one.
Good luck!
Don't forget about the needle seat o-ring, which may be hardened/deformed/shrunken/cracked. Also, the tip of the needle can be inspected under magnification. If a witness line is evident where it has been contacting the seat, the needle should be replaced.
Regards,
Derek
motolab is offline   Reply With Quote
Old 07-13-2012, 11:44 AM   #12494
Alli
Alli's Avatar
Oddometer: 56
[/QUOTE]
Hi Gregory
Your post was perfect timing, thought I would have to go through a bunch of pics and searches to see if anyone has the Moose Racing chain guide and pretty much first pic and I see it on your bike.
I wasn't 100% sure it was the right one till I saw yours.
I just received mine today and tried it on( took me a few head scratches to figure it out)
A question if I may (or two), firstly, how do you feel about it? Stable? do you have any issues with it?
It seems to me a bit odd that the third, rear bolt isn't used, did you make a bracket for it or just left it like that? (I don't see one in your pic).
I'm still rebuilding my DR, so I can't test it yet, so hoping you and anyone else who has also got one can give me a bit of info.
Thanks in advance
Allan
Alli is offline   Reply With Quote
Old 07-13-2012, 11:54 AM   #12495
Greg Bender
Oddometer: 1,162
Originally Posted by Alli View Post
Hi Gregory
Thanks in advance
Allan[/QUOTE]
Hi Allan,
The chain guide came on my DR when I bought it few years ago, but it isn't a Moose one. Instead, it is made by Fredette Racing Products. Last year I replaced a few "wear" parts but other than that, it has been worry free.
http://www.frpoffroad.com/Fredette-R...atalogId=-1039
Hope this helps!
Regards,
Gregory Bender
Times are GMT -7.   It's 02:14 PM.
