Old 10-14-2007, 05:32 PM   #121
Matttys
Matt the Balloon Guy
Matttys's Avatar
Oddometer: 436
I have no need for $100 foot pegs on my cheap bike! $20 would have been nice, but $25 will work too. I should have them in a few days. Thanks for the heads up!
www.ProTwister.com
'04 Bonneville hack, '05 DRZ134SM minimoto, '02 955i Tiger, '08 WR250R
Matttys is offline   Reply With Quote
Old 10-14-2007, 06:52 PM   #122
BikePilot
BikePilot's Avatar
Oddometer: 11,251
Originally Posted by Helmet_Hair
My DR actually came with those on it from the previous owner. They WILL bend if you crash. My right one is a little bent from a get off at low speed, so they're nothing too special, but they do give a nice place for your boots to sit.
Yep, nothing special at all, but hugely better than stock (about twice the width!). If you want bullet proof (probably literally) pegs the IMS pro series are very good. They will not break - I'm quite positive you'd demolish the frame before they even budged (I had a pair on my KX250 for years and definately crash-tested them a lot lol).
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 10-14-2007, 07:01 PM   #123
Matttys
Matttys's Avatar
Oddometer: 436
Yeah, those or the Fastways are great. I only spend $1600 on the bike with upgraded carb, spring front/rear, airbox, battery removed, new bars, Kouba link, Big Gun exhaust, fork brace, etc. All told, the bike had 2600 miles and is worth every penny!
I just cannot believe that I dual sported my F650GS Dakar for so long. That thing is a beast at 400+ pounds. I think my 350 is maybe 260 or so.
On a side note, I've got MT21's on the bike right now, but think I want to find tires that will help me hook up a little more off road. Any suggestions on a purely off road tire? I've been searching, but every thing I've read seems to be that the tires wear out in under 1000 miles. Maybe that's just a trade off that I will have to make, but with a street legal bike I don't want to burn them up just because I wanted to ride around town a few times.
www.ProTwister.com
Old 10-14-2007, 07:12 PM   #124
BikePilot
BikePilot's Avatar
Oddometer: 11,251
Sadly there's no such thing as a tire that works well on the street and in the dirt. Dunlop 606's might be a little better than the MT21's and Mich AC10's are also supposed to be pretty decent, but still a comprimise. For pure off road on a bike like the DR I tend to favor a bridgestone M59 front and IRC M5B rear. For a bike I'll be riding fast off road I stick with mx race rubber as its lighter and had different flex charcteristics than the m5B/m59 combo, but on the DR you'll never find the limit of the tire carcas and they are quite stiff, durable, hook up really well and last well (for an off road only tire).
have fun
Old 10-14-2007, 07:14 PM   #125
old sparky
Oddometer: 4
Dyno jet help please
Hello. I bought a new 07 Dr650 I have 900 miles on it. I have been reading all the threads I can. During the past month I have read this whole thread. Lots of information but now I cant find what I need and know I have read the answer.
I purchased a dyno jet kit and have installed it today. 155 jet airbox mod drilled air slide set the needle on fourth slot using the wacher and clip omitting the white spacer. Using the extended air mixture screw out 3/4 turn at 1000' elevation stock exhaust.
Problem is this. It started right up. Only signifacant differance is air box noise with a slight increase in performance not much. I figured I needed to adjust the air mixture. With the bike warmed up turning the air mixture screw clockwise till light seat no stumble, out 1 1/2 no change.
any help
thanks, Sparky
old sparky is offline   Reply With Quote
Old 10-14-2007, 07:18 PM   #126
BikePilot
BikePilot's Avatar
Oddometer: 11,251
You might have better luck starting a new thread or posting in a DR650 thread. I've never worked on a DR650 but airbox mods typically yeild more noise than anything else unless combined with other mods as well. Dialing in the jetting should always help out though, but as each bike, rider and set of conditions is different there's no one-size fits all kit - it might get you sorta close but to have it spot on you'll nearly always have to dial it in yourself.
Note that the fuel screw only really affects idle and even then they are generally only really effective from about 1/2 turn out to about 2 1/2 turns out so if your outside that range (and this is just general info, I don't know much about the 650 specifically) you'll need to go to the next size pilot.
good luck
Old 10-14-2007, 07:23 PM   #127
Matttys
Matttys's Avatar
Oddometer: 436
Haha, I should have known! All the other tires were $40-50. Those are $70-90. I was hoping to find a good tire for cheap, but that's not terrible a terrible price as long as I can stay off the roads
Thanks for your help!
www.ProTwister.com
Old 10-14-2007, 07:58 PM   #128
Matttys
Matttys's Avatar
Oddometer: 436
OK, one more question whilest I'm in the typing mood.
If I ride the 350 around town, to the store, at any speed and stop, turn it off it will immediately restart. But when I'm trail riding mostly in 1st, 2nd and sometimes 3rd gear and I stall the bike or turn it off to take a water break, I cannot restart the bike without letting it sit for 5-10 minutes. I can kick my little heart out, but the bike won't start.
Any ideas what could be going on here or how to fix the problem? Or is this just an oil cooled bike issue?
www.ProTwister.com
Old 10-14-2007, 08:23 PM   #129
Helmet_Hair
Helmet_Hair's Avatar
Oddometer: 225
Bit of a "hot bike" issue maybe. When kicking mine over when hot I need to use the decomp lever to find TDC and crack the throttle about 1/4 to 1/2 open. Usually starts on the first kick. This is normally a recipe for a nasty kickback if the piston's not at the top, so I always use the decomp to be sure I've got it. This method may or may not work for your bike...seems to work for mine.
Helmet_Hair is offline   Reply With Quote
Old 10-14-2007, 09:45 PM   #130
electrolite
Wanderer
electrolite's Avatar
Oddometer: 48
Just a few pics from last weekend, me and a buddy rode up an old mining trail and found some logging going on and the road all tore up and replaced with thick mud.
sorry this ones kinda blurry, the old dr's just got so much power the camera couldn't keep up
electrolite is offline   Reply With Quote
Old 10-15-2007, 05:19 AM   #131
Matttys
Matttys's Avatar
Oddometer: 436
I've used every trick there is. TDC w/ decomp, TDC without, no throttle, some throttle, choke even. I'm running full Amsoil synthetic in it so it shouldn't be too hot, but still. This bike is hard to fire once it's hot!
www.ProTwister.com
Old 10-15-2007, 06:22 AM   #132
BikePilot
BikePilot's Avatar
Oddometer: 11,251
Don't know for sure - both mine start right up hot or cold (but they have e-start).
I do know that all the modern thumpers have a special hot-start button. I think it lets extra air into the carb to lean it out or something like that. I know all the OEM FCR's have them and the aftermarket FCR probably does too, might be a good excuse to upgrade
For the M5B you'll probably want a 130 width (I ran a 140 on my CR500 and onmy dad's XR650L - those also work great, but I'm not 100% sure they would fit the DR's swingarm, but I think they would if you wanna try it:))
Old 10-15-2007, 11:25 AM   #133
Matttys
Matttys's Avatar
Oddometer: 436
OK, I'm just going to live with the hot bike issue for now. Bike already came with the upgraded pumper carb from Jesse and I'm not ready to spend $400 on a new carb.
Thanks for the width on the tire, I figured a 140 might be too large.
www.ProTwister.com
Old 10-15-2007, 06:38 PM   #134
Helmet_Hair
Oddometer: 225
Hmm. You've already got a good carby on there. I found if my intake valves are just a little tight, it can cause some hard starting too. Wonder if that's why it's easier to start if you let it sit for a few minutes. Just thinking out loud.
Old 10-15-2007, 08:45 PM   #135
Matttys
Matttys's Avatar
Oddometer: 436
Yeah, I've thought about that, but at this point I would rather spend my one or two days a month riding rather than checking valves. That sounds like a project for Turkey Day weekend!
www.ProTwister.com
Times are GMT -7.   It's 11:14 PM.
