11-23-2012, 08:24 PM
#13681 |
Oddometer: 487
My '98 with 1.3K miles is mostly stock except for tires. I have removed non essential stuff, safety interlock switches and buddy pegs. Added hand guards, wind screen, and rear rack. I'm 160 lbs. At 65MPH GPS it turns an effortless ~6k RPMs, or a little less, with 16T frt sprocket about 5500. I don't like spinning the motor,( seen too many blown motors) but this one feels quite comfortable. 65MPH is about as fast as like to go anyway, and it'll do it easily.
11-23-2012, 08:51 PM
#13682 | |
Oddometer: 52
11-23-2012, 08:56 PM
#13683 | |
Doing it Wrong
2003 Sv650s; 2012 BMW F650GS; 1999 Suzuki Dr 350se Leave the busy interstates and highways for the cagers. My Youtube Channel |
11-23-2012, 09:19 PM
#13684 | |
almost gnarly
Oddometer: 1,472
'97 R1100GS, '99 DR350, '02 DR650, '03 DR650, '04 R1150RT A Few Days Solo to Copper Canyon A Maine Rider’s Arizona Day Trips A Few Days Solo in Baja |
11-23-2012, 09:28 PM
#13685 | |
Sleep, Wrench, Ride
Oddometer: 4,446
Parts between the two engines are interchangeable (trannies, crank, jug, heads, etc) so you aren't saving any weight with the smaller engine. In fact everything on those two bikes are interchangeable: frame, swingarm, suspension, etc. They are virtually the same bike with a different bore and stroke.
Bikes: DR350 | GR650 Street Tracker | NX650 Turbo | Catamount Cycles Events: 2013 Monkey-Butt 500 | BreckTrek 2013 |
11-23-2012, 09:40 PM
#13686 | ||
Sleep, Wrench, Ride
Oddometer: 4,446
With each of these mods you'll want to play with your gearing to get it comfortable at higher speeds without revving the engine too much. I have a 440 kit, open airbox, pumper carb, I weigh 190 lbs, and live at 9000 ft elevation and I don't have an issue hitting 65 on my bike.
11-23-2012, 09:55 PM
#13687 | ||
Oddometer: 52
On a side note, I can buy a heavily modified 2005 DRZ400SM in perfect condition for about $650 more than the budget I have for this DR350SE (buying it and sticking $1,000 in it). If I'm talked out of this DR350SE, I may have to just shell out for it, and drive the 200 miles to get it. .I need a bike pronto.
11-23-2012, 10:07 PM
#13688 | |
KIWIINUSA
If you have a bike like I do that drains batteries over a week or so then disconnect the Shoria for that time , they hold a charge on their own very well , I have Sherco 510 with one that I never disconnect but my DR450 has something doing a slow drain , I believe the switch itself , and I have found it dead flat on a number of occasions , I will put the Shorai charger on and both lights blink away for a couple of days sometimes and then just the green light will be flashing indicating that it is charging .Anymore than a couple of days I will give it a bust on the regular charger .
88 R100GS 75 Norton Commando Roadster 98 DR450 07 Sherco 450 called BLING. 07 Sherco 510 called Holy Shit . |
11-23-2012, 10:15 PM
#13689 | |
KIWIINUSA
11-23-2012, 10:35 PM
#13690 |
Oddometer: 52
Haha. That's a great video. I like the random tanks on fire and people bursting out of the floor at the beginning. I don't doubt the capabilities of the bike, I just want to be able to ride long distances at a good speed and not worry about killing it dead. I really like these bikes, and I know people do adventure riding on them, as I plan to do, I just don't know at what speeds they maintain, or what modifications they've done.
11-24-2012, 04:31 AM
#13691 |
Oddometer: 169
My 1990 DR350s is setup with 16T front, and a 41t Rear, It runs 70 all day with no problems right around 6k RPM? i have had no problems. mines bone stock with all the jazz still on it. That with the clarke 4 gallon tank on it too. The CV carb gets me some extra miles at no cost. I have no complaints about speeds at all now. Still does great in the woods too.
-WagZ- '93 DR350S **WANTED**: White or Aluminum Frame Guards for DR350. Please PM with details. |
11-24-2012, 05:54 AM
#13692 | |
Oddometer: 581
I have a 1993 DR350 and I've used it with both a pumper carb (as original) and now a CV carb. For pavement work and regular off-pavement duties I stick with a 15/41 sprocket set (I switch to 14/41 when the off-pavement work gets a bit tougher). In the past two years, I've ridden it over 12,000 miles; including 3 big multi-day trips. These trips start off and end with me ridding pavement to meet up with my ridding buddies at some distant location from where I live (or coming back home). Examples include: Clayton, NM - 800 miles over two days; Green River, UT - 500 miles in one day; Mexican Hat, UT - 320 miles one afternoon; Jackpot, NV - 730 miles in one day, Ely, NV - 525 miles in one day, etc. These rides are always in the summer months and that means 110 degrees plus here in the Phoenix area (and Las Vegas, too). I maintain speeds of 60 - 65 MPH all day long going to these locations. I'm 6'3", 220 pounds, and carrying an original Giant Loop with canoe sack strapped on top, a Clarke tank, and plenty of water in my camelbak. I generally keep the speed around 65 MPH without any trouble. Yes, I can wick it up from there a bit if I need to, but it feels like I'm pushing the engine too hard. There are some long uphill pulls in parts of Nevada where I ride (maybe 20 miles of continuous pulling up hill). I'll end up a lot closer to 60 MPH or maybe a bit less running up those at the higher Nevada elevation. I don't necessarily thrill at the thought of these long pavement days with the DR350 (my Moto Guzzis are so much better at that work), but, the DR350 gets the job done. These really are tough machines. Regards, Gregory Bender |
11-24-2012, 06:13 AM
#13693 |
Oddometer: 37
Shorai Battery
“If you have a bike like I do that drains batteries over a week or so then disconnect the Shoria for that time , they hold a charge on their own very well”
Fortunately this bike does not have a drain when sitting. One issue with the original battery was that the PO had installed a battery from a non-e start DR350. On its best day it had trouble getting the bike started. “Take a lesson from me. If it is flat, DO NOT use a regular charger to charge it up. I ruined a 4 week old Shorai by doing this. Very expensive lesson.” Thanks for the heads up on dealing with one that goes totally flat, hopefully I won’t run into this situation. I will definitely take the battery out for the winter. |
11-24-2012, 06:58 AM
#13694 |
mc caregiver
Oddometer: 2,590
11-24-2012, 12:00 PM
#13695 |
Oddometer: 52
Because I need a lightweight offroad bike, not a street bike. If I needed a street bike I wouldn't have sold my Harley a couple of weeks ago. I offroad, very fast. And I've ridden a CR500R on the street doing 70+ consistently for many miles, and it's light weight and grand vibration never bothered me. I'm not looking for comfort, I'm looking for light weight, and highway speeds. I'm not looking for a 100% on road bike, if that's what you're thinking. The bike will spend most of it's time pounded offroad around here, but I want to make trips across country on it this winter, and possible every other month when it warms up.
