Old 12-02-2012, 08:30 PM   #13771
ctjohnson
Oddometer: 27
Originally Posted by MrPulldown View Post
You have also found out what Suzuki uses a vacume opperater petcock.
Yes, I already had put a yamaha raptor petcock on the stock tank. Took the carb out, cleaned it , and runs like new and doesn't flood. Something must have stuck in the float needle seat (maybe from the new tank) although I did clean the tank before installing it.
ctjohnson is offline   Reply With Quote
Old 12-03-2012, 05:23 AM   #13772
djpreston
djpreston's Avatar
Oddometer: 17
Fitted an Acerbis XR400 tank, with my current fuel consumption I should be getting around 450km (280 miles)!!
Now I just need a few ideas on what color to paint the tank, any suggestions?
Also need a new stock rear fender, the previous owner cut this one short.
Thanks,
Dale
[IMG]Photobucket[/IMG]
djpreston is offline   Reply With Quote
Old 12-03-2012, 06:14 AM   #13773
shearboy2004
KIWIINUSA
shearboy2004's Avatar
Oddometer: 4,086
Send a message via Skype™ to shearboy2004
Dale don't paint the tank , if you ride off road it will look like shit really quickly.
88 R100GS
75 Norton Commando Roadster
98 DR450
07 Sherco 450 called BLING.
07 Sherco 510 called Holy Shit .
shearboy2004 is offline   Reply With Quote
Old 12-03-2012, 06:16 AM   #13774
Stretch67
Mad Scientist
Stretch67's Avatar
Oddometer: 3,168
The gasoline vapors coming through the tank will blister up the paint in short order.
Stretch67 is online now   Reply With Quote
Old 12-03-2012, 09:12 AM   #13775
RuggedExposure
wandering the desert
RuggedExposure's Avatar
Oddometer: 681
Thanks,
Dale
[IMG][/IMG]
I'm looking at doing the same thing shortly, What did you do for the mounts on the front end? pics please
Many 'a hand began to scan around for the next plateau. Some say it was Greenland, and some say Mexico. Others decided it was nowhere except for where they stood.
Border Road 100 Border Road Rally Raid
'13 Husky Terra 650 , '08 Kawasaki Meanstreak 1600, '95 DR350S
RuggedExposure is offline   Reply With Quote
Old 12-03-2012, 09:13 AM   #13776
RuggedExposure
Oddometer: 681
I screwed the pooch and ordered a 41 tooth rear sprocket for an SE model instead of a dirt model.
Anyone need a new/spare rear sprocket? Its a brand new JT sprocket.
$24 (includes shipping) sent to anywhere in the US.
Old 12-03-2012, 10:20 AM   #13777
MrPulldown
MrPulldown's Avatar
Oddometer: 1,249
Can't you return it?
I think the Acerbis xr400 tank mounts with the rubber disk off the engine mount bolt. SImilar to the way the DR350 acerbis tank mounts. I thought you asked for some details of the mount (dr350) a few pages ago.
http://www.maximum-suzuki.com/forums...?topic=88944.0
The XR400 has a write up here, but no pics of the under tnak mount. You will not need to trim the stock tank mounts as it is a street model only thing.
http://www.wilddog.za.net/forum/inde...opic=58367.160
94 DR 350 SE
MrPulldown is offline   Reply With Quote
Old 12-03-2012, 10:25 AM   #13778
RuggedExposure
Oddometer: 681
It was just easier to order a new one since this was part of a set (I alredy installed the new chain and front sprocket).
I've never seen that forum, I should probably join.
Old 12-03-2012, 10:26 AM   #13779
MrPulldown
MrPulldown's Avatar
Oddometer: 1,249
Originally Posted by a1fa View Post
The 93 DR350 was kickstart only? how hard is it to add electric start?
I hate it when peopel tell me I can't do a particular mod to my bike. Sure selling your bike and getting a E-start is the easiest thing to do. The next easiest thing to do is to buy a E-Start engine and swap it in. The main issue is where the start connects to the case and crank.
From this picture you can see that their is an extended case cover to accomidate the starter and gear set. The extended section however is not jsut limited to the cover but the case itself has the matching back half. Their is also auto decompression mechanism on the head that you will need.
Finally you will need to sort out the electricals. I know the SE has a large battery and battery box that the S.
94 DR 350 SE
Old 12-03-2012, 10:33 AM   #13780
RuggedExposure
Oddometer: 681
Is this the correct model year for the tank? Does it include a new petcock?
Old 12-03-2012, 11:33 AM   #13781
tntmo
Oddometer: 226
Would it be possible to install an E-start engine into a kick start frame? Sure, it will bolt right in. Would it be worth it? Maybe, if you were able to get the engine and the entire wiring harness including the additional electric bits the E-start has all in one package for a decent price. Once you need to start buying bits and pieces, it will end up being spendy.
Sometimes, the ends just don't justify the means.
Buncha dirt bikes with license plates.
tntmo is offline   Reply With Quote
Old 12-03-2012, 11:38 AM   #13782
RuggedExposure
Oddometer: 681
Why are you so bent on having an E-start? Whats wrong with a kicker?
I have electric start and kick start bikes (and one that was both), and 10/10 I prefer a kick start. You save weight not having the extra parts and a battery, your electrical system is a lot simpler and you'll never be stranded on the side of the road with a dead battery.
If anything I'd be more concerned about how to convert an E-start to a kick start.
Old 12-03-2012, 11:43 AM   #13783
tntmo
Oddometer: 226
I am not intetrested in E-start, just replying to the thread. I bought a kick start DR350 to replace a DRZ400S because it was too heavy for my wife.
Old 12-03-2012, 11:48 AM   #13784
RuggedExposure
Oddometer: 681
Ah sorry, I misread your post thinking you were the one trying to convert it.
Old 12-03-2012, 11:55 AM   #13785
VooDooDaddy
VooDooDaddy's Avatar
Oddometer: 144
Ezactly. That's why I recently acquired all the parts to convert my '99 SE (still keeping the button option) to have the kicker option.
Yeah, it will put a couple more pounds onto the bike, but if I were really concerned about weight on the bike, I'd probably stop eating pie every night before bed time....!
VooDooDaddy is offline   Reply With Quote
Times are GMT -7.   It's 06:09 AM.
