Old 12-07-2012, 05:17 AM   #13846
cwc
Oddometer: 744
Originally Posted by MrPulldown View Post
Based on this:
http://oem-cycle.com/KawasakiDR350.shtml
This is what you need:
http://www.ebay.com/itm/2004-suzuki-...badc88&vxp=mtr
old Froks are 15mm axles. Newer ones are 17mm
Thanks. That's an interesting page.
I ordered the other link. If the speedo drive has some life it will be a good deal.
Presently shopping for frocks.
Charlie
DR350 It'll get you there
But then so will my DR650
My Ride Reports Here
cwc is offline   Reply With Quote
Old 12-07-2012, 07:31 AM   #13847
flyinfuzz
Redneck with money
flyinfuzz's Avatar
Oddometer: 1,079
How about changing the clutch rod oil seal.? Does it pop out the top or need to pull the clutch cover to push it out from the inside ? 1998 sew . It figured since I lubed its chain it would return the favor and lube my boot
Cotton says "People are crazier than anybody"
flyinfuzz is offline   Reply With Quote
Old 12-07-2012, 07:44 AM   #13848
Greg Bender
Oddometer: 611
IIRC, it pops out the top. Can be removed using typical "dental pick" tools. Just be careful not to gouge anything and you'll be set. Pretty easy, actually.
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 12-07-2012, 11:45 AM   #13849
Laura0107
Retrophilic Rambler
Laura0107's Avatar
Oddometer: 1,050
Originally Posted by dirtyron View Post
mine just died. need one fast. any walmart fits? 96 se
If you're near a Batteries Plus store, you could see if they have this one. I've never tried it, though; I always just use Yuasa.
Sandlapper Braaaappper - Savannah River Rambling - SC Dirt! - On a perpetual dirty road tour in the land of Hicks and Nothing...
Laura0107 is online now   Reply With Quote
Old 12-07-2012, 01:35 PM   #13850
kobukan
almost gnarly
kobukan's Avatar
Oddometer: 1,484
Regards,
Gregory Bender
+1
"Dig" it out from the top. Just make sure you get everything out and the hole is nice and clean before you try putting the new one in or it won't go. A little oil in the hole and on the new seal will help it slide in.
'97 R1100GS, '99 DR350, '02 DR650, '03 DR650, '04 R1150RT
A Few Days Solo to Copper Canyon
A Maine Rider’s Arizona Day Trips
A Few Days Solo in Baja
kobukan is offline   Reply With Quote
Old 12-07-2012, 05:31 PM   #13851
flyinfuzz
Redneck with money
flyinfuzz's Avatar
Oddometer: 1,079
Thanks $ 2.75 seal $ 5.50 shipping
Old 12-07-2012, 06:25 PM   #13852
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 12,787
quiet exhaust anyone?
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 12-07-2012, 07:08 PM   #13853
Stretch67
Mad Scientist
Stretch67's Avatar
Oddometer: 3,202
Are you asking if anybody has one for sale, or who prefers quiet over aftermarket loud? My 250 came with a scrapped-together POS homebrew pipe that sounded like crap, so I found a good used pipe on FleaBay. Nice and quiet.
I did the same with the gutted pipe on my new '98 XR400... stock quiet pipe from eBay. I hate loud pipes.
Stretch67 is offline   Reply With Quote
Old 12-07-2012, 10:10 PM   #13854
RuggedExposure
wandering the desert
RuggedExposure's Avatar
Oddometer: 720
Just put on new front sprocket, rear sprocket, chain, changed the oil and adjusted the valves.
While I had the tank off, I took a pic of my security switch I installed. I don't have a fancy key ignition like the SE owners, so I put on a kill switch before the spark plug and stuffed it to where I can barely fit my fat finger under the tank and engage it.
Many 'a hand began to scan around for the next plateau. Some say it was Greenland, and some say Mexico. Others decided it was nowhere except for where they stood.
Border Road 100 Border Road Rally Raid
'13 Husky Terra 650 , '08 Kawasaki Meanstreak 1600, '95 DR350S
RuggedExposure is online now   Reply With Quote
Old 12-08-2012, 07:19 AM   #13855
kobukan
almost gnarly
kobukan's Avatar
Oddometer: 1,484
I've thought about doing something like that, but if I'm really nervous about where I'm leaving the bike I shift it into a high gear (4th, 5th or 6th) and switch the headlight all the way off. On the Baja Designs handlebar switch I have the bike won't run with the switch in that position. I figure most thieves won't know that, and even if they figure it out they're going to make a lot of noise stalling out repeatedly before they ever find a gear they can take off in.
Old 12-08-2012, 10:29 AM   #13856
TopDeadCenter
TopDeadCenter's Avatar
Oddometer: 325
Quick question about the auto decomp on a '94 se. Is there supposed to be a lever sticking out of the valve cover? I thought the auto decomp models didn't have anything there. Mine does but doesn't have a cabel or bracket. Am I missing something here? Did someone put an older head or motor into this bike?
TDC
I wear a helmet in public! Yeah!
GS850GLX
DR350SE
TopDeadCenter is offline   Reply With Quote
Old 12-08-2012, 10:48 AM   #13857
canyonkid
Does it Matter
Oddometer: 13
if you look at this link MrPuldown posted
you can check your motor serial # to see if it matched your model year bike.
canyonkid is offline   Reply With Quote
Old 12-08-2012, 03:08 PM   #13858
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,127
As likely as not only the top end would be changed if someone messed with the engine for some reason. If the bike does indeed autodecompress then those parts are inside. If it doesn't then it needs a cable and lever fitting.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 12-08-2012, 03:08 PM   #13859
RuggedExposure
Oddometer: 720
My ADV stickers finally came in.
Old 12-08-2012, 03:23 PM   #13860
Bonerov
Oddometer: 167
Nice ammo boxes. I have a pair of boxes that I want to install on my DR, but haven't figured out how I want to mount them yet. I will likely end up having a buddy help me fab up something custom. So many projects, so little time (and money).
Bonerov is offline   Reply With Quote
Times are GMT -7.   It's 10:00 AM.
