Old 01-28-2013, 10:29 PM   #14446
Anonawesome
Scenic Rider
Anonawesome's Avatar
Oddometer: 1,359
Originally Posted by smc5735 View Post
Hey all,
Just a question about the amount of oil I need to properly run my 97 dr350se.
On the frame is says "1700ml," but does that not include the oil that stays in the engine itself?
The reason why I ask is because I put in a quart (.946 ml) ran the bike for about 3 minutes, then checked the oil, and put almost all of the other quart in (because of being a dry sump)...
...It reads low, .946 ml x 2 = 1892 ml
It still reads low after I run the engine for 2 minutes and then put the dipstick in (not screwed in).
Any ideas? tips?
My 1990 dr350s takes just under 2 litres. I know this from accidentally running it completely dry just past toronto, and it took a full 2 litres (they sell oil by the litre in canada). So 2 qts or a little over sounds about right to me, And you are correct in not screwing the dipstick in when checking.
Anonawesome is online now   Reply With Quote
Old 01-28-2013, 11:27 PM   #14447
tntmo
Oddometer: 533
Originally Posted by Anonawesome View Post
Valve clearances! To me it sounds like your intake valves are just barely not closing all the way. That would explain why in the video it's so easy for you to kick (low compression), the backfiring (back into the intake and carb), and why there is smoke from the intake when you remove the carb/intake boot/whatever it was.
It's easy to kick because it has an auto-decompression cam. All 94-99 dirt models have it and don't require use of the lever....even though they have the lever. I removed mine.
Buncha dirt bikes with license plates.
tntmo is offline   Reply With Quote
Old 01-29-2013, 04:54 AM   #14448
Greg Bender
Oddometer: 1,235
Originally Posted by Stretch67 View Post
Yep. Mine sat up for a couple weeks and I started it last night in three kicks. Valves in spec, fresh high-octane, full choke, 10 priming kicks, three real kicks. Vroom!
Agreed! I hear all the time people lamenting the kick-start problems with their DR350. My 1993 dirt model fit with a CV carb is a dream. Give it a bunch of priming kicks and then generally two real kicks. Done! Takes me longer to type this than to do it. After it is warm, no trouble at all.
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 01-29-2013, 06:14 AM   #14449
RuggedExposure
Now with more rugged
RuggedExposure's Avatar
Oddometer: 1,247
Someone brought this up a few pages ago, even though I had adjusted them about 750 miles ago.
So I checked them again, 0.003" for the intake valves...
Guess I could check them again.
The fear and dread of you will fall on all the beasts of the earth
RE Fotowerks
Border Road 100 Border Road Rally Raid
'13 Husky Terra 650, '08 Kawasaki Meanstreak 1600, '95 DR350S
RuggedExposure is offline   Reply With Quote
Old 01-29-2013, 07:24 AM   #14450
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,901
Does anyone have a spare stock exhaust willing to part with it for some $$?
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 01-29-2013, 07:40 AM   #14451
Vankaye
n00b on the move
Oddometer: 225
PM Sent.
Vankaye is offline   Reply With Quote
Old 01-29-2013, 07:47 AM   #14452
RuggedExposure
Oddometer: 1,247
I have a bad-ass Supertrapp setup I'll trade you
RE Fotowerks
Old 01-29-2013, 08:05 AM   #14453
tonusmaximus
maximus
tonusmaximus's Avatar
Oddometer: 588
im glad youre getting your sense of humor back! thanks for the laugh
tonusmaximus is online now   Reply With Quote
Old 01-29-2013, 09:46 AM   #14454
MrPulldown
MrPulldown's Avatar
Oddometer: 3,536
Sure you know this but turn the enigne over till you reach the point where the valves jiggle before you adjust the clearance. Mine was off from the TDC mark.
MrPulldown is offline   Reply With Quote
Old 01-29-2013, 09:54 AM   #14455
tntmo
Oddometer: 533
Switched out the cdi, still popping and sputtering.
Tomorrow I'll swapt out the stator to try that, and then the regulator if that doesn't do the trick.
I even swapped out the spark plug boot, no dice.
I don't know if I'd bother with the regulator. All that does is set the voltage for the head/tail light. It's not difficult to swap, but it shouldn't have anything to do with the way the bike runs.
Old 01-29-2013, 10:18 AM   #14456
MrPulldown
MrPulldown's Avatar
Oddometer: 3,536
I jsut bought a 2nd pair of 98 rm250 forks.
I think I have a problem.
Old 01-29-2013, 10:51 AM   #14457
straight cut
Oddometer: 136
[QUOTE=smc5735;20597290]Hey all,
Any ideas? tips?
WHEN YOU CHANGE THE OIL ONLY AND DRAIN THE ENGINE AND FRAME YOU WILL NEED TO PUT 1700ml BACK IN ,IF YOU CHANGE THE OIL AND OIL FILTER YOU WILL NEED TO FILL WITH 1900ml
THE VOLUMES INCLUDE ENGINE AND FRAME TOGETHER
I would drain the engine and sump into a measuring jug to see how much you have [make sure areas around the drain bolts are clean to avoid dirt getting into the oil] and then refil with 1700ml,run the engine for 4 minutes and check .You know how much oil you have put in via the measuring jug
straight cut is offline   Reply With Quote
Old 01-29-2013, 11:57 AM   #14458
Elliot the Kraut
Oddometer: 31
If anyone of you guys got a german granny - ask her for the "Otto" winter sale - mag, and have a look at page 119
... and smile
http://imageshack.us/photo/my-images/405/foto0325c.jpg/
Elliot the Kraut is offline   Reply With Quote
Old 01-29-2013, 12:06 PM   #14459
MrPulldown
MrPulldown's Avatar
Oddometer: 3,536
... and smile
Nice. The euro DR350 with the handles on the grab bar.
Old 01-29-2013, 12:10 PM   #14460
RuggedExposure
Oddometer: 1,247
I'll give it a shot.
You're probably right. I'm going to try and swap stators right now... the wind is blowing about 50mph and its 33*F out. I'll try dragging the bike into the tiny shop room and wrenching on it.
If this and checking the valves doesn't work, I'm setting it on fire.
something along the lines of this but angrier:
RE Fotowerks
Times are GMT -7.   It's 02:24 PM.
