02-11-2013, 02:03 PM
#14701 | |
Oddometer: 167
-WagZ- '93 DR350S **WANTED**: White or Aluminum Frame Guards for DR350. Please PM with details. |
02-11-2013, 02:20 PM
#14702 |
Oddometer: 23
oil change question
Hey all,
Did an oil change on my new to me 97 dr350se. I changed the oil filter, as well. I put one quart in, started the bike up, turned it off, put the other quart in. It says '1700ml' on the frame but is that for just the frame and I need more for the crank case? Because when I run the bike for 3 minutes, turn off, wait a minute and read the dipstick (by not screwing it in) it reads 'L' or Low. Two quarts is around 1892 ml.. thats obviously more than 1700 ml.... any ideas? |
02-11-2013, 02:41 PM
#14703 |
Oddometer: 339
2 quarts with a filter change is the right amount. The dip stick is terrible on the DR. You have to hold your tongue just right, stand on one foot, close your right eye 3/4 of the way and humm Camptown Races to get an accurate reading.
02-11-2013, 02:48 PM
#14704 | |
Oddometer: 581
Lack of oil is the easiest way to toast the otherwise very reliable DR350. Check it every time :> Regards, Gregory Bender |
02-11-2013, 02:54 PM
#14705 |
Oddometer: 120
Good place to mention this again
Re: lack of oil
Get one of the screw-in thermometers that replace the dipstick. I ordered one on eBay, cost about $30 shipped from Germany. I've had one on my bike for a bit and I usually see about 80-120C depending on ambient temperature and how quickly I'm moving. I mainly use the gauge as a way to make sure I've got enough oil in the bike. If it doesn't rise above 40c after a few minutes of riding, it probably needs to be topped off. |
02-11-2013, 03:19 PM
#14706 |
Oddometer: 23
Ghostyman, I closed my LEFT eye instead of my right, that's it !
Thanks for the responses guys I appreciate it. I guess I'll just be checking my oil more regularly than normal. As long as its 2 quarts I should be good to go. thanks again ! |
02-11-2013, 03:47 PM
#14707 | |
Oddometer: 167
the time is upon me to start getting the bike ready for rippin shit up. The rear of the bike is good to go! (SHAKE AND BAKE!!) the front it my main priority here..pretty much from handlebars down! On my list of stuff i have: New front tire, bearings, Tube, Brake pads, Rotor, oil change, Throttle tube, grips, and some plastic covers for my brush busters. (also need to mount my "headlight crash cage" that i bought, but doesnt fit real well with the brush busters...) If anyones got suggestions on Rotor/pad combos, let me know. Also suggestions on a good front tire that'll hold its ground on the road, and on the dirt...gonna run my 606 rear for a while this year till everything dries up then ill switch over to my Kenda to finish it off and replace this fall. so...if anyones got good links on tires, brakes, rotors, hit me with em! Thanks boys!! Woooot!
-WagZ- '93 DR350S **WANTED**: White or Aluminum Frame Guards for DR350. Please PM with details. mustangwagz screwed with this post 02-11-2013 at 03:53 PM Reason: needed to say more shit! |
02-11-2013, 06:25 PM
#14708 |
Riding Nomad™
Oddometer: 12,722
What's needed to improve the front brake feel? Mine feels like grabbing grandma's ass -- all mush and no push....
Learn to ride. Ride to learn. FS: 1993 Suzuki DR350S (wide ratio 6 speed - street legal kickstart) |
02-11-2013, 06:55 PM
#14709 | |
Oddometer: 120
And flush your brake fluid. A lot of people report better feel with stainless steel brake lines (immediately followed by a post from someone saying that they make no difference in actual braking. How are your pads? |
02-11-2013, 07:21 PM
#14710 |
Wishing I was riding RTW
Oddometer: 2,422
Oil change with filter I also do 2 quarts
I just flushed my front brake that almost pulled to the bar. With new fluid it's nice and firm.
My screen name is kind of long. I am the "ME" part, my name is Cory. Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..." |
02-11-2013, 08:10 PM
#14711 |
Miner
Oddometer: 40
02-11-2013, 08:28 PM
#14712 | |
Oddometer: 2,422
Got a order source where you got your oil temp gauge?
02-11-2013, 10:11 PM
#14713 | |
Oddometer: 274
Got head back, the bikes, from machine shop with time sert in and ready to go. Snapped plug off at head. Not cross threaded as they said I tightened to tight and did not use anti seize. Broke it off, taking it out! Oh well, never used anti seize before but will now. Heirhead Worlds worst mechanic heirhead screwed with this post 03-31-2013 at 10:57 PM |
02-12-2013, 12:03 AM
#14714 |
Oddometer: 120
Current eBay auction: http://www.ebay.com/itm/180498178219...219%26_rdc%3D1
and here's a German info page: http://www.rr-motorsport-ries.de/motorrad/produkt.htm Here's a pic installed on a DR350 (not my pic): ![]() The bottom of the probe is at the midpoint of the hash marks on the dipstick. When the gauge stops registering over something like 60C, check your oil. Look like it's gone up in price since I got mine. About $48 shipped from Germany |
02-12-2013, 04:46 AM
#14715 | |
Cultural Attaché
Oddometer: 21
Here's a link to another current seller on Ebay; not sure of your conversion rate but it looks a bit cheaper? http://www.ebay.co.uk/itm/2309279761...84.m1423.l2649 There's also some useful info on oil temperature gauges from Pablo, back on Page 20 of this very thread.... http://www.advrider.com/forums/showt...php?p=17041816 |
