Old 03-03-2013, 08:33 PM   #14926
boardforever
boardforever's Avatar
Oddometer: 213
Originally Posted by PWRCRZR View Post
looks good, what are the dimensions of those Keintech signals?
They are about 3.75" x 3.5" x 1.5" The tuck in nicely though under the rack.
1999 DR350SE
2006 Kawasaki ZZR600 [sold]
boardforever is offline   Reply With Quote
Old 03-04-2013, 04:09 AM   #14927
pdegroote
pdegroote's Avatar
Oddometer: 63
Originally Posted by Greg Bender View Post
Hi Patrick,
Yes, what you describe seems possible. Major internal damage? I don't know. Hopefully not. With the fresh oil in it, run it until it get's hot and then change the oil again (a second oil change to get any residual fuel out).
Then, I would ride it like I stole it and see what happens. If it doesn't blow up or start making crazy sounds, then I'd never worry about it again. If it did suffer major internal damage, then I don't think you are going to spend any more money riding it now, anyway.
Regards,
Gregory Bender
Follow-up:
I've done a test-drive yesterday and it starts quite well... starting the engine was no trouble, driving ok... untill it stalled some 500 meters further... I feared the worst, but then remembered I'd forgotten to open the petcock...
I restarted and ran it untill it was warm. No strange engine noises, nothing out of the ordinary.... I did have some issues in finding neutral at every stop, so I guess I need to check the clutch thrust washers and the bolt in there.... So plan for next spare moment: drain the oil, check the clutch, grease all linkages and bearings, check the cam and valves and I should be ok for some driving...
Regards
Patrick
2005 R1200GS
1998 DR350
1996 XJ900 Diversion
BMW R100R (sold)
pdegroote is offline   Reply With Quote
Old 03-04-2013, 04:37 AM   #14928
Greg Bender
Oddometer: 1,216
Originally Posted by a1fa View Post
Its quieter than my loud can I currently have on. Can't compare to stock... however... I can barely start my bike with this exhaust.. it will require a rejet..
Any of you boys know what jetting I should run at 300-2000 ft elevation? Stock airbox.. will mod airbox too.
I have a jesse modified muffler, CV carb, uncut airbox with snorkle tube. I run the stock CV jetting for my 1993 model (direct from the book). Works great for me and I live at 2200 feet and ride up from here almost exclusively.
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 03-04-2013, 04:40 AM   #14929
Greg Bender
Oddometer: 1,216
Originally Posted by pdegroote View Post
Follow-up:
Regards
Patrick
Awesome news! When I bought my DR350 back in 2009, I had to replace a missing shift drum bolt (bent the "L" shaped bracket when I did that and had to go back in afterward to straighten it)...I also clearanced the basket at the same time. It works a treat now unless I really heat up the clutch doing things I really should have had lower gearing for in the first place.
Regards,
Gregory Bender
Old 03-04-2013, 06:30 AM   #14930
rubberband
Will ride for tacos
rubberband's Avatar
Oddometer: 423
A call back to jesse should remedy this situation. He gave me a baseline to start with based on my set up carb, needle, airbox, etc
2011 UPAT
rubberband is offline   Reply With Quote
Old 03-04-2013, 06:50 AM   #14931
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,881
Thanks, I intended to call him today. Yesterday was Sunday. His shop was closed..
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 03-04-2013, 11:52 AM   #14932
SloMo228
World Class Cheapass
Oddometer: 1,826
Originally Posted by SloMo228 View Post
Well, it's in the garage now. Someone gave it a terrible half-assed paintjob but it does start and run with no unseemly noises. Stalls as soon as you try to get on the throttle but I plan on cleaning out the carb just as SOP with every "new" bike I get. Any recommendations for a quality rebuild kit if it comes to that? I'll try to post up a picture tomorrow, it was too dark for a decent shot when I got it home today.
Just an update on the bike:
After a good carb cleaning, it now runs relatively normally. I'm waiting on new O-rings and a float valve assembly to finish up the carb, but I couldn't resist putting it back on the bike to test it and run it up and down the street a bit. I discovered that the clutch slips pretty badly, but it could be due to the fact that the clutch cable is almost frozen. I have a new one on order.
Other than that, I just put on new turn signals, grips, and mirrors to replace the torn up old ones, installed a new air filter, and removed the kickstand and clutch starter interlocks. It's starting to come together.
On a related note, I'm looking for a luggage rack. I have a pair of Pelican cases that I want to mount and it would be nice to just buy a rack. However, I can build one too, so I'm not willing to shell out a a couple hundred for a new rack, so if anyone happens to have an old rack lying around that they want to get rid of relatively cheaply, let me know. Thanks!
--------------------------- Steve----------------------------------------
'96 DR350SE
SloMo228 is offline   Reply With Quote
Old 03-04-2013, 03:35 PM   #14933
mustangwagz
mustangwagz's Avatar
Oddometer: 247
Originally Posted by OldUKBikerGuy View Post
I emailed him from the UK a couple of months ago about ordering a pumper carb kit; his wife said that they weren't doing any international shipping anymore. Maybe that has changed now?
Still, it made me reconsider my plans and so saved me lots of money, both on the carb and future gas mileage.
some more info to help support this theory, I emailed him about frame guards (the ones by the footpegs he used to get, they were aluminum ones..) He dont deal international anymore, but he did point me to a company in Austrailia that still makes the frame guards and sells them. PRetty pricy to get a set here though. (close to 150 US dollars..)
-WagZ-
'93 DR350S
My attempt to roundup Local Riders..
https://www.facebook.com/dualsportridingwesternpa
mustangwagz is offline   Reply With Quote
Old 03-04-2013, 06:09 PM   #14934
ADV BUM
Oddometer: 124
What company still makes them? Maybe we can do a bulk purchase to keep the cost down?
ADV BUM is offline   Reply With Quote
Old 03-05-2013, 04:42 PM   #14935
Bridude
Oddometer: 12
Corbin seat for DR350
Hi,
I don't want to break any rules...where/what thread do I advertise a Corbin seat for a DR350??
Bridude is offline   Reply With Quote
Old 03-05-2013, 04:50 PM   #14936
2old2Bbold
was 2bold2getold
Oddometer: 1,843
Originally Posted by Bridude View Post
Hi,
I don't think anybody minds if you post it here. But, normally, here... http://www.advrider.com/forums/forumdisplay.php?f=14 , under "parts. "Then post a link to it here.
2old2Bbold is online now   Reply With Quote
Old 03-05-2013, 06:15 PM   #14937
cwc
Oddometer: 939
Cam Chain Tensioner
My cam chain measures about 127.5mm across 21 pins(center to center), spec is 128.9 so that seems OK. The chain has about 20K miles on it.
The sliders show no wear.
So I installed the tensioner per the book and then removed the spring before pulling out the tensioner. The push rod was 3 clicks from being fully extended.
Is this normal?
Does anyone know what the 21 pin measurement is on a new chain?
Charlie
DR350 It'll get you there
My Ride Reports Here
cwc is offline   Reply With Quote
Old 03-05-2013, 07:10 PM   #14938
trippda
trippda's Avatar
Oddometer: 55
Hi,
Checked the flea market but didn't see it. Post a link or the deets!!!
I like.
jeeze, the list of crap I want to buy for my DR is long. But getting shorter!
Get busy living, or get busy dying
'96 - DR350 -'04 Sherpa
trippda is offline   Reply With Quote
Old 03-05-2013, 09:04 PM   #14939
Bridude
Oddometer: 12
DR350 Corbin seat for sale!!
I like.
OK...here are the details!
I bought my DR350 a few months ago and it came with a Corbin seat as well as the original seat, which I prefer. The guy I bought the bike from bought this seat himself about 2-3 years ago. He paid around $350 for it. It is in great shape with no rips tears, cuts, etc.
I am willing to sell it for $225.
Below is a pic of the seat on my bike;
photo storage
Old 03-05-2013, 10:27 PM   #14940
MrPulldown
MrPulldown's Avatar
Oddometer: 3,395
Which one is the 250 and which the 350?
MrPulldown is offline   Reply With Quote
Times are GMT -7.   It's 09:30 PM.
