Old 03-08-2013, 03:39 PM   #14971
2old2Bbold
was 2bold2getold
Oddometer: 1,915
Originally Posted by thump! View Post
The ignition switch on your bike does exactly the same thing as the kill switch. When it is in the OFF or locked position it simply grounds the CDI. Most likely the lead from the CDI or the ground lead from the switch is unplugged. I don't have a wiring diagram handy but it will be obvious if you look at one. I do recall the ground lead from the ignition switch is a separate single wire that plugs to the Suzuki standard black with white stripe ground circuit.
Just looked at my manual. The wire from the CDI that grounds the ignition is B/Y. Sounds like the ignition switch lost it's ground through the B/W wire, as you said, or the contacts in the switch are bad.
2old2Bbold is online now   Reply With Quote
Old 03-08-2013, 03:46 PM   #14972
Stretch67
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,953
The key switches on older DR's do have a history of wearing out internally.
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 is offline   Reply With Quote
Old 03-08-2013, 04:06 PM   #14973
mustangwagz
mustangwagz's Avatar
Oddometer: 247
Originally Posted by Wadester View Post
I'd go for a set - especially if the "per unit" price keeps dropping. This deal is $102/ea.
Is that shipped? Id say get a few of them, and stick em on ebay, and if your feeling curious...make a set an auction and see how much they end up selling for? lol
-WagZ-
'93 DR350S
My attempt to roundup Local Riders..
https://www.facebook.com/dualsportridingwesternpa
mustangwagz is offline   Reply With Quote
Old 03-08-2013, 07:53 PM   #14974
crowbot
Oddometer: 18
I Need a little advice on finding some parts. I'm in the market for some new fork seals on a 94 dr350 se, it has the original street forks on it. The problem is all I can find are dirt model fork seals. Bike bandit had some listed for an se but upon receiving the package it lists 90-99 s models and 97-99 se models. This leads me to believe they are wrong for my bike. Anybody know where I can find the correct ones?
crowbot is offline   Reply With Quote
Old 03-08-2013, 10:24 PM   #14975
SoPaRider
Location: South Central PA/Michaux State Forest/Lincoln Hwy.
Oddometer: 300
crowbot
I'm betting they will fit your bike, call BikeBandit and ask to be sure, the later year ('98/'99) "S" model forks changed but the seals may still be the same as the 1990 thru 1997's.
Jeff (SoPaRider)
'96 DR350/441SET
P.M. me for copies of my 15 Michaux State Forest Dual Sport Routes and check the Trip Planning/Tent Space Sign-Up Thread dated 8-22-11 for more info.
SoPaRider is offline   Reply With Quote
Old 03-09-2013, 01:47 AM   #14976
tntmo
Oddometer: 532
For frame guards....has anyone ever thought to use Kydex? A buddy of mine has been making gun holsters out of it and it's easy to work with. Just a suggestion.
Buncha dirt bikes with license plates.
tntmo is offline   Reply With Quote
Old 03-09-2013, 02:09 AM   #14977
mustangwagz
Oddometer: 247
have to read what its about? never heard of the stuf
-WagZ-
'93 DR350S
Old 03-09-2013, 08:52 AM   #14978
RuggedExposure
Now with more rugged
RuggedExposure's Avatar
Oddometer: 1,247
Does anyone have a gasket kit for sale or recommend where to get one for the DR?
Despite all the fun I'm having with my Husky, I still have this retarded horse (dr350) staring at me and I want it running again.
The fear and dread of you will fall on all the beasts of the earth
RE Fotowerks
Border Road 100 Border Road Rally Raid
'13 Husky Terra 650, '08 Kawasaki Meanstreak 1600, '95 DR350S
RuggedExposure is offline   Reply With Quote
Old 03-09-2013, 08:59 AM   #14979
Spad
Spad's Avatar
Oddometer: 109
My local dealer got me a gasket kit when I took apart the engine for my DR350SE, but it turned out it was for the DR350. They're not the same - the alternator side gasket is different, to allow for the starter, and there's an extra o-ring for the kickstarter that you don't much need. Everything else was OK. The individual gasket was available.
The kit wasn't Suzuki's - I can find out where it came from, but it didn't sound like it was hard for them to get for me.
I have a spare alternator-side case gasket and kickstarter o-ring for a DR350 if it's any use to you...
- Spad
___________
06 Wee Strom
82 CM450E
99 DR350SE
Spad is offline   Reply With Quote
Old 03-09-2013, 09:06 AM   #14980
RandyM
Less talk, More ride
RandyM's Avatar
Oddometer: 917
I think they all take the same seals including the 98-99 models with cartrige forks. Check the part numbers on Ron ayers or some other OEM parts site to be sure.
Also Racetech carries all the seals and bushings. FYI the copper crush washer that seals the bolt in the bottom of the forks is a special size on the 99 cartrige forks and I had to grind down the outside diameter of an aluminum washer for mine. So I would order new washers from Suzuki if racetech does not have them.
-Ride Safe-
RandyM
RandyM is offline   Reply With Quote
Old 03-09-2013, 09:07 AM   #14981
RuggedExposure
Oddometer: 1,247
- Spad
Thanks, I should have specified my situation better.
I took the top end apart and need the gaskets for the jug, head, etc.
I guess you would call it a 'top end' gasket set.
RE Fotowerks
Old 03-09-2013, 10:17 AM   #14982
RandyM
RandyM's Avatar
Oddometer: 917
I had to replace a destroyed lower chain guide on my DR350 and I have another damaged one on my DR250. I bought both a Moose and Kientech chain guide so I'll post up a comparison of them.
Moose chain guide cost about $50 off ebay, has a sticker indicating it was made by "Freddete racing" on it, and based on packing labels fits a variety of motorcycles. There is a note in the instructions indicating that Suzukis may need additional spacers. The Moose CG mounts using 2 of the 3 holes on the swingharm. When I tried to install it, I found that the chain would rub on the aluminum plate with the included spacers. I could make it work but I would need to get different spacers and longer bolts to install it.
The Kientech CG cost $75. Jesse said he was sending me the adjustable one for the DR650 which also fits the DR350 and is a little different than the one pictured on his web site. It uses all 3 mounting holes on the swing arm and has 3 positions for the lower wear block to adjust the chain position. I used the middle position. It also has nylon side plates on the inside so if the chain rubs on the sides, it will rub nylon instead of aluminum. The Kientech chain guide bolted right up.
Pics:
Moose on top, Kientech on bottom
Kientech (left) Moose (right)
Kientech chain guide installed.
I did not put the Moose chain guide on my DR250 yet. It looks like I need to pick up some washers and put them between the wear blocks and alumumunum side plates to give a little more space for the chain and longer spacers and bolts to mount it to the swing arm.
The M6 x 20mm mounting bolts that came with the Kientech guide were a little short, they don't quite fill up the lock nut, and I think I'll replace them with 25mm long bolts just to be safe.
In summary, I think the Moose guide is adaquate for most of us and more durable than the stock plastic one, but the Kientech chain guide fits better and is even tougher.
-Ride Safe-
RandyM
Old 03-09-2013, 10:29 AM   #14983
RandyM
RandyM's Avatar
Oddometer: 917
You only need a gasket for the cylinder-case and head gasket. Cometic makes a kit with both gaskets. Then there is the exhaust seal. I got a no-name exhaust seal off ebay for about $3. It was ugly and looked low quality but it seems to work. I think there are also a few O-rings and copper washers on the oil lines.
-Ride Safe-
RandyM
Old 03-09-2013, 10:53 AM   #14984
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 2,102
Kydex is a thermoplastic sheet material. Heat it up in the oven, then form it.
"Kydex sheet is an extremely durable Acrylic-PVC alloy extruded in a range of colors, textures, and patterns. Kydex thickness ranges from .028 to .250 and full sheets are available in 48" x 96" and 48" x 120 ft rolls. Kydex can be thermoformed, post formed, brake formed and laminated."
http://www.interstateplastics.com/ky...for_sale_E.php
Used for many things - but not UV resistant or rated for unprotected outdoor use. It's hard, slick and springy, so it would be a great material for a frame guard - except for the sun eating it up. Might last long enough not to care.
Two roads diverged in a wood, and / I took the one less traveled by, and / now where the hell am I?
This isn't a "you're doing it wrong" topic. (Originally Posted by Human Ills, 7/1/14)
Wadester is online now   Reply With Quote
Old 03-09-2013, 11:23 AM   #14985
RuggedExposure
Oddometer: 1,247
Thanks. I'll look for it.
RE Fotowerks
Times are GMT -7.   It's 07:44 PM.
