Thread Tools Rating: Thread Rating: 218 votes, 4.96 average. Display Modes
Old 08-18-2013, 03:10 PM   #2131
doogiepooch
doogiepooch's Avatar
Oddometer: 960
Dualsport dad is right...but might I make another suggestion...
Unless the 87' has signifigant meaning, deceased loved ones ride etc, sell it and just buy you another Cherokee. They are plentiful and cheap and there is no reason to pour money into the 87, or buy another and swap stuff onto the 87. I have a 96 4cyl AX-5 and I wanted to put an AX-15 in it so I went down the same path. But after I got done I would have had more time and money and parts/spare vehicle than it would have cost just to buy a nicer 4.0 5 speed and sell the 96. If you are wanting to fix one up there are plenty out there that are better starting platforms than the 87.
Current: 13 Ninja 300 Past: 12 KLR650, 09 Ninja 250, 98 VFR, 88 KLR650, 88 XT350, 07 ZX6R
A nation of sheep will beget a government of wolves....Edward R. Murrow
www.nationalmssociety.org
doogiepooch is offline   Reply With Quote
Old 08-19-2013, 04:37 AM   #2132
RedRocker
Native Texican
RedRocker's Avatar
Oddometer: 5,691
Originally Posted by HardCase View Post
As far as I was concerned, the old TJ with the 3-speed auto was pretty good off-road although I tend to agree with Sally for heavy duty wheeling (which, as I've mentioned, I don't do a lot of), but mostly I liked it for drinking coffee while running errands around town!
As much as I like the auto off road, I hate it on road, that thing sucks on the highway, not enough gears. It would help if I lowered my gearing I'm sure.
My CJ7 came with a 5 speed, I put an injected 4.0 with a NP435 4 speed & then an NV4500 5 spd in it.
N. Texas
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance - that principle is contempt prior to investigation."
RedRocker is online now   Reply With Quote
Old 08-19-2013, 05:59 AM   #2133
HardCase
winter is coming
HardCase's Avatar
Oddometer: 10,727
Yeah, the old 3-speed auto had no overdrive. Mine had a tach and it seems like it revved pretty high, although I don't recall the range anymore, when running at highway speeds, thus the sucky mileage no doubt! I did find it was pretty good off-road, however, and was great for around-town.
Μολών λαβέ
Hard cases make bad law.
HardCase is online now   Reply With Quote
Old 08-19-2013, 09:14 AM   #2134
XpressCS
Must. Have. Lumens..
XpressCS's Avatar
Oddometer: 1,337
My grandpas 97 Sahara runs almost 3000rpm doing 65ish on the highway. What a stupid idea to put in a 3 speed auto with no overdrive on something that new. Most cars through that era had either 4 or 5 speed autos, and 5 speed manuals.
2015 Yamaha FJ-09
XpressCS is online now   Reply With Quote
Old 08-22-2013, 02:18 PM   #2135
redog1
KLR650-2009
redog1's Avatar
Oddometer: 1,805
Laugh My home grown Hybrid
built mostly for trails, no rock crawlin'. open diffs, only 4 inch lift with 33's
No, I don't know where that road goes, let's find out!
redog1
redog1 is offline   Reply With Quote
Old 08-23-2013, 12:23 PM   #2136
Jeffy
Hmm...
Jeffy's Avatar
Oddometer: 5,364
So is that a chopped down Willy PU or just a chopped body on another frame? What's it running for the drivetrain?
"I'm going to shift gears now.... This will involve man touching." - Jeremy Clarkson
Jeffy is offline   Reply With Quote
Old 08-24-2013, 07:18 AM   #2137
beemerkid
Do you ADV
Oddometer: 978
I loved having a manual in my jeep, but eventually I decided that for my engine swap I would run a 4L60E. With a little custom wiring, I have some of the advantages of a manual in that I can manually engage the lockup torque converter for compression braking. I do miss rowing gears however. If I want to start off on a steep hill, its a little easier but the skill of toe and heel starts on rocks is pretty fun to practice.
Originally Posted by Mr.Grumpy View Post
I swear to God that I will beat you senless with a Sanka can before I die.
beemerkid is online now   Reply With Quote
Old 08-24-2013, 11:57 AM   #2138
Jeffy
Hmm...
Jeffy's Avatar
Oddometer: 5,364
A lot of people are jumping on the 6L80e bandwagon now. I think that's the way I'd go if I was going an LS swap.
Old 08-24-2013, 05:09 PM   #2139
Range Motorsport
Junk collector
Range Motorsport's Avatar
Oddometer: 1,652
Until the new 9 speed auto transmissions become readily available.
2007 KTM Superduke
SNL Will Ferrell Yoga, google it.
www.adventuremine.com
www.upoverland.org
Range Motorsport is offline   Reply With Quote
Old 08-26-2013, 10:56 AM   #2140
beemerkid
Do you ADV
Oddometer: 978
CVT....
Old 08-26-2013, 12:37 PM   #2141
Jeffy
Hmm...
Jeffy's Avatar
Oddometer: 5,364
CVT....
That's crazy talk! It's like saying the Renex 4.0L is better then the High Outrput 4.0L.
Here's a 5.3L with a 6L80-E going into a YJ. The double OD allows you to gear it lower then you normally would while keeping the RPM's down on the highway. It's also shorter then a 4l60e/700R4 which helps in a SWB Jeep. You also have the ability to shift manually and have a gear spread similar to a manual.
Here's a JK with a similar 5.3L and 6L80-E
Old 08-26-2013, 03:36 PM   #2142
RedRocker
Native Texican
RedRocker's Avatar
Oddometer: 5,691
That would look swell in my LJ.
N. Texas
Old 08-26-2013, 03:46 PM   #2143
Jeffy
Hmm...
Jeffy's Avatar
Oddometer: 5,364
The shop is called MoTech. http://www.lswrangler.com/ Supposedly, they can make it 50-state, too. It looks really clean, like it belongs there.
Old 08-26-2013, 04:01 PM   #2144
RedRocker
Native Texican
RedRocker's Avatar
Oddometer: 5,691
Thanks, looks like they don't do TJ's.
N. Texas
Old 08-26-2013, 04:50 PM   #2145
Jeffy
Hmm...
Jeffy's Avatar
Oddometer: 5,364
Actually, I think they will do just about anything. CJ, YJ, TJ, JK... I remember hearing it in one of their videos. Best to call or email them. Both Jeeps I posted were done by them.
Jeffy screwed with this post 08-26-2013 at 04:59 PM
Thread Tools
Times are GMT -7.   It's 05:48 PM.
