Old 05-23-2007, 06:24 AM   #1
BMW4LIFE OP
Oddometer: 124
Pissed XR650L won't start
I need some help. I have a Honda XR650L and it won't start. I have pulled the plug and I don't have any spark. I tryed a new plug and nothing. I also took the tank and seat off and looked at all of the wires and everything looked good. All of the fuses are good also. Please let me know what I need to look at next. I am not much of a mechanic so please speak in layman terms! Thanks!!!
BMW4LIFE is offline   Reply With Quote
Old 05-23-2007, 07:11 AM   #2
B DIRT
B DIRT's Avatar
Location: your moms house startn a small fire in her panties
Oddometer: 1,376
Its either the CDI box which is common or one of the safety switches on the clutch or kickstand. You can by pass them to try to figure it out
2002 XR650R (plated), 2000 XR650R (trophy), 1990 Transalp, 1986 CR125R (flashback), 1977 CT90, 2009 Big Red MUV
B DIRT is offline   Reply With Quote
Old 05-23-2007, 07:14 AM   #3
GLOCKBOY
Oddometer: 1
I have your answer. The ECM is the problem. It is to the right of the battery as you face the left side of the bike. Take a hammer and tap it a few times, then try to start the bike. It should start right away. Now REPLACE THE ECM BEFORE IT STRANDS YOU!!! I read this in MCN a few months ago and then my bike would die and not start. I rapped the ECM a few times and it started right up. It has failed a few times since (my new ECM hasn't come in yet) two taps and it lives. There is a crack internally in the unit and contact is being lost.
Glockboy
GLOCKBOY is offline   Reply With Quote
Old 05-23-2007, 07:49 AM   #4
BMW4LIFE OP
Oddometer: 124
Thanks for the replys! I will give these a try tonight. How much should a new CDI cost?
Old 05-23-2007, 07:56 AM   #5
B DIRT
B DIRT's Avatar
Oddometer: 1,376
around 100 bucks from the dealer, and its the CDI thats right of the battery
Old 05-23-2007, 09:24 AM   #6
BMW4LIFE OP
Oddometer: 124
Anything else. I just talked to the Honda dealer and thay said thay never see a CDI go bad . I just need any help I can get. Thanks!
Old 05-23-2007, 09:51 AM   #7
XR650L_Dave
Oddometer: 3,758
XRL CDIs do fail, usually they become intermittent as they die. You'll be riding along, it dies, you wait 5 minutes, it starts right up.
The CDI failure is relatively rare, but with the number of XRLs out there, it adds up.
You can read reports of this here, on thumpertalk, on 4strokes, and on the yahoo XRLUG group.
If you want to bypass all safeties very quickly, you can remove the 2 wires that go to the clutch lever switch and connect both to ground.
If your XRL is older (before 94? help me out here...) its much more likely to be the CDI than if its much newer.
Dave
XR650L_Dave is offline   Reply With Quote
Old 05-23-2007, 09:58 AM   #8
BMW4LIFE OP
Oddometer: 124
Thanks Dave. My XRL is a 1998 with 4500mi. Thanks to all for the help.
Old 05-23-2007, 10:21 AM   #9
B DIRT
B DIRT's Avatar
Oddometer: 1,376
theyre really easy to get to if the dealers got one on the showroom floor
Old 05-24-2007, 05:48 AM   #10
BMW4LIFE OP
Oddometer: 124
How much power should I be getting to my coil?? I seem to be getting around 3 volts. That just seems really low.
Old 05-24-2007, 07:49 AM   #11
12bridn
I need throttle therapy
12bridn's Avatar
Oddometer: 4,603
I had an NX that wouldn't spark if the battery was low. Check the battery voltage before switching parts, you may be throwing money at a non-existent problem.
12bridn is offline   Reply With Quote
Old 05-24-2007, 09:30 AM   #12
BMW4LIFE OP
Oddometer: 124
Old 05-24-2007, 10:35 AM   #13
12bridn
12bridn's Avatar
Oddometer: 4,603
Is it running yet? What was the issue?
Old 05-24-2007, 10:53 AM   #14
BMW4LIFE OP
Oddometer: 124
No it's not running yet. I checked everything I can like the on/off switch, fuses, kickstand, and a few others. I just don't know where to go now. I have made a app with a dealer. I would be willing to try something else if anyone has any ideas.
Old 05-24-2007, 02:21 PM   #15
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,260
It's more than likely your CDI box - I had to change mine recently. Another thing to check is the kill switch. On mine, even on run, it initially would not start. Turns out the contacts were dirty.
I am betting CDI unit though. I think mine was about $100. Save yourself some money and order one. If it isn't that, take it to the dealer and either keep the CDI unit (for when it does go TU) or sell it here on ADV. Sure you'll lose a few $$ but the CDI is probably what the problem is if you have checked everything else.
Good luck and be sure to report back
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Times are GMT -7.   It's 02:39 PM.
