Old 05-25-2007, 06:34 PM   #1
clang OP
Not lost, Exploring!
clang's Avatar
Oddometer: 2,786
XR100 Problem
OK, so I bought an old XR100 to get in on the miniTT races that Geek is posting about. It had been sitting for about 18 months (started a couple of times a year), but fired right up after about eight kicks.
These bikes have a two position choke. When it is choked, it fires right up and runs well, when it warms up you can move it to the 1/2 choke position and it still idles well but it starts to stutter at high rpms. If you turn the choke off, it just dies, even when warm.
I've drained the gas and carb, and tried fresh gas, I have pulled the carb and cleaned the main jet, the needle jet, the slow jet and the pilot screw. I put everything back together, readjusted the carb, and get about the same results. It idles better with the choke in 1/2 position, but still boggs at high rmps and dies when you trun the choke off.
I'm going to get a rebuild kit tomorrow, is there anything else I should be looking at? Do these bikes have any quirks around carburetor adjustment I should be aware of???? Do I need a whole rebuild kit, or just new jets?
Sometimes it takes a whole tank full of fuel before you can think straight.
Ride for the soul!
'06 R12GS '92 R100GS '73 R75 /5 '01 F650GS '02 F650GS Dakar
clang screwed with this post 05-25-2007 at 06:53 PM
clang is offline   Reply With Quote
Old 05-25-2007, 07:36 PM   #2
experiment70
experiment70's Avatar
Oddometer: 274
Forgive me if you already know all this...
If this happens predominantly at idle, it might be an air screw problem. Where is your air screw set? If the bike likes choke, it's too lean. I'm pretty sure the XR100 has an air, not a fuel, screw (you can tell by where the screw is located - air box side = air screw, intake manifold side = fuel screw). Try turning the screw in, to richen the idle mix.
To tune it, once the bike is warm, I set the idle screw a little too high, and then mess with the air screw until I find the spot where the bikes idles the highest. Then I reset the idle screw to a more reasonable idle.
If this works, but the bike bogs when you whack the throttle open, try pulling the needle jet up one clip position.
There are some things which cannot be learned quickly, and time, which is all we have, must be paid heavily for their acquiring.
-Hemingway
experiment70 is offline   Reply With Quote
Old 05-26-2007, 12:03 AM   #3
clang OP
clang's Avatar
Oddometer: 2,786
I'm going to tinker some more tomorrow and see what happens
Ride for the soul!
Old 05-26-2007, 12:11 AM   #4
bykpimp
Live and let ride
bykpimp's Avatar
Oddometer: 1,408
Float bowl level, needle valve worn or a piece of debris in it??????????
bykpimp is offline   Reply With Quote
Old 05-26-2007, 07:32 AM   #5
Hunsta
Have guns will hunt
Hunsta's Avatar
Oddometer: 5,458
Ditto on the float bowl level. Check for needle valve wear on one side. Will be very slight but noticable.
Cheers
Craig
I REALLY AM A NICE GUY. JUST ASK ANYONE WHO HASN`T MET ME.
Hunsta is offline   Reply With Quote
Old 05-26-2007, 08:05 AM   #6
Eurobiker
Vintage Cat Herder
Eurobiker's Avatar
Oddometer: 5,975
I suspect this is the smaller version of the Kehin carb that's on my XR600. Try setting the pilot screw at 2.5 turns.
"If you don't know where you're going, any road will get you there." -Henry Foster
Eurobiker screwed with this post 05-26-2007 at 08:26 AM
Eurobiker is offline   Reply With Quote
Old 05-26-2007, 08:26 AM   #7
woody's wheel works
Built to Last
woody's wheel works's Avatar
Oddometer: 3,385
FYI...watch out for your rear wheel too!!!!
FYI,,,,as a fellow advrider,,,be forewarned to keep your rear spokes tight,,check them for looseness OFTEN,,,,these rear wheels have a propensity to come apart at an abnormally high rate,,,especially when ridden hard.
if you get tired of jerking around doing that,,,there is a solution,,,,basically changing from the x2 to a x3 lace pattern,,,that solves it
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 05-26-2007, 08:52 AM   #8
wickedsprint
Oddometer: 2,386
You might also have an air leak in your carb boot. That would also give those symptoms, especially if it was a hair lean on top to dtart, that extra air would toss it into not being able to run at all.
wickedsprint is offline   Reply With Quote
Old 05-26-2007, 01:44 PM   #9
clang OP
clang's Avatar
Oddometer: 2,786
Thanks everyone for the advice. Bike is now running well
A little fine tuning and we are good to go
Ride for the soul!
Old 05-26-2007, 05:58 PM   #10
KneeKicker
KneeKicker's Avatar
Oddometer: 2,627
I bought one last year with the same situation bike had basically set for 2 yrs the guy who had it strted every once in a great while just let it idle and shut it off. The jets didn't look bad but those little things are so small on the 100's that it doesn't take much i cleaned them and it would run fine but if it sat more than a week or so it ran like crap had to clean the jets and it was fine. I read some things on thumpertalk and decided to rejet the bike. It starts easyand runs better,I did add an FMF pipe and opened up the air box
KneeKicker is offline   Reply With Quote
Times are GMT -7.   It's 10:32 AM.
