05-26-2007, 05:57 AM
#1 |
adventures on asphalt
Oddometer: 708
What have you "Offered to the God of Speed" ?
DRDude's torched bike thread brought this to mind.
I re-discovered some things I have "offered" long ago while cleaning my garage. This was a stroked '81 CB750 crank. Oil starvation was a problem as the engine was running a wet sump. Back in the day I called it total loss lubrication. (ie total loss ignition). It still ran but just a little noisey!! After the engine was modified to a dry sump & $$$$$, problem went away !!! So to start this off, a tribute to Burt Munro. ![]() Mine ![]() ![]() ![]() In the last pic the valves kissed the pistons. The ignition ran off this side crank. Let's see what you got.... .
"I've had an excellent time so far... ... it could be all downhill from here." L Lovett KAdriver screwed with this post 05-26-2007 at 12:28 PM |
05-26-2007, 08:39 AM
#2 |
Oddometer: 1,642
![]() ![]() From a 2003 KTM 640 Adventure. She was running a leeetle lean down in Baja this past Spring. This is what it looked like after about 200 miles. Amazingly, the bike ran okay at over 3,000 rpm - just wouldn't idle! The full story here ----> http://www.advrider.com/forums/showt...highlight=sick |
05-26-2007, 11:07 AM
#3 |
Aspiring advrider
Oddometer: 3,345
Yikes.
5f? Is that like riding down a 90 degree cliff face into a lake of fire? I thought 4f was bad. Abdelhub "Assembled Spectator Scoring With Incriminating Photographic Evidence" or A.S.S.W.I.P.E. - Granparacer |
05-26-2007, 11:13 AM
#4 |
All Hail Seitan!!!
Oddometer: 5,561
When I finally clean out my garage, I'll shoot some pics. One of my favorites was my old business card holder. It was one of those custom offset connecting rods, and a nitro melted piston.
I worked for Orient Express and we had a neat collection of stuff. Twisted rods, melted pistons, a cylinder head that was perfect except there huge hole on the #3 spot where a piston went through it.
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966 |
05-26-2007, 06:44 PM
#5 |
Lazy ass
Oddometer: 1,586
![]() ![]() It was a 883/1200 conversion that didn't have enough piston/cylinder clearance. The sheet that came with the pistons said to use .0015" Well the machine shop did and it cold seized. |
05-26-2007, 07:03 PM
#6 |
Thumper Girl
Oddometer: 777
It ain't no lemon tree but...
to Burt. The God of Speed will have to wait until he grows up a bit.
Red hair & black leather, my favorite color scheme. '06 Ninja 650r '93 Honda XR100 '93 Honda 250XR '83 Kawasaki GPz 550 '71 Triumph Bonneville - Restored, but parts keep falling off! ![]() '73 Honda 350cl that I intend to ride around Lake Huron when we get her running well ************************************ Go out for adventure. Come home for love.![]() |
05-26-2007, 07:10 PM
#7 |
Spudly Adventurer
Oddometer: 3,254
I pulled this out of a early 90's Acura Integra some clown had run into some deep water. i don't know if it was a puddle, lake, or what. Motor had a good knocking noise in it down low. The counter weight on the crank was hitting the wrist pin boss on the underside of the piston pictured.
Needles to say the rod was shortened up just a bit. ![]() Mike
Cogswell Rides To Big Bend See my airhead project here Time Warp Vintage Motorcycle Club The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED. |
05-26-2007, 09:40 PM
#8 | |
Syndicated
Oddometer: 11,285
I don't have any pictures of the motor parts, axles, suspension pieces, bodywork, that were offered up while going way too fast. It was a while ago, and I never owned a camera. Prolly just as well that there's no evidence. Poolside screwed with this post 05-29-2007 at 01:15 AM |
05-28-2007, 08:58 PM
#9 |
The clutch basket out of my old RM125 that I toasted, I've learned skid plates on woods bikes are alot cheaper than new clutch baskets...
![]() ![]() Piston out of my 1974 CB360, oil got on the points and after one of the points cracked the timing was off and opps, hello hole in piston, but she did get me home on just on lung. ![]() Piston out of another CB360 motor I have. Turns out that you can not run a wasted spark igniton set-up on a CB360, stupid hurts... ![]() Head assy out of CB360 motor, on both the top and bottom cam guide there was an oil slot cut in, turns out 1970's lubracations systems don't do to well when you ride the bike at high RPMs all the time, I have a couple of these sitting around... ![]() ![]() Rear Vortex alum. sprocket off of my SV650, only 15 out of 45 teeth are still intact...
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." George Orwell 2007 Triumph Tiger 1050i 1978 Honda CT70 |
05-28-2007, 09:32 PM
#10 |
Woolf Barnato
Oddometer: 29,130
Ferrari 308
Over revved and dropped a couple valves. Not mine and I didn't do it. 113k miles on the engine. It belongs to a friend's dad. Luckily my friend is a Ferrari mechanic. I think he should put a Cadillac Northstar in there. More power and a better engine.
'Gonna get me a six pack...push people off the highway!' "they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood." "I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!" "Yeah, that guy sure is terrible at touching moms" |
07-12-2007, 09:36 AM
#11 |
Oddometer: 708
Found another piston.
This one smacked the head and kissed the valves* ![]() ![]() *not to be taken in a sexual way!!
"I've had an excellent time so far... ... it could be all downhill from here." L Lovett |
07-12-2007, 10:27 AM
#12 |
Oddometer: 10,901
I don't think I have any pictures but I had a CR500 pistion shatter to bits and hung its remains from my bedroom celing as decoration for years
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, DR250SE, XR650R, Cota 315R Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038 Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703 |
07-12-2007, 02:39 PM
#13 |
Talks to cats
Oddometer: 5,303
I don't know if you can blame speed, as the damage was due to over reving at modest speeds, but....
Bent pushrods: ![]() With matching bent valves ![]() OK, the valve doesn't look that bent, but when put in a valve grinder it had a very obvious wobble. The exhaust valves on both sides hit the pistons which survived the mishap. // marc marchyman screwed with this post 07-12-2007 at 08:18 PM |
07-12-2007, 02:57 PM
#14 |
Dirty_Sanchez
Oddometer: 2,096
All Hail KADriver!! Most honorable thread for those of us who covet not thy neighbor, possibly his good lady wife, but most definately all things involving gasoline and spark plugs.
Now I'm off to find a lemon tree to urinate upon. Dirty
No, really, the mustache means I love you. '09 KTM 250SXF for Sale, take a look: http://advrider.com/forums/showthrea...7#post21410167 |
07-12-2007, 06:31 PM
#15 |
Where does that go?
Oddometer: 1,996
This is the hot side of my Mitusbishi turbocharger. You should have seen the Spyhunteresque smoke screen coming out the back of the car...
"...falsehood is just as much the opposite of dialogue as is silence." - Albert Camus |
