Old 06-03-2007, 11:30 AM   #1
klm4755 OP
Oddometer: 575
KLR650 Front Sprocket swap step-by-step Walk thru
Enclosed is a step by step walk thru to swap out the KLR650 front (drive) sprocket (15 tooth) with a 16 tooth PBI “after-market” brand. Since 99% of the KLR travels will be on pavement during my daily commute, I am seeking a less vibration environment. One way to obtain this effect is to lower the RPM’s while in 5th gear. The larger sprocket will reduce RPM’s by 7% for the equivalent speed. Do not loosen rear wheel or mess with the chain...yet
Sprocket can be seen here:
http://happy-trail.com/ProductInfo.aspx?productid=MCY%2050-440XX
sprocket as delivered from happytrails.com
annotations on packaging
exploded view of configuration. Note represents a 2007 bike.
remove sprocket cover
The bolt to remove....27mm socket size.
pry back the retainer clip. Easy to bend with prying screw driver
like so
since a 27mm socket is very difficult/expensive a 1 and 1/16 size socket will fit.
Ok...the tricky part.
1. Place the bike on the side stand
2. Approach bike from right side and lean over placing your belly on the seat.
3. Right foot on rear brake...push
4. Right hand on front brake ...squeeze
5. Left foot on ground
6. Place socket on sprocket nut. Wrench handle pointing aft (toward rear). Left hand on wrench handle.
7. Lift left hand with all might to loosen nut. I used a 2 foot ˝ torque wrench as shown above
spin nut off of threaded drive shaft
like so...now jack up bike, remove rear axle and loosen chain
drive stud with sprocket on splines
backoff view
wiggle sprocket off splines. Out view side
inner view side
proper stack-up sequence
spline with sprocket off..inspect..no wear here. My bike has 2,000 miles logged
height comparison
top view OEM 15 tooth over 16 tooth new
new sprocket installed on spline
add nut retainer and thread nut
torque nut to 72 ft-lbs note units!
bend the retainer over the nut land area, use channel lock plyers
like so
replace sprocket cover, rear axle nut to 69 ft-lbs, and adjust the chain to spec.
cleaned up OEM sprocket
little to no wear after 2,000 miles
Observations and Review:
1. Easy to swapout
2. Loosening the sprocket nut was the most difficult part
3. Little to no sprocket wear after 2,000 miles
4. Love the way the bike “feels” now
5. Feels like the 6th gear the bike has been missing.
6. Don’t miss the low end torque ...yet. Worth the trade for me.
Keithm
-----------EDIT Below------
I have reviewed the install have included the option to shim and included a progressive torque nut from Arrowheadmotorsports.
progressive nut + 30mm socket for install
closeup of nut.
Note the crimped threads
sprocket shims
OEM sprocket “Bike side” shown
shim ID
shim OD
would fit here, if needed
sprocket gage at shaft location = .500 inch
PBI aftermarket sprocket gage at shaft location = .501 inch, matches
Will flip PBI sprocket and compare with OEM
try this, outside view
inside view
teeth align in this orientation. NO shims needed!
reinstalled with PBI markings inside
torque to 72 ft-lbs
I’ll still use the supplemental nut locking device, just for extra safety
fold over a tab
OEM fasteners replaced
The PBI sprocket is an exact match without shims. Face markings on the inside face.
klm4755 is offline   Reply With Quote
Old 06-03-2007, 11:32 AM   #2
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,239
Very well documented!!
Max Kool screwed with this post 06-03-2007 at 11:38 AM
Max Kool is offline   Reply With Quote
Old 06-03-2007, 11:37 AM   #3
shoco
Not So Gnarly Adventurer
shoco's Avatar
Oddometer: 467
Thumb Great!
Excellent write up. Thanks for taking the time to post this!
shoco is offline   Reply With Quote
Old 06-03-2007, 02:28 PM   #4
dgunther
rides ugly bikes
dgunther's Avatar
Oddometer: 226
Nice write-up.
I realize the need to make do with what is on-hand, but it is best not to use a torque wrench for breaking loose the sprocket nut. You might damage it or cause it to fall out of calibration, increasing the chance that you could over-torque something important in the future.
I use a cheap extendable 1/2" breaker bar I picked up at Harbor Freight or Northern Tool - you can try to mess up a whole bunch of those for less than the price of even the cheapest torque wrench!
dgunther is offline   Reply With Quote
Old 06-04-2007, 05:48 PM   #5
klr650tr
Oddometer: 17
how about 17teeth?
too much? anyone has it?
klr650tr is offline   Reply With Quote
Old 06-04-2007, 06:03 PM   #6
Kbetts
Kbetts's Avatar
Oddometer: 1,259
I didn't put the locking plate back on with the prevailing torq nut....
I thought the whole idea was not to need a locking plate for field swaping the CS.....
Do I need to take the PT nut back off and stick the locking plate behind it and bend it over?
Keith
We're all sheep gone astray
Originally Posted by TrashCan View Post
Hey, this is ADVrider, where facts are not real important.
Kbetts is offline   Reply With Quote
Old 06-04-2007, 06:15 PM   #7
colomtnbiker
wimpy old guy
Oddometer: 496
The locking plate is not needed with the prevailing nut. That's the joy, just use a crescent wrench or something similar and you don't have to go through so many steps to change sprockets. I can change sprockets (13 tooth) on two bikes ( mine & my wife's) in about 30 minutes when we are going offroading. The prevailing nut is awesome.
colomtnbiker is online now   Reply With Quote
Old 06-04-2007, 06:34 PM   #8
klm4755 OP
Oddometer: 575
The lock washer was just added for additional security. You know, I dress with a belt and suspenders.
Keithm
Old 06-13-2007, 06:46 PM   #9
East Coast
East Coast
East Coast's Avatar
Oddometer: 144
Appreciate the indepth explanation
Just tried to do the gear swap this evening - "prior to reading this article", and was not sucessfull due to inability to get the nut off. I'll try your method. Did you make any changes to your chain tension?
Thanks. Jt
Life's too short to spend it complaining!
East Coast is offline   Reply With Quote
Old 06-13-2007, 07:48 PM   #10
klm4755 OP
Oddometer: 575
Yes, the rear axle was moved forward just a tad to compensate for the slightly larger drive sprocket. No new chain needed though. Still very happy with the extra tooth.
Keithm
Old 06-14-2007, 07:41 PM   #11
East Coast
East Coast
East Coast's Avatar
Oddometer: 144
Question
Why did you remove the rear axle. Did you just loosen it to move it forward?
Old 06-20-2007, 05:49 PM   #12
klm4755 OP
Oddometer: 575
I removed the rear axle so I would not have to re-thread those chain adjusters. I have the fuji lockbolts.
Keith
Old 06-20-2007, 06:17 PM   #13
CA Stu
CA Stu's Avatar
Oddometer: 47,773
Question
Hey man, I'm pretty sure that those washers are for the early model bikes (pre-96) that used a different method of mounting the drive sprocket that was prone to chatter and wearing out the splines, not for your bike...
Do some homework and get back to me!
CA Stu
EDIT: from the FAQ:
Mid-1996: Changed valve cover, added bracket to hold cam chain bumper; changed crank to heavier unit; improved clutch basket with more clutch plates; changed countershaft sprocket retainer from slotted plate to large nut; changed 2nd and 3rd gear ratios. Kickstarter no longer fits with new clutch basket
On '95 and earlier models, two hex head screws hold a slotted retaining plate. Remove the screws, rotate the plate, and pull it off. Note that the retaining plate can get chewed up. Sagebrush Machine Shop makes a stronger replacement part, that gives full engagement of the splines rather than half.
I believe those washers were sold as part of a remedy for this problem.
And not to come off like a know it all, but even with zero maintenance, a stock OEM sprocket is good for at least 15k miles, the chain maybe 9 or 10k miles, and it's best to replace all 3 items (both sprockets and the chain) at the same time.
Preferably before they look like this:
http://youtu.be/C6cxNR9ML8k
CA Stu screwed with this post 06-20-2007 at 06:26 PM
CA Stu is offline   Reply With Quote
Old 06-20-2007, 10:55 PM   #14
CA Stu
CA Stu's Avatar
Oddometer: 47,773
Free advice is worth what you pay for it, but...
Um, what is the point of bending the washer over the prevailing torque nut?
It's silly.
A bent splined washer isn't going to magically flatten itself out and allow a sprocket that is on a splined shaft to fly off.
Are you now or have you ever been inside a garage?
CA Stu
PS here are my instructions
1) remove old sprocket
2) Install new sprocket
3) Go riding
And, FWIW, I've tried other tooth count front sprockets, and here is my conclusion;
The 15 is the best for every day riding.
If you are one of those morons that enjoys thrashing your KLR where it should never go, the 14t is really good (sweet spot in rpm and speed for tough offroad in 2nd gear), and the 16 is OK if you live in Florida and hardly ever use your clutch.
Old 06-20-2007, 11:23 PM   #15
wheatwhacker
It's raining here
wheatwhacker's Avatar
Oddometer: 2,979
Wow, what a great article...........
I did mine a year ago, went as follows.
Step 1. Loosen rear wheel and slacken chain a little.
Step 2. Take off 15 tooth sprocket.
Step 3. Install 16 tooth sprocket.
Step 4. Retighten chain, tighten rear wheel.
Step 4. Check for gas, start motor, ride.
Total time..............15 min
European bike sales and storage.
https://www.facebook.com/motofeirme
wheatwhacker is offline   Reply With Quote
Times are GMT -7.   It's 07:36 AM.
