Old 06-07-2007, 10:34 AM   #1
tahoeacr OP
tahoeacr's Avatar
Oddometer: 2,212
canisterectomy on 990FI
Can't seem to be able to fake out the pcm that the valve for the cannister is still hooked up. With ignition on, the pcm sends 12 volts and checks the circuit before the engine is even started. I've grounded the negitive side and the pcm still knows it's not plugged in. FI code is that the system is grounded(with the valve just unplugged). Cannot find a schematic on this in the service manuel.
tahoeacr is offline   Reply With Quote
Old 06-07-2007, 10:41 AM   #2
rubRsidedown
rubRsidedown's Avatar
Oddometer: 2,728
All in due time I'm sure......
Jeff B In Maine
05.5 KTM 950 Adventure Black, Mine
06 BMW F650GS Electric Orange, Hers
"We don't quit playing because we grow old, we grow old because we quit playing."
rubRsidedown is offline   Reply With Quote
Old 06-07-2007, 11:15 AM   #3
Nut Clutch
was Steve Lavigne
Nut Clutch's Avatar
Oddometer: 437
I am currently contemplating the same thing while I am doing the 1st service of my 990.
I am wondering what sorts of fueling and ignition changes the ECU makes when it opens the evap valve and creates a expected vacuum leak. Leaving the evap valve in place, while the intake manifold ports are plugged seems like a possible solution. The question for me remains whether the ECU will make fueling and ignition compensations when it opens a evap valve that is essentially useless.
Or, you could always put tape over the FI light.
Nut Clutch is online now   Reply With Quote
Old 06-07-2007, 11:28 AM   #4
tahoeacr OP
tahoeacr's Avatar
Oddometer: 2,212
Laugh
I doubt they make any changes. Now, the SAS is a large enough draw it has to make a diff. I've got a EIS system coming in the mail so I will soon have EGT,CHT, A/F, and about 10 other parameters available. I'm too lazy to resort to good old fahion plug reading on this bike.
Old 06-12-2007, 10:21 PM   #5
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,266
Do I understand from this that a successful 990FI canisterectomy has not been done yet? I just got a 990 and was browsing OC to see who had done it for some instructions. How much does that smog gear weigh anyway?
cyborg is offline   Reply With Quote
Old 06-13-2007, 12:43 AM   #6
tahoeacr OP
tahoeacr's Avatar
Oddometer: 2,212
You can take everything off like the 950's, just have to leave the valve(that controls the flow) plugged in to the harness. Bike is fine. No FI lights. No vacuum is hooked to the valve(or anything else). I can now top off both tanks to the top and have no problems. The pcm must look for the proper resistance with the valve hooked up.
Old 06-13-2007, 09:45 AM   #7
Northbound
Northbound's Avatar
Oddometer: 36
How does the bike run with all that taken off? Better I hope!? I'm getting ready to dig into mine. Do you have to remap the FI or anything? Also, do you know if the 15 minute idle trick really does reset the ECU? Thanks.
2007 990 Adventure
2007 300 XC-W
Northbound is offline   Reply With Quote
Old 06-13-2007, 10:05 AM   #8
tahoeacr OP
tahoeacr's Avatar
Oddometer: 2,212
I haven't taken off the SAS yet. That I think will effect the mapping. Don't know yet if the stock mapping has wide enough parameters to compensate for it. I have EGT,CHT and a wide band o-2 to install. Going to start on that today. I want a baseline stock before I remove the SAS. And also want to get FMF cans on it before the SAS comes off. Just disconnecting the charcoal filter I doubt anyone would notice a difference. Take a wide band to even tell IMO.
The map idle reset did well on my bike. I bought it at a dealer at 2800'+- and I live at 6500'. First thing I did was idle it for 10 minutes. Stay tuned, I'll let you know.
Old 06-13-2007, 11:24 AM   #9
cyborg
cyborg's Avatar
Oddometer: 5,266
Thanks for the info!
Old 06-13-2007, 12:03 PM   #10
cyborg
cyborg's Avatar
Oddometer: 5,266
Are those instruments you will install on the bike or shop equipment? If on-the-bike, who makes those?
Old 06-13-2007, 03:02 PM   #11
tahoeacr OP
tahoeacr's Avatar
Oddometer: 2,212
Here u go. Full deal. EIS will stay on the bike. The rest will be temp.
EIS will monitor Duel CHT & EGT, tach, oil temp & pressure, water temp, o-2, hour meter, flight timer , voltage, outside air temp, instantaneous fuel flow, total fuel remaining, time until empty, low fuel limit, max fuel flow, & I think that's it on that.
The Davtron measures fuel temperature & OAT. This will be temporary.
Also have a temp sensor mounted in the air box. These are just for data and to try and cool the airfuel charge.
The Innovate wide band will be for tuning only. Not to sure if I can replace a factory one with this. Adding it in could effect back pressure.
EIS: http://www.grtavionics.com/model_2002.htm
tahoeacr screwed with this post 01-21-2008 at 10:05 AM
Old 06-13-2007, 03:04 PM   #12
tahoeacr OP
tahoeacr's Avatar
Oddometer: 2,212
another pic
Old 06-13-2007, 03:05 PM   #13
tahoeacr OP
tahoeacr's Avatar
Oddometer: 2,212
A little large for the dash, but oh well!
Old 06-13-2007, 04:50 PM   #14
cyborg
cyborg's Avatar
Oddometer: 5,266
EGT, CHT and so on are far more common terms and displays in airplane cockpits. Are those usually airplane vendors? Of course an engine is an engine, so it should all work fine.
You will have I'm sure the most instrumented 990 ever!
Old 06-13-2007, 04:59 PM   #15
cyborg
cyborg's Avatar
Oddometer: 5,266
Maybe slap an Ohmmeter on the valve coil and read the resistance. Then a small resistor can take it's place? It can't be super-tricky if there's just 2 wires to the relay unless it's a CANbus link, then that's a whole 'nother can of worms, with ID codes etc... I haven't taken the bike apart yet, only had my 990S 3 days!
Times are GMT -7.   It's 11:41 PM.
