Old 02-13-2012, 04:06 AM   #166
Jeco46
Breastly Adventurer
Oddometer: 92
Sounds like mine when the fuel pick up filter in the tank was very clogged.
990 Adventure
350 XCF W
RMX 250
Jeco46 is offline   Reply With Quote
Old 06-20-2013, 05:37 PM   #167
renogeorge
Oddometer: 1,123
i am confused on the resistors. Is there 1 resistor between the 2 wires to the SAS unit? And 1, between the 2 wires to the canister pump? I am still getting an FI light wire this way. 2007 990.
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 06-20-2013, 10:37 PM   #168
FastEddy760
Lil' Mexican on a 990s
FastEddy760's Avatar
Oddometer: 188
You Are Correct...
Its been several years, don't recall the setup. If you follow the steps, your good to go.
Where did you deviate?
Did you stuff the resistor into the plug to check its effectiveness? See the test photo near the front of the group.
I dont think the pump is still in the program. I think it was removed, er, 'fell off'. Again, its been six years.
To answer the first part of your question, there are two resistors, one for each circuit, so yes, one resistor at the front of the bike, one at the rear.
If you plug your stock parts back into the circuit does the light go off?
And I assume you are starting the bike, running the engine(?).
Please post your solution so others can learn, and include the year, model etc.
If you would like to discuss this in detail, I'll be at the gas station for about 7 minutes.
FastEddy760 is offline   Reply With Quote
Old 06-21-2013, 07:04 AM   #169
smitty141
smitty141's Avatar
Oddometer: 567
Any need to do this on my 2012 standard. I did it on my 08... I just wanting to remove the clutter making engine work a bit less difficult . I seen a post somewhere causing issues.. Anyone done this to there new bike??
America.. only place in the world you can get a free cell phone, draw a check for doing nothing, and still be 75 lbs. over weight.
2014 BMW R1200GS Adventure LC...2010 BMW F800GS..
2009 Yamaha WR250R...1999 YZ250
smitty141 is offline   Reply With Quote
Old 06-21-2013, 12:57 PM   #170
renogeorge
Oddometer: 1,123
Canisterectomy short cut??
First, thanks to all who contributed to this very informative thread. My main problem ended up being the fuel pump, which I had replaced while the tanks were off and I was doing the ectomies.
The procedure illustrated in the thread is top notch. Since I didn't have the plug for the resistor install, I just wired the resistor across each of the wire pairs feeding the stock plugs. So, the bike runs great. FI light is still on with it running for a few minutes. I guess I will try the 15 minute idle deal.
Another question, what about the 2 vacuum sensors which are part of the canister system? There is one on each side with an electrical connection and a tie into the vacuum line from the intake stack. I plugged all 4 vacuum taps. I left the vacuum sensors (what I am calling them) plugged in electrically. Obviously there is no vacuum line to them.
Thanks again!
2007 990 Adventure.
KTMs--300, 518, 990
Old 06-21-2013, 01:23 PM   #171
Bronco3738
Mike
Bronco3738's Avatar
Oddometer: 496
Thanks again!
2007 990 Adventure.
Not sure I entirely follow what you did. The sensors should be removed, that's what the resistors are taking the place if in the system. Remove the pump and place a resistor in its place. If you have access to one if the cables for using TuneECU you can turn off the system all together and I don't think you even need the resistors going this way. As someone above asked, you are getting the FI light after the bike is started?
2009 KTM 990
Honeymoon Ride Report
Crazy Europeans Tour Utah
Bronco3738 is offline   Reply With Quote
Old 06-21-2013, 03:06 PM   #172
renogeorge
Oddometer: 1,123
I am probably using the wrong names for the components.
1. The canister valve--in front of the air box. Removed this and installed resistor across the 2 feed wires.
2. The SAS valve--rear of air box. Removed this and installed resistor between feed wires to it.
3 and 4. What I am calling the vacuum sensors--1 on right side of air box and 1 on left. These have vacuum lines to them. I removed the vacuum lines and left these connected electrically.
I plugged the 4 vacuum taps of the intake stacks and capped the airbox outlet spigot at the rear of the air box cover.
How is it running?? Wierd!! It is hard to start and when it does it sounds like a plug is misfiring--won't idle on its own without throttle. No FI light at this stage. If I keep it running with throttle, it "cleans out" in 20-30 seconds. Then the FI light comes on. It blinks 6 single dashes followed by 7 quick dots. In this stage in is running smooth and idles on its own.
I did the 15 minute idle.
Almost makes me wish for my old 950 Super Moto.
KTMs--300, 518, 990
Old 06-21-2013, 05:34 PM   #173
renogeorge
Oddometer: 1,123
Dumb S**t
Well, color me stupid!!! On the 990s, the 2 small boxes on each side of the air box (attached to the frame) are NOT part of the emissions control system. These are "manifold air pressure sensors". I guess the ECU/computer/electronics need to talk to them!
So, when doing the canisterectomy don't mess with the vacuum lines to these sensors! It is ONLY the vacuum lines to the canister that are removed/plugged or tied together.
Finally figured this out by checking the "Error Code" section in the service manual. When you are having a problem with the "FI" light coming on, it would be a good idea to count the dots (first digit of the error code) and dashes (second digit of the error code). Seems like a very valuable diagnostic tool. Ain't learning the hard way a wonderful thing!
A famous MX'er/friend, Rich Thorwaldsen, once told me to "turn the page" when it came to racing the old bikes. Guess I turned it too soon trying to go from carbs to fuel injection. Oh well, no going back now....
KTMs--300, 518, 990
renogeorge screwed with this post 06-21-2013 at 06:26 PM
Old 06-21-2013, 06:06 PM   #174
Defaultgateway
Oddometer: 85
SAS and canister and pump removed, 2011 990
I just completed the de-smogging on a 2011 990.
You will be left with two connectors that need a single 22,000 ohm resistor to bridge the now empty connector terminals. Do this for each of the two connectors. I had terminals left over from another project, so I used these to solder to the resistor pig-tails, and used shrink tubing to cover the resistor and most of the pig-tails, then plugged the ends into the empty connectors, using di-electric grease, then wrapped the connector with rubber electrical tape, then used standard vinyl electrical tape over this, until I was satisfied water could not make it's way in at some later time. Then I ty-wrapped each to the frame, out of the way, especially keep any obstructions away from the moving throttle bits.
Another way would be to form the resistor ends as a "U" shape, carefully with a small hammer reduce the wire round cross-section to a flat section approximating the shape of the small spade terminal that would be required. (a fine bastard cut file to to clean up might be needed to make the inserted end have a light chamfer to aide insertion. ) Using solder, tinned the newly formed end, then add the heat shrink tubing. By the way, I used small diameter heat shrink, about 1/16 inch inside diameter before shrinking. You must keep the two ends from touching each other, this will be read by the A/D converter in the FI computer as a 0 voltage drop, and throw an error.
For the case when you need a female connector, (and you don't have one handy) rather than cut off the stock connector, just go back a few inches from the connector wire pair, carefully remove the insulation at the same spot along each wire, bridge your resistor across the now partially bare wires, add your shrink wrap, solder one leg of the resistor to one bare spot you just made, and the other resistor leg to the other wire bare spot, shrink the tubing, bend the resistor to hug the wire, and apply electrical tape, again so the wires/resistor pig tails cannot come into electrical contact with each other. Later, the connector can be used with the stock parts by removing the bridge resistor, if this was a new requirement.
There are four vacuum "taps" on the intake manifolds. Using a piece of tubing and tube clamps measure the tube to connect to the two taps that had their tubes removed, forming a gentle "S" shape, effectively connecting cyl. #1 to cyl. #2 taps, as shown in the article on "canisterectomy". The other two taps, with the short tubes to little black boxes, must remain with their connectors un-touched, DO NOT FUCK WITH THESE in any way, they are the MAP barometric sensors and without them the system is hosed big time. DO NOT Modify the connections to these parts. At this point, your will not get ANY FI warning lights or codes thrown when turning on the key if you did the mod correctly.
Now, referring to the previous post picture of the right tank, inside view.
Now, the #3 connectors are the actual tank vents. There are short tubes that remain in the frame, as is normal when we take the tanks off for service. These go back just like stock.
The #2 connector is to equalize the pressures in each tank, connecting the left and right air spaces together. This remains just like the stock situation. So again, no change here.
Now for item #3, these go inside the tank, and exit just under the tank fill cap. The purpose of these was to capture any fuel from overflow while the cap was open and send it to the canister.( and if the canister filled up, there was a tube to atmosphere). When the cap is closed, this line is closed off by the cap. Later, the solenoid valve would open and the engine vacuum would suck the fuel vapors in the canister into the engine to be burned. If the canister was full of fuel, then the engine ran way rich (and crappy), this could happen if you took a dirt nap....
Anyhoo,
#1 elbows on both sides are arranged to point more or less down, and use tubing to route next to the radiator and then down, such that knowing if I overfilled the tank, gas will flow out of one of these tubes onto the ground. The main idea here is that you very much do not want fuel to ever come near the hot front cyl. header pipe(or any hot part...). I would suggest you route enough tubing to each side to exit near the center of the bike, and have a straight shot to the ground.
I hope this helps.
Defaultgateway is offline   Reply With Quote
Old 06-21-2013, 07:53 PM   #175
Bronco3738
Mike
Bronco3738's Avatar
Oddometer: 496
So, when doing the canisterectomy don't mess with the vacuum lines to these sensors! It is ONLY the vacuum lines to the canister that are removed/plugged or tied together....
Glad to hear you figured it out. Sounds like you got a little over zealous removing parts.. MAP sensors are very important to the FI system. Now that those a are back into the system, you shouldn't have any more issues. At least it was something simple.
2009 KTM 990
Old 07-09-2014, 02:59 PM   #176
tkrwyo13
Oddometer: 55
Originally Posted by FastEddy760 View Post
Ok, here are the steps...
There are lots of questions about capping off the vacuum tubes with caps from Dormans Auto parts and what not. I noticed that the tubes off the throttle bodies were "T'd" into the canister, so I took one tube, and ran it to both throttle bodies. In this pic, you can see the tube doing an "S" to each throttle body. Its quality tube, and will fake any inspectors, at a casual glance as it looks stock, sorta, mostly, kinda stock.
So I was wondering if you could tell me more about the stock hose barb thingys... My bike had the canister removed and some hoses re-routed but not the full job done properly when I purchased it.. Additionally I noticed the bolt holes had been plugged with m6 flange bolts and not tied together like you have. Should the throttle bodies be tied together again? Also what is the ID of the hose you used. Thanks!!
tkrwyo13 is offline   Reply With Quote
Times are GMT -7.   It's 07:52 AM.
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
