Old 09-26-2007, 11:37 PM   #91
FastEddy760
Lil' Mexican on a 990s
FastEddy760's Avatar
Oddometer: 188
the canister end, installed...
FastEddy760 is offline   Reply With Quote
Old 09-26-2007, 11:40 PM   #92
FastEddy760
Oddometer: 188
Both plugs installed, key on, no warning lights for fuel injection.
YEAH!!!
Yes, that is in the AM for the clock reading.
Old 09-26-2007, 11:46 PM   #93
FastEddy760
Oddometer: 188
The completed install and road test....
Old 09-27-2007, 12:01 AM   #94
FastEddy760
Oddometer: 188
Comments and Advice...
The front block off plate took some time. As others have mentioned, remove the oil tank bolts so you can push it out of the way. Also a small hand, mine is not small enough, and a little box wrench. Other than that, you need to figure it out, but you *can* do it.
The wires are easy with resistors if you take your time.
Pulling the throttle bodies and all the plugs, just let the wires tell you where they want to go and you'll be fine. I recylced the factory tubing where ever I could avoiding capping off for vacuum. The exception was the cap included with the block off plates.
I also did the 15 minute idle trick. As you might guess, the cats are still in the pipes. Without the SAS no longer pumping air, the bike is cooler, starts easier, and it actually sounds better. A bit deeper growl. I also took the bike to 103 MPH (21" wheel setting) that afternoon in the beautiful San Deigo desert. What a machine.
Hope this helps those on the fence, and shares some details that were cloudy in my mind.
Happy trails,
FastEddy
FastEddy760 screwed with this post 09-27-2007 at 12:09 AM
Old 09-27-2007, 06:24 AM   #95
paochow
Bye bye desert
paochow's Avatar
Oddometer: 1,177
Nice job. I'm currently about halfway into mine right now as I'm awaiting shims from the dealer for the valve check.
But looks like I can finish up the canisterectomy. Your write up is great.
Thanks,
paochow
paochow is offline   Reply With Quote
Old 09-27-2007, 06:43 AM   #96
AlphaTera
990rider
AlphaTera's Avatar
Oddometer: 90
FastEddy, great writeup and pics. What did you do with the tank breather hoses? Where did you run them?
AlphaTera is offline   Reply With Quote
Old 09-29-2007, 11:38 AM   #97
FastEddy760
Oddometer: 188
Hi Alpha, Here are some removel pics, that I can talk about to hopefully shed some light....
Old 09-29-2007, 11:40 AM   #98
FastEddy760
Oddometer: 188
Vent Tubes Between Tanks...
First off, this tube remains totally stock, in the same U position connecting both sides....
Old 09-29-2007, 11:46 AM   #99
FastEddy760
Oddometer: 188
The next three pics show the throttle side tank, with the stock routing of the vent/crossover tubes. I left the tube in the plastic with the turn signal, to connect to the tank, and leaving the "pass through" that will connect tot he "other side". However the connection to the other side is where I recylced a "T" and put a shorty tank breather.
Old 09-29-2007, 11:46 AM   #100
FastEddy760
Oddometer: 188
...number 2 example...
Old 09-29-2007, 11:47 AM   #101
FastEddy760
Oddometer: 188
the last of three for the throttle side...
Old 09-29-2007, 11:52 AM   #102
FastEddy760
Oddometer: 188
Here we see again, the stock setup, as these pics are still "removal". However, when the cannister is removed, I used that pass through elbow to connect a tube on the inside plastic, to the clutch side tank. This is pretty much the stoc path, with the cannister removed (imagine the assembly application). Then that elbow, on the exposed side will have a tube run onder the gauge cluster, to a recycled "T" and again, the shorty tank breather like a MX bike.
Old 09-29-2007, 11:56 AM   #103
FastEddy760
Oddometer: 188
this orginal stock image shows the position of the elbow pointing to the rear of the bike. I turned to point up, allowing for a more natural trip for the tube going under the gauges, to the "T" and the shorty tank breather that will eventually sit on top of the "T".
The "T" is to connect both sides together so as to keep a very stock appearance. With the shorty tank vent, no one will know that I'm venting into the atmosphere.
Old 09-29-2007, 11:59 AM   #104
FastEddy760
Oddometer: 188
And the last of the "removal" for the clutch side tank, hopefully depicting (imaginary) the connection I made for the tank and the tube into the internal plastic of the "turn signal" section cover thingy. It also shows the external "elbow" point to the back of the bike, and as noted previously, I pointed it straight up to 12 o'clock.
Old 03-10-2008, 05:48 PM   #105
Rabid Dog
Rabid Dog's Avatar
Oddometer: 354
Hey FastEddy - Great write up on the "pollution solution". One question - When removing SAS and replacing the block-off plates, do you remove the reed valve behind the plate?
Rabid
2007 KTM 990 Adventure (Black)
Rabid Dog is offline   Reply With Quote
Times are GMT -7.   It's 10:42 PM.
