Old 08-30-2003, 01:35 PM   #1
MotoJim OP
MotoJim's Avatar
Oddometer: 223
Another KTM 950 EPC Fix
Attached you will see a screen capture of part of the KTM Repair manual which talks about how the epc works in 2nd & 3rd gears.
Instead of messing with the tubes running to the carbs a more simple solution is just unplugging the epc's and maybe sealing the female connection on the epc with silicone to keep it from the elements.
The front epc is found though the opening in the tank on the right side just above the oil tank along the frame. The rear epc is below the seat behind the airbox.
The last line of the section is the key data:
Note: If the epc valves are disconnected, this will not influence the other systems.
ciao,
JimR
MotoJim is offline   Reply With Quote
Old 08-30-2003, 06:32 PM   #2
vgstef
Oddometer: 197
any difference in power
Did you disconnect the wire ? Any difference in power in 2 and 3 third gear ?
Stephane
vgstef is offline   Reply With Quote
Old 08-30-2003, 07:12 PM   #3
MotoJim OP
MotoJim's Avatar
Oddometer: 223
Re: any difference in power
Said vgstef:
Stephane
I did disconnect the connectors for both epcs. I haven't ridden the bike yet because it's raining cats and dawgs right now. Maybe tomorrow.
I'll let you know.
Old 08-30-2003, 07:55 PM   #4
Gerg
Cupcake
Gerg's Avatar
Oddometer: 8,430
Im acronym impared...what's a EPC?
Greg
Gerg is offline   Reply With Quote
Old 08-30-2003, 08:19 PM   #5
MotoJim OP
MotoJim's Avatar
Oddometer: 223
Said Gerg:
Greg
I'm not sure what EPC stands for but it's basically a solenoid, an electronic device that opens and closes a valve, which limits the amount movement of the slide in each carburetor, based on the vacuum available. It reduces the amount of vacuum over the diaphram in each carb to keep the slide from opening up as fast.
Jim
Old 08-31-2003, 07:15 AM   #6
Renazco
Formerly AKA Boejangles
Renazco's Avatar
Oddometer: 4,742
Jim, did it stop raining yet? I'm curious to know if you noticed an improvement with the disconection..
Renazco is offline   Reply With Quote
Old 08-31-2003, 08:17 AM   #7
MotoJim OP
MotoJim's Avatar
Oddometer: 223
Said boejangles:
A Big No!
We've been in a severe drought around Kansas City and we have had two straight days of heavy rain. There's localized flooding with some roads closed.
They shut down I-35 south of Emporia, Kansas yesterday because water was forcing cars off the interstate.
Maybe tomorrow, but today I'm trying to keep my basement from flooding. Window wells are filling up and waters coming through the windows. Great fun!
WetMotoJim
Old 08-31-2003, 12:56 PM   #8
Renazco
Renazco's Avatar
Oddometer: 4,742
Put the 950 on the roof! Just kidding hope everything works out good for you guys.
Old 09-02-2003, 05:19 AM   #9
Goss
LC8 Adventurer
Goss's Avatar
Oddometer: 1,380
Thumb
Keep us updated on your EPC experiment Motojim. And stay dry!
Goss
2004 KTM 950 Adventure S
2007 Ducati 999S Parts Unlimited
2012 Ducati Multistrada 1200 Pikes Peak
Goss is offline   Reply With Quote
Old 09-02-2003, 03:49 PM   #10
human
Treehugger
Oddometer: 23
My dealer just unplugs them. He pointed out the plugs when I first picked the bike up and said disconnect them if you want, if not we'll do it at the first service.
human is offline   Reply With Quote
Old 09-03-2003, 05:35 AM   #11
Goss
LC8 Adventurer
Goss's Avatar
Oddometer: 1,380
But still the question is Human, can you tell the difference ? If not I see no reason to do it. I don't have enough miles on mine to try 2nd and 3rd gear full throttle fun yet so let me know.
Goss
Old 09-03-2003, 09:46 AM   #12
Maurizio
2 smoker
Maurizio's Avatar
Oddometer: 163
Well... You are driving me crazy with EPC (Electronic Power Control???)....
I have just been out in the parking lot, unplugged the two things, and I am about to put on my jacket, gloves and helmet and commute back home (70 km....).
Let's talk about the "kick in the pants" effect later in the evening (ahhh... time zones effect: good evening for me... good morning for you guys on the other side of the pool...... )
maurizio
'14 250 EXC E "Sparkling Orange"
'08 FLHCTUSE3 - '76 CB 750 F ss
sold: '03 950 adv s, '05 450 exc, '08 690 e
Maurizio is offline   Reply With Quote
Old 09-03-2003, 09:56 AM   #13
barbasma
100% CAROTONE
barbasma's Avatar
Oddometer: 1,821
SOMMER KTM give to me two little plastic plugs to put on the carburators and take off the tubes...
it's that the bypass for EPC?
x Maurizio
spiegamelo in italiano così capisco cosa hai fatto... grazie:):
la bestia è incredibile!!!!
"Dakar must be a race for few people, Dakar is a dream, the dream of the Rose Lake, if everybody finish it, the dream is over" Fabrizio Meoni
ciao Matteo
www.barbasma.smugmug.com
www.lc8.org
www.adventureschool.it
KTM 950 ADV S 2003 80.000 KM..... and gooooo...
barbasma is offline   Reply With Quote
Old 09-03-2003, 11:09 AM   #14
human
Treehugger
Oddometer: 23
Said Goss:
Yes! :):
Old 09-03-2003, 12:37 PM   #15
Maurizio
2 smoker
Maurizio's Avatar
Oddometer: 163
Here I am....
You can feel the difference, ohhh... you can feel it!
With the EPC disabled, the bike has a complete different feeling in low gears: it seems somewhat less responsive at low RPM, but it doesn't feel "strangled" in second and third gear at about 6000/7000 rpm (I can tell this as I have plugged the EPCs again, and it behaves in a different way...).
You know: twist the throttle on the stock beast in first gear and it power wheelies; shift first/second at about 6500/7000 rpm and it tries to wheelie... Open the throttle in second gear and it pushes and pushes, but seems to be too heavy or too long to wheelie...
Unplug the two EPC controllers, and it power wheelies in second gear: open the throttle (not so hard if you are not wearing a back protector equipped jacket) and the front wheel point to the sky! And it does the same shifting second/third...
I think it is a big no-no for off road use, anyway, as the bike wants to rev up, and the stock setup seems to be more easy to control, IMHO, as it is much more "softer".
You can call it a "show" mode: unplug the EPCs (or close the carburetors hoses... ) and you will be the wheelie king in town...
Per Matteo: ti telefono domani mattina... piu' facile spiegare le cose a voce... eheheh
maurizio
Times are GMT -7.   It's 05:11 AM.
