Old 06-07-2007, 08:38 PM   #1
StephenB OP
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
Remote final drive vent
I never liked the oilmist around the filler plug and the inspection plug of my rear drive. As we all know, the filler plug works as a vent as well and I never knew whether after heavy rain I got water in there or not without draining the oil. I already had the inspection plug weld shut when Bruno worked on my rear drive, and I had my local machinist have a looksee at the filler plug. We bounced off a couple of ideas how to best get a M10x1 thread in there in order to use a stock banjo bolt used on the brake master cylinder (a modification that I had seen somewhere else before). Well, the modification did not go as well as we thought, so Richard just fabricated a new plug, a stainless female-female adapter M18x1.5 / M10x1.0:
Click pictures for higher resolution ...
Now, that worked out nicely and made a professional vent that leads under the seat. So no more oil mist outside or water in the final drive anymore:
Hope that helps someone else as well.
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Old 06-07-2007, 08:46 PM   #2
walkingbear
walkingbear's Avatar
Oddometer: 3,603
make another one?
Will your machinist make another one?
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 06-08-2007, 12:11 AM   #3
nowhereman
I'm lost -don't follow me
nowhereman's Avatar
Oddometer: 386
or two?
Cause I'd buy one too!
1990 R100GSPD
1964 LI125S with a 240 MRB kit
nowhereman is offline   Reply With Quote
Old 06-08-2007, 12:58 AM   #4
Joerg
Joerg's Avatar
Oddometer: 1,356
Just for the record, here's a similar device from Daniel Dicke's website. He used an adapter that was originally used to vent house radiators (!). Reportedly, these have the necessary thread M18x1.5, and you just need to cut the inner thread M10x1 - which in turn fits to standard hydraulic tubing.
- Joerg
1990 BMW R80GS and K100LT * Lausanne, Switzerland
My Motorcycle WebPages - LED voltage monitor (aka charge light)
Joerg is offline   Reply With Quote
Old 06-08-2007, 04:33 AM   #5
StephenB OP
StephenB's Avatar
Oddometer: 2,044
Joerg,
Daniel's idea inspired me, but we hardly get any metric stuff here in Northamerica. Especially fittings or adpaters like that. The one "we-have-it-all" shop quoted me four (4) pieces of hardware to make up that adapter: metric-to-imperial-to-imperial-to-metric sort of thing.
So we have to resort to other ways of getting there.
walkingbear, nowhereman, I will talk to Rich, but I know from earlier cases that he is not interested in doing even smaller lots of say 5 or 10, he is the local "custom-design one-off" sort of shop!
Stephen
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
Old 06-08-2007, 05:13 AM   #6
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
very cool.
thx Stephen for sharing.
datchew is offline   Reply With Quote
Times are GMT -7.   It's 09:09 AM.
