Old 08-24-2013, 04:21 AM   #3691
Crazy_Tim
Crazy_Tim's Avatar
Oddometer: 57
Originally Posted by Mav View Post
Looks great in white - is that a headlight and mudguard set up from an XChallenge?
'xactly. It's an xHP2 now.
Crazy_Tim is offline   Reply With Quote
Old 08-24-2013, 04:38 AM   #3692
Mav
Something witty...
Mav's Avatar
Oddometer: 3,713
Originally Posted by farcall View Post
From my recent 7-day 4000km ride to Rudall River National Park in Western Australia. Extremely remote. Search in Google Earth if you want to see how remote. If you do, those red lines are desert sand dune ridges.
Hamersley Ranges in the background. Billions of dollars of iron ore are in those ranges which is the prime feedstock for China's massive infrastructure boom over the last decade.
That looks epic
And you did that trip on your own?
Mav
All the gear.. no idea!
Mav is offline   Reply With Quote
Old 08-24-2013, 05:31 AM   #3693
farcall
Bike-a-holic
farcall's Avatar
Oddometer: 1,860
That looks epic
The pic from the sandy sections... there were only 2 of us. We were on our own. We each had a satellite phone and spot tracker. My ride buddy was probably 15 mins ahead. Usual practice is to give plenty of separation and each can travel at their own speed. Then stop every 30 mins to catch up. That ride leg was 88kms long which took 3 hours non-stop. I reckon 1/3 of it was shitty deep soft sand, 1/3 soft sand and the last 1/3 just sand .
01 Africa Twin RD07A (x2)
05 HP2
11 K1600GTL
farcall is offline   Reply With Quote
Old 08-24-2013, 09:50 AM   #3694
Mav
Something witty...
Mav's Avatar
Oddometer: 3,713
Awesome - would love to be able to ride in those kinds of conditions.
Mav
Old 08-29-2013, 05:32 AM   #3695
michaelmy
Oddometer: 28
I want to see my own HP2 - still waiting on the suspension to finish the new front end... it's taking forever But will be great when it gets here!
Mav
I have got my HP2 back from from Moly
He has built it with the BMW wheel & front disc caliper
He has also retained all the stock headlight & fender brackets
I have only tried it on the road, but the suspension is way better
MichaelmyLondon & Somerset
10 990 ADV R,08 SE, 06 HP2, 12 Freeride +67 Honda Monkey (since new!)
Supporting Big Bike Rally Challenge at www.rallymoto.co.uk
& Long Distance trials www.themotorcyclingclub.org.uk & http://www.eventdirectory.org.uk/
michaelmy is offline   Reply With Quote
Old 08-30-2013, 05:00 PM   #3696
Mav
Something witty...
Mav's Avatar
Oddometer: 3,713
Originally Posted by michaelmy View Post
Mav
Just got mine back too - new bottom yoke from Moly (top one didn't work out :blast ) WP forks, complete with preload adjustability, retaining original wheel and calliper. I plan on changing the disc on the SM rim to the enduro size so that I can still use that too.
I've also got a Wilburs on the back and a renazco seat, and a new plate: HP02 MAV.
So bike is suitably pimped - just trying to decide if I can justify a set of Woody's wheels
Mav
Old 09-01-2013, 03:01 PM   #3697
Louisdut
Louisdut's Avatar
Oddometer: 638
Mav
Nice one lads
Louis
Louisdut is offline   Reply With Quote
Old 09-01-2013, 04:10 PM   #3698
MoxNix
Stuttgart Germany
MoxNix's Avatar
Oddometer: 1,166
I'm heading back to the states and downsizing to one bike (at least that's what I tell my wife).
To make the HP2 a little more travel worthy I'm planning on installing ZegaPros with 3ltr. cannisters mounted on the front of the panniers.
Has anyone here done this? Do the cannisters hit the back of your boots?
I'll try to pick up a Marcus tank prior to leaving der Fatherland but it may not happen and TT no longer lists their long distance tank on the website so I'm a little limited on choices right now.
Thanks,
Chris
Hope is not a course of action.
MoxNix is offline   Reply With Quote
Old 09-02-2013, 01:00 AM   #3699
Mav
Something witty...
Mav's Avatar
Oddometer: 3,713
Thanks,
Chris
Maybe not your feet... But certainly the passengers feet if you ever ride 2up - why not put them on the back?
Mav
Old 09-02-2013, 02:28 AM   #3700
Mav
Something witty...
Mav's Avatar
Oddometer: 3,713
Originally Posted by Louisdut View Post
Nice one lads
Louis
Cheers Louis
Mav
Old 09-02-2013, 02:29 AM   #3701
Mav
Something witty...
Mav's Avatar
Oddometer: 3,713
Anyone know if the SM rim can take the brake disc from the enduro rim? With the new forks I no longer have the option to move the caliper... am hoping I can simply put the smaller enduro disc on the SM rim...
Mav
Old 09-02-2013, 03:15 AM   #3702
GSMarc
GSMarc's Avatar
Oddometer: 1,006
I don't imagine why it could be a problem to change the diameter of the disk.
The only thing to check is the thickness of the disk :
320 mm disk ==> 5 mm 34 11 7 670 939
305 mm disk ==> 4,5mm 34 11 7 676 550
GSMarc from BELGIUM
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2005 HP2E
2005 HP2E SM Prototype
GSMarc is offline   Reply With Quote
Old 09-02-2013, 03:22 AM   #3703
Mav
Something witty...
Mav's Avatar
Oddometer: 3,713
So the mount is the same? That is - is it a straight swap between the 2 discs?
And what are the implications of being 0.5mm thinner?
Mav
Old 09-02-2013, 04:10 AM   #3704
GSMarc
GSMarc's Avatar
Oddometer: 1,006
both hubs (enduro & SM) are ref : AS7G03-Y33
0.5mm thicker and 15mm larger for SM are due for heating realease and major brake force on road I imagine.
I think you can go and change your disk
GSMarc from BELGIUM
2008 HP2/MM ABS
2005 HP2E
Old 09-02-2013, 04:45 AM   #3705
Mav
Something witty...
Mav's Avatar
Oddometer: 3,713
Thanks chap
Mav
Times are GMT -7.   It's 08:11 AM.
