Old 09-02-2013, 08:01 AM   #3706
MoxNix
Stuttgart Germany
MoxNix's Avatar
Oddometer: 1,166
Originally Posted by Mav View Post
Maybe not your feet... But certainly the passengers feet if you ever ride 2up - why not put them on the back?
I want to bring the weight (what little there is) lower and forward- that and I may do front and rear.
I just want to make sure before I drill new Zegas.
Looking at Harleys for two-up....
Thanks Mav
Hope is not a course of action.
MoxNix is offline   Reply With Quote
Old 09-02-2013, 09:56 AM   #3707
Chuck U Farley
Mr 2 u
Chuck U Farley's Avatar
Oddometer: 61
Anyone know if the SM rim can take the brake disc from the enduro rim? With the new forks I no longer have the option to move the caliper... am hoping I can simply put the smaller enduro disc on the SM rim...
Mav, I ran the SM disc on my enduro wheel, so I'm sure it'll work the other way around.
go BIG or go home
Chuck U Farley is offline   Reply With Quote
Old 09-02-2013, 11:03 AM   #3708
MoxNix
Stuttgart Germany
MoxNix's Avatar
Oddometer: 1,166
I'm deployed to Afghanistan with not enough sleep but bike surfing takes precedence...
I am an HP2 noob and especially with the SM wheels please bear with the questions.
The rear wheel just bolts on- what torque?
Are paddock stands (PitBull or BMW) preferred or is a lift required/preferred? What about for the front?
For the front, the caliper needs to be moved to accommodate the different sized rotors- enduro being smaller?
Can I run (based on the current discussion) the road rotor on both sets of wheels avoiding moving the caliper from inboard and outboard? (I have an extra front road rim w/rotor)
On HP2Enduro.com, someone mentioned that the front bolt is aluminum but there is a replacement bolt that is steel. Is the bolt part #11 in this diagram?
Can't wait to get back to the states and start riding this thing!
MoxNix screwed with this post 09-02-2013 at 11:08 AM
Old 09-02-2013, 12:20 PM   #3709
Mav
Something witty...
Mav's Avatar
Oddometer: 3,713
The rear wheel just bolts on- what torque?60nm
Are paddock stands (PitBull or BMW) preferred or is a lift required/preferred? What about for the front?I use a paddock stand for the rear wheel and jack under the sump to lift the front wheel. That also give you a chance to check the steering head bearings
For the front, the caliper needs to be moved to accommodate the different sized rotors- enduro being smaller? Yep, the enduro disc is smaller
Can I run (based on the current discussion) the road rotor on both sets of wheels avoiding moving the caliper from inboard and outboard? (I have an extra front road rim w/rotor)It would seem so. Only, with the larger disc, fitting the SM rim means removing the caliper and brake pads to get the caliper over the disc. I'm hoping the with the smaller disc, this should be easier...
On HP2Enduro.com, someone mentioned that the front bolt is aluminum but there is a replacement bolt that is steel. Is the bolt part #11 in this diagram?Yep, it is bolt number 11 - you go from needing a 19mm spanner to a decent size allen key, which I think is the same as the sump...
Hope that helps - stay safe over there
Mav
All the gear.. no idea!
Mav is offline   Reply With Quote
Old 09-02-2013, 12:25 PM   #3710
MoxNix
Stuttgart Germany
MoxNix's Avatar
Oddometer: 1,166
Thanks a ton Mav.
Old 09-02-2013, 12:31 PM   #3711
Mav
Something witty...
Mav's Avatar
Oddometer: 3,713
Thanks Mav
Sounds like a good plan
I ended up using MSR fuel cans - that way I the fuel could be used for the bike or the stove
Queue gratuitous pic of my bike
Cheers - will get a new one ordered tonight
Mav
Old 09-03-2013, 06:51 AM   #3712
Visian
Look out!
Visian's Avatar
Oddometer: 1,667
Thanks a ton Mav.
fwiw, Bolt #11, the front axle keeper, is the same as on an F800GS.
'67 Trail 90 || '86 R80 G/SPD+ || '97 F650ST || '00 1150 GS || '06 HP2e
Visian is offline   Reply With Quote
Old 09-10-2013, 06:04 AM   #3713
Mav
Something witty...
Mav's Avatar
Oddometer: 3,713
A couple from the ride home from work last night:
Not bad for an iPhone...
Mav
Old 09-17-2013, 09:52 AM   #3714
OK Lucinda
Oddometer: 305
A magical 7 hour canoe ride with a friend on an 800GS on the Rio Napo in Ecuadorian Amazon three days ago. The tie-down points were near vertical at the rear of the bike through drainage holes, not the best as the river was a bit wild for the last two hours approaching Misahualli. A fantastic and remote area.
OK Lucinda is offline   Reply With Quote
Old 09-17-2013, 10:44 AM   #3715
Mav
Something witty...
Mav's Avatar
Oddometer: 3,713
Fantastic!
Now where are the rest of the pics?!
Mav
Old 09-18-2013, 09:55 AM   #3716
OK Lucinda
Oddometer: 305
Like this?
Old 09-18-2013, 11:35 AM   #3717
philgunn
BMW R80gs offroad + HP2
Oddometer: 243
not quite a Canoe but three HP2,s on the way to the Hard Alp Tour Recently
https://www.facebook.com/philip.gunn.587
Gunner
Eating Cheese , Drinking wine , catching some rays
philgunn is offline   Reply With Quote
Old 09-19-2013, 01:58 PM   #3718
Louisdut
Louisdut's Avatar
Oddometer: 638
Hp2 in Albania
Louis
Louisdut is offline   Reply With Quote
Old 09-19-2013, 02:13 PM   #3719
Mav
Something witty...
Mav's Avatar
Oddometer: 3,713
So how many countries is that on the HP2 now?
Mav
Old 09-20-2013, 02:25 PM   #3720
OK Lucinda
Oddometer: 305
Both Adam Shani and Hans Eichmann are above 60 countries each I think on their HP2 rtw's. Adam's is complete (but it sounds like he might do it again) and Hans is still going but mostly done. Both of them did brilliant routes, including lapping both Africa and SA. I just started 11 months ago. Not sure about other HP2's out there right now doing this.
Times are GMT -7.   It's 06:58 AM.
