Old 11-18-2013, 09:36 PM   #3796
mike cummins
OUTBACK RIDER
mike cummins's Avatar
Oddometer: 724
panniers
I have used giant loop and they are awesome but just not in the wet. I understand a lot of guys say they are great and they are but wp they are not. So I am going to install some zega pro's and see how they go. All my rides are long and in the outback and next year I see myself continuing on my trip from bali up to thailand etc. Also im going to re install my 17/21 wheels as I think the 18 seems to increase my 1st gear . Maybe its all in my head :)
mike cummins is offline   Reply With Quote
Old 11-18-2013, 09:58 PM   #3797
Some Dude
what attitude problem???
Some Dude's Avatar
Oddometer: 4,758
The 18" is a taller tire, albeit not by much. The final drive can be re-geared lower to a 3.05 final ratio I believe as I think stock is 2.92
Just some dude on the internet,..
Some Dude is offline   Reply With Quote
Old 11-18-2013, 10:16 PM   #3798
farcall
Bike-a-holic
farcall's Avatar
Oddometer: 1,903
Waterproof soft panniers... http://www.adventure-spec.com/defaul...-panniers.html
I can see a set of these in my future...
01 Africa Twin RD07A (x2)
05 HP2
11 K1600GTL
farcall is offline   Reply With Quote
Old 11-18-2013, 10:18 PM   #3799
GSMarc
GSMarc's Avatar
Oddometer: 1,132
User Manual says this
Gear ratios
Gearbox transmission ratios 1.824 (31:17 teeth), Primary transmission ratio
2.277 (41:18 teeth), 1st gear
1.583 (38:24 teeth), 2nd gear
1.259 (34:27 teeth), 3rd gear
1.033 (31:30 teeth), 4th gear
0.903 (28:31 teeth), 5th gear
0.805 (29:36 teeth), 6th gear
Final drive
Rear wheel drive, type Shaft drive with bevel gears
Final drive gear ratio 2.82 : 1
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2005 HP2E SM Prototype
GSMarc is offline   Reply With Quote
Old 11-19-2013, 02:17 AM   #3800
OK Lucinda
Oddometer: 493
Originally Posted by BiG DoM View Post
Epic pictures OK L .
The only thing I can think is that there is a wire that has chaffed through (the clutch switch wire) and is making intermittent contact. These breakages often happen near the steering head and handlebars where there is alot of regular movement and the wires tend to be cable tied too tight. The clutch switch is prone to getting dirt etc stuck in it and is a very finicky little switch - have had mine out a few times to clean and adjust. If I recall it has a small spade connector - you should be able to get to it and disconnect and just bridge the contacts. I have done this permanently on my Husky 610. Of course if you bridge it and it still does it seems to point to broken wire further down the line.
Thank you for this. This looks like the best information so far. I'm due in Arequipa in two days and will start with your ideas and will report back. Very much appreciated.
OK Lucinda screwed with this post 11-19-2013 at 02:44 AM Reason: typo
OK Lucinda is offline   Reply With Quote
Old 11-19-2013, 02:25 AM   #3801
OK Lucinda
Oddometer: 493
Guys I was at the sydney motorcycle show and at the touratech stand and checked out the zega pro panniers. Does anyone have the touratech zega pro panniers on their hp2 ?
I've replied to PM from Mike.
But to answer this question publically, yes I use Zega Pros. The smallest size, 29 litres. The Touratech rack was asymmetrical and ugly so went for the Holan rack. It presses lightly against the Akra but not an issue.
Old 11-19-2013, 04:22 AM   #3802
space
a.k.a. Jake
space's Avatar
Oddometer: 2,635
I have the Wolfman Expedition packs, mounted on the symmetric Holan racks. I've never had any water or dust infiltrate my luggage, and I've fallen on them more than once off road without any significant damage. Nice side benefit is that I can use the same racks for the Zegas or similar if I ever want to switch to hard cases. Like OKL said, the left Holan rack makes slight contact with my Remus exhaust, but no issue. It would not work with the clown-sized stock can.
space is offline   Reply With Quote
Old 11-19-2013, 10:20 AM   #3803
compositeboy
What, me worry?
compositeboy's Avatar
Oddometer: 99
I run both the 17 and the 18 regularly and the change is noticeable, especially with a fresh treaded knobby on the 18 going to "street" knobby on the 17. Also, I beleive the final drive change option is 3:00:1, from 2.82:1 stock. That also does not seem like much on paper - but is a significant difference in practice.
What's the worst that could happen???
compositeboy is offline   Reply With Quote
Old 11-19-2013, 05:27 PM   #3804
mike cummins
OUTBACK RIDER
Oddometer: 724
final drive
Wow how much would it cost? im imagining if they have to break down it down and put it back together plus the cost of part , it would cost plenty of $$.
I found in timor and indo that the clutch copped a hard time from slow going as feathering the clutch became the order of the day. Also a low 1st gear would allow u to use the engine breaking more.
So i reckon on my next big trip its back to my original wheels and keep the woodys for big open desert stuff.
Old 11-19-2013, 10:08 PM   #3805
GSMarc
GSMarc's Avatar
Oddometer: 1,132
Price, call MAX BMW
http://www.maxbmwmotorsport.com/hp2-enduro
http://www.maxbmwmotorsport.com/r120...drive-upgrade/
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 11-20-2013, 04:59 PM   #3806
Boredsurfer
Oddometer: 406
p.m. sent btw.....
Boredsurfer is offline   Reply With Quote
Old 11-20-2013, 07:20 PM   #3807
mike cummins
OUTBACK RIDER
Oddometer: 724
hp2 owners ave age?
im 52 , i reckon most hp2e owners are ave age 40's. youngest being late 20"s oldest being 65 ? What do you guys think? These days im thinking i would love a lower 1st gear and a lower bike as well, wether i can just get a softer spring for the rear shock is something im looking at.
Thanks for the tips gs mark re max bmw , i actually googled them and they do the job.
Old 11-21-2013, 12:11 AM   #3808
OK Lucinda
Oddometer: 493
56 here. One rtw owner from Isreal is about 38, one Swiss rtw owner is about 55. I know two other owners from Washington state who have ridden Africa on them (and much more, but rtw'd on different bikes) and who are both in their mid-to-late 50's. An owner in Georgia and can't guess his age. Don't know any other HP2 people. Other than you guys, haha.
Back to the pannier discussion of a couple of days ago I made a mistake when I said my Zega Pros were 29 litres. They're 31. The regular, non-Pro series smallest size is 29. I had the mid-sized non-Pros until I switched over and down-sized in Medellin. Another benefit of trimming enough gear to go down to the smallest size is that if your bars make it through a gap in traffic, or any maneuvering where dimensions are important, so will your bike (within 1/2 inch a side), which is actually very nice to know.
OK Lucinda screwed with this post 11-21-2013 at 12:35 AM
Old 11-21-2013, 01:06 AM   #3809
mike cummins
OUTBACK RIDER
Oddometer: 724
zega and things
yep i worked it out re 31's. and yep same here re age, owners. We have about 20 hp2e's in oz, with one brand new one for sale at the moment for 28,000aud
Old 11-21-2013, 01:07 AM   #3810
mike cummins
OUTBACK RIDER
Oddometer: 724
gps
whats that gps u are using ,jeremy
Times are GMT -7.   It's 07:58 PM.
