Old 06-23-2007, 02:52 PM   #31
bmwktmbill
Traveler
Oddometer: 5,218
Hi 2 tail,
Man I get the getting ready issues cause I almost went suspension nuts this winter getting ready for this trip.
I reread your long post above and for the midvalve float on the "old style" tap and it seems like your measurement would be not enough for what I found on my '02 Adventure.
Now I wonder if you and I have the same fork.
What's the mm of your tubes.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 06-24-2007, 07:34 AM   #32
Twotaildog
Old Poop
Twotaildog's Avatar
Oddometer: 1,331
Originally Posted by bmwktmbill
Hi 2 tail,
bill
Tubes are 48mm.
Twotaildog is offline   Reply With Quote
Old 06-24-2007, 07:51 AM   #33
bmwktmbill
Traveler
Oddometer: 5,218
I would bet that you and I have the same mid-valve tap.
Somewhere here in the threads my shim stacks are posted.
I am on the road so no access to my notes.
From memory, I measured more float on my stock settings than you posted.
Have a great ride.
bill
Bill Shockley
Old 06-24-2007, 11:04 AM   #34
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,228
Originally Posted by Twotaildog
I couldn't figure out how to make the midvalve stack work on my '01 forks, it looked like I would run out of float if I tried to put that many shims in there. For the record, here is what I found in my forks:
Base Valve:
(6) 24 - 0.1
(2) 22 - 0.1
(2) 20 - 0.1
(2) 18 - 0.1
(1) 16 - 0.1
(1) 14 - 0.1
(1) 11 - 0.1
Mid valve:
(4) 24 - 0.1
float - 1.3
The hydraulic stop, which appears to also be a guide for the inside of the spring, was slightly too large in diameter for the new springs. The ID of the new springs was ~32.6 mm and the OD of the hydraulic stop was ~32.8 mm. I filed about a half a mm off of each of the four ridges on the OD of the hydraulic stop, and everything fit just fine.
You have almost the same base valve as I do ('02 adv) and exactly the same mid valve. The rebound tap that holds the rebound and midvalve shims changed from '02 to '03. It looks like the '01 and '02 have the same part. I changed the base valve to the Z-dog stack and left the mid-valve alone -it was still a big improvement. Probably not as big an improvement as filling both forks with oil, though. BTDT.
Not that it's that big a deal, but the MX-Tech springs slid right in. The difference might in be the rubber bumpers, though.
Luke is offline   Reply With Quote
Times are GMT -7.   It's 01:43 AM.
