Old 06-11-2007, 05:31 PM   #16
Udo OP
Udo's Avatar
Oddometer: 524
Rear shock mounts
Spent part of today fabricating/reinforcing the rear shock mounts. Took some pics.
Thought a lot about moving the bottom mounts forward, making a single shock setup, and variations. Finally decided to go with the obvious and not over engineer it at this point. The plan, what there is of it, is to just build the bike based on common sense, not get hung up on too many details, see how it rides and handles. Then, redesign as needed, tear it down, make it pretty, and put it all back together again. No, haven't looked too hard at geometry. Too easy to get hung up on paper designing and never get to the building.
Udo is offline   Reply With Quote
Old 06-11-2007, 05:33 PM   #17
Udo OP
Udo's Avatar
Oddometer: 524
Putting it to steel
Traced the cardboard pattern onto some 1/8" plate and cut it off with a simple cut-off wheel.
Old 06-11-2007, 05:37 PM   #18
Udo OP
Udo's Avatar
Oddometer: 524
Fitting to frame
After cleaning the cuts up on a grinder I attached the plates to the frame, using flat washers stacked to get proper spacing for the top shock eye. Then, torch to get it red hot, hammer to shape against frame.
Old 06-11-2007, 05:40 PM   #19
Udo OP
Udo's Avatar
Oddometer: 524
Welding to frame
Had Noah, our shops expert welder, do the final attachment.
Old 06-11-2007, 05:42 PM   #20
Udo OP
Udo's Avatar
Oddometer: 524
Finished
Ta da, bullet proof top shock mounts.
Old 06-12-2007, 08:47 AM   #21
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,210
i love this stuff.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 06-12-2007, 07:55 PM   #22
Renegade6
Renegade6's Avatar
Oddometer: 820
Nice. I've always wondered about doing that with an R65.
Brandon
1993 BMW R100GS
Renegade6 is offline   Reply With Quote
Old 06-12-2007, 08:07 PM   #23
Udo OP
Udo's Avatar
Oddometer: 524
Progress
Doing this show and tell is inspiring me to plow ahead full speed. Today, managed to mount the starter, alternator, diode plate, a nice set of 32mm Bings I found on e-bay (like most everything going into this bike, including the frame). What a pain in the ass it is to attach the drive shaft to the trans. I even managed to drop a bolt down the swing arm. A long, thin magnet fished it out. Thought I'd be tipping the bike up on its front end. The next problem is altering the sub-frame to fit. The vertical braces interfere with the new shock location. Looked at an R100GS and noticed how they bent the brace around the mono shock. I'll post pics as I do that modification.
Old 06-13-2007, 04:35 AM   #24
grimmboy
Chris Grimm
grimmboy's Avatar
Oddometer: 894
Damn, I was going to ditch the BMW project because I was building this;
I guess I've got to get the R65 frame back in the shop and start getting parts put together.
Stagehand glad to see all is well.
grimmboy is offline   Reply With Quote
Old 06-13-2007, 05:16 AM   #25
grimmboy
Chris Grimm
grimmboy's Avatar
Oddometer: 894
Forgot to add Udo great project, simple is better.
Old 06-13-2007, 06:47 AM   #26
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,210
yeah, you too!
What you've got going on is not too shabby either. I have a soft spot for XT's as well.
Old 06-13-2007, 05:52 PM   #27
Udo OP
Udo's Avatar
Oddometer: 524
Grimmboy, nice to meet you.
Why not get the R65 frame out and do both? If you get stumped or bored with one, you can then play with the other. Isn't more better?
Old 06-18-2007, 02:01 PM   #28
grimmboy
Chris Grimm
grimmboy's Avatar
Oddometer: 894
Udo, bigger plans for the XT500 that must be met. Nice grass root fab, take what works, make it, ride it and fit it if it needs it.
Can't wait for more updates.
Old 06-20-2007, 05:45 PM   #29
Udo OP
Udo's Avatar
Oddometer: 524
Step by step
Moving right along. Parts have been arriving every other day. Love my UPS guy. Got a nice set of controls for the Renthal Handle bars. Rich at Repsycle BMW has been very helpful. Brake lever, master cylinder, throttle, starter switch/kill switch, and cables on the right. Clutch lever, choke control, light switches, and cables on the left. The Renthal bars were knurled on the left side, making the left a little thicker than the right. Made the mistake of trying to force the clutch lever perch over the knurling and broke the part. Stupid. Repsycle was able to get me another one. This time - a litle flat filing over the knurling and an adjustable reamer inside the perch, and all fit together nicely.
The alternator, diode plate, and ignition pick up were routine once I figured the wiring out. A used R65 harness is temporarily hung, just waiting for a battery.
Got a used, very large battery tray. Don't know from what. So, a little cutting wheel action, a little sand blasting and welding, we now have a battery box made to fit.
Had to hang a set of 32mm Bings, just to make it look like there's progress. Got them used without any real history. I suppose I should drop the bowls, check the diaphrams, just to make sure all the parts are inside.
Found an R80ST being parted - we now have a seat, center stand, air tubes, and ignition module heat sink enroute on some UPS plane between here and San Francisco. Once the seat arrives I can determine the angle of the subframe and fabricate the new vertical braces.
Here's some pics.
Old 06-20-2007, 05:50 PM   #30
Udo OP
Udo's Avatar
Oddometer: 524
Charging system
All routine here.
Times are GMT -7.   It's 04:12 AM.
