Old 06-28-2007, 10:42 AM   #46
milkman
can't find my screwdriver
milkman's Avatar
Oddometer: 137
Looks unreal mate.
Long time lurker and R65 rider, you've coaxed me out to make a post.
Would love to do somethin simmilar, can't wait to see how it tests.
milkman is offline   Reply With Quote
Old 07-04-2007, 10:24 AM   #47
grimmboy
Chris Grimm
grimmboy's Avatar
Oddometer: 893
Udo????? I realize things like work, life and family get in the way but we are waiting for an update.....
grimmboy is online now   Reply With Quote
Old 07-07-2007, 04:52 AM   #48
Udo OP
Udo's Avatar
Oddometer: 524
Not abandoned
No, haven't abandoned the project. Yes, work has been in the way. The shop is slammed with cages needing repairs, maintenance, work. The crew is taking turns going on vacations, and I'm up to my ears.
But, a tach, speedo, and a few other bits are on the way - want to have it running within the next week. The sub-frame supports have me hung up. Trying to bend 3/4" thin wall tubing to clear the rear shocks. Bought a Harbor Freight hydraulic pipe bender with the hope of bending smooth curves - Not. The tubing kinks every try, even filled with sand, heating, cussing. Need to get a line on a local who can do mandrel bending.
More pics this week.
Anyone been following Lonestar's thread riding a R1100GS from Texas to Montana? He stopped at the shop on his way through here. Nice guy and a great ride report. Here's the link:
http://www.advrider.com/forums/showt...20#post4863020
Later.
Udo is offline   Reply With Quote
Old 08-03-2007, 04:05 PM   #49
Udo OP
Udo's Avatar
Oddometer: 524
Progress at last
Had some free time so I got myself motivated to make this beast a rider. The seat frame supports had us hung up for awhile. Didn't think that part would be so difficult. Have you ever tried bending 3/4" thin wall steel tubing without kinking it? Finally had a buddy bend some thick wall tubing to shape and was able to make the supports. To join the supports to the stubs I left after cutting off the old supports I used some 3/4" ID sections as collars. Able to then braze everything together. A grinder will clean them up nicely before powder coating.
Udo screwed with this post 08-04-2007 at 04:31 AM
Old 08-03-2007, 04:09 PM   #50
Udo OP
Udo's Avatar
Oddometer: 524
Seat support
The back of the R80ST seat needed something to keep it from moving backwards and coming off. The front has a tab that slides under the rear/bottom of the tank. So, some more 1/8" metal fabrication. Work real slick.
Old 08-03-2007, 04:12 PM   #51
Udo OP
Udo's Avatar
Oddometer: 524
Ignition switch
Till I figure out how to mount the tach, speedo, warning lights I needed to somehow fasten the ignition switch. A simple bracket bolted to the triple tree works just fine.
Old 08-03-2007, 04:17 PM   #52
Udo OP
Udo's Avatar
Oddometer: 524
A runner
Here's a shot of the bike, ready for a good road test. Right now the exhaust is wide open, waiting to fabricate a y-pipe, two into one to a Supertrapp muffler high at the right side. I had guessed at the ignition timing and found it right on when I checked it with a light. Carbs also work fine, right out of the box. Better lucky than good. I'll make final adjustments once I have the exhaust completed.
Old 08-03-2007, 04:19 PM   #53
Udo OP
Udo's Avatar
Oddometer: 524
Another view
Almost ready for disassembly for the "make pretty" phase.
Old 08-03-2007, 04:26 PM   #54
Udo OP
Udo's Avatar
Oddometer: 524
Road test
At first, carefully, gingerly, fearfully, took it up and down the road. Slowly, and then faster and faster. What a gas. At first the longer front caster felt a little weird, but soon got used to it. The suspension is very compliant, but never bottomed out. The test track is a very rutted, washboardy dirt and rock road next to the shop. No problem. I had Noah, our most experienced dirt rider take it out. He loves it. And this is from a Harley trained mechanic. Here he is at speed.
Old 08-03-2007, 04:29 PM   #55
Udo OP
Udo's Avatar
Oddometer: 524
More fuzzy at speed
The engine has a flat spot at lower RPM's. Should be OK after we put on a muffler and do final tuning. Even with that, you can feel the torque in that small frame. It feels like wheelies should come easy.
Old 08-03-2007, 04:44 PM   #56
ctfz1
ctfz1's Avatar
Oddometer: 1,309
Buell bits are usually reasonably priced and durable. Lights turn sigs. OEM sportbike mufflers are usually cheap and sturdy if heavy. Keep thinking of gsxr 1000 05-06 but Ducati or sv (1000 had twin pipes?) or such. or ebay.
Beautiful.
ctfz1 is offline   Reply With Quote
Old 08-03-2007, 08:57 PM   #57
Pezz_gs
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,812
Well Done Udo
One approach you could used was to come off the cross brace beneath the battery with the curve inside the shocks to the seat support. I imagine you tried that anyhow.
Coming together nicely
Pezz :)
Airhead Tragic
I'm not a complete idiot -- Some parts are missing
XR460/4 - http://www.advrider.com/forums/showthread.php?t=497905
Pezz_gs screwed with this post 08-05-2007 at 04:06 PM
Pezz_gs is offline   Reply With Quote
Old 08-03-2007, 09:07 PM   #58
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,969
Thats cool, man!
tell that guy to put a helmet on and pop a wheelie.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 08-05-2007, 03:25 PM   #59
grimmboy
Chris Grimm
grimmboy's Avatar
Oddometer: 893
Udo, fantastic, always great to see a project on the road again. That front end needs a big Baja Designs 8" headlight.
Old 08-05-2007, 03:51 PM   #60
philp38
philp38's Avatar
Oddometer: 3,256
That looks great. Please don't keep us in the dark. I can't wait to see it finished.
Temple Lodge,No 25.F.& A.M. Winthrop Maine
Paddle faster I hear banjos
philp38 is offline   Reply With Quote
Times are GMT -7.   It's 05:25 PM.
