Old 06-11-2007, 10:06 AM   #1
Hotspice OP
Satellites not acquired
Hotspice's Avatar
Oddometer: 5,540
Latest Items at Cyclenutz
Well I've been slowly adding more items to the lineup at www.cyclenutz.com so I thought I'd put them in a central thread to keep y'all in the loop.
* First up is the Ezy-Mount Light bar for the 1200GS. This won't work on the Adv without some mods but it is a clean bolt up solution for the "sport" GS. It's the same Light bar you get in PIAA kits and is designed so you can mount lights on top, below, or even on the ends of the bar.
* Next is the Ezy-Mount light bar for the F650GS. This bar will only take lights on the bottom and is again a pretty straight forward, bolt on kit.
* And for you non GS'rs we have a RAM mount that fits in the center area of your handlebars. This is made of billet aluminum and is one trick, clean setup.
Cyclenutz.com motorcycle accessories
Get a SmugMug account and use coupon code DwHE0pDRjpJfw to save yourself $5.
Hotspice screwed with this post 05-18-2011 at 10:39 AM Reason: removed image file
Hotspice is offline   Reply With Quote
Old 06-11-2007, 07:03 PM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,529
Hmmmm, I like that!
Might be we could make a deal!
Jim
JimVonBaden is online now   Reply With Quote
Old 06-12-2007, 06:47 PM   #3
Hotspice OP
Hotspice's Avatar
Oddometer: 5,540
And again from the EzyMount corner we have a handy little gadget for wiring up to switched power.
The Plug N Play Parking Lamp Switched Power Interface is a connector that just plugs into the parking lamp of the 1200GS, you plug the bulb into it, and plug back into the headlight housing. Walla, you have a pigtail that you can wire right to a relay circuit to give you switched power without tapping into any of the bikes wiring.
This is already packaged in the R1200GS light bar kit to make the job easier.
Hotspice screwed with this post 11-16-2010 at 12:24 PM
Old 06-14-2007, 11:07 PM   #4
chanman
chanman
Oddometer: 4
your light bar for the f650gs, will it only work with the piaa lights or could you mount some cheap lights like hella optilux or similar? thanks
chan
chanman is offline   Reply With Quote
Old 06-15-2007, 04:45 AM   #5
Hotspice OP
Hotspice's Avatar
Oddometer: 5,540
The light bar has a hole through it that can accept up to a 7/16" bolt. That means that they should accept most other driving lights.
I've even had people mount the Optilux 1402's on it which are similar to the PIAA 1400's in that they have a rectangular base with slots on each side.
Feel free to PM me with the specifics of your lights and we'll see what we come up with.
chan
Old 07-23-2007, 07:15 PM   #6
Hotspice OP
Hotspice's Avatar
Oddometer: 5,540
Thanks to members here I found out about the Rox Pivoting Risers.
Put them on my 1200GS, loved them, and had to add them to the shop.
Hotspice screwed with this post 11-16-2010 at 12:22 PM
Old 07-24-2007, 07:21 AM   #7
kildala2000
The GS Store.
kildala2000's Avatar
Oddometer: 2,073
Talking Looks GOOD
Hey Hotspice,
The new products look good & I'm sure will sell like hot cakes.
Ride Safe,
Rick
kildala2000 is offline   Reply With Quote
Old 07-24-2007, 07:40 PM   #8
See-Double-You
See-Double-You's Avatar
Oddometer: 1,670
chan
The EzyMount is pre-drilled for about 6 different PIAA models. Makes it nice if you're installing one of the recommended lights. Will probably do a write up on f650.com one of these days, since there is so little info "out there" on this brand. All the websites use the same stock photos. Instructions/installation is pretty straight forward; although at first glance, you may think different.
CW
" Suggest you stick with failure analysis of Pork Chops " - -Benesesso
See-Double-You is offline   Reply With Quote
Old 07-24-2007, 08:23 PM   #9
JimVonBaden
"Cool" Aid!
Oddometer: 53,529
I love mine!!!
Jim
Old 07-25-2007, 05:27 AM   #10
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,644
How does that work? Does each bracket mount to the two (appropriate sided) screws holding the 'beak' on?
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 07-25-2007, 07:39 PM   #11
Hotspice OP
Hotspice's Avatar
Oddometer: 5,540
Unfortunately I don't have any good pictures but yep, there should be two bolts you can easily access. They are about 1 1/2" apart and the bracket bolt up to them.
Old 07-25-2007, 07:49 PM   #12
See-Double-You
Oddometer: 1,670
Yup, pretty much. Very easy to install. I've probably spent 5 times more time working on the electrical portion of the project, and I'm still not done. Haven't made up my mind what to do with on/off switch...
Check the chain gang this W/E, I'll try to put together a small write up w/ photos. (Don't want to steal Hotspice's thunder)
CW
Old 07-25-2007, 08:02 PM   #13
Hotspice OP
Hotspice's Avatar
Oddometer: 5,540
It's great to hear from people that use them so there is no thunder stealing at all.
Heck, most of the time I get people asking me why they look just like the PIAA mounts. Then I get a response like "REALY" when I tell them that the PIAA's are really EzyMounts.
I'll take a look over at CG for your write up.
Old 07-26-2007, 10:10 AM   #14
R_W
wannabe
R_W's Avatar
Oddometer: 4,126
ROX ROCK!!!
Nice updates on items. One suggestion: on the versatool, list the individual bit sizes. I was pissed last time I bought a set of wrenches (from somewhere else) and it skipped the one size I needed
Red hair and black leather, my favorite color scheme...
R_W is offline   Reply With Quote
Old 07-26-2007, 05:14 PM   #15
R_W
wannabe
R_W's Avatar
Oddometer: 4,126
Thumb
WOW, that was fast. Thanks for the bit sizes.
Times are GMT -7.   It's 04:52 PM.
