Old 06-14-2007, 05:22 PM   #1
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Penny-Tech valve stem pull-thru tool
OK... it's not really penny-tech. It will set you back about 5 bucks and a half hour of you're time.
Earlier today, Tholand (KTMtalk) made a post asking about anyone who might know a fellow that made tube type valve stem pull-thru tools. That original thread is here.
We’ve all seen stem pullers before… from leverage bars to cable type pullers, but they all have one thing in common, they attach to the outside of the valve stem, making them pretty useless for motorcycle wheels… unless you’ve got those rims with huge, oversize stem holes and the rubber grommet that pops into them.
Years ago… back when dinosaurs roamed the earth and every tire had a tube, there was such a tool, readily available, that could be used to pull the valve stem thru the hole by screwing it into the core threads, rather than over the stem threads. But, much like dinosaurs and 24.9 cent a gallon gas… those days are over.
Back to Tholand’s post. I responded, thinking of the current outer thread type pullers, not really knowing what he was talking about.
Then, I did a little research (after the fact of course) and found that a gentleman was making a motorcycle specific tool.
The down side is that his e-mail and the website I found the tool at are defunct.
So, I decided to make my own. To make a long story less long… I thought I could make a tool with a valve core. That was wrong headed thinking on my part.
On to plan B.
I went down to the Taiwanese auto parts store and bought a cheapy valve stem tool.
Then I pressed the two pieces apart and proceeded to drill out the part I needed... and toss the part I didn't.
Looking around, I couldn’t find any braided stainless cable, and I couldn’t find any hi-test fishing line… probably because I don’t fish.
But I did find my trusty spool of safety wire… Eureka!
And this is the finished tool… well, OK, it’s the first finished tool, the last pic is the finished finished tool, but with fancy rubber hose over most of the safety wire.
The hole is big enough (and chamfered on the ends too) for the safety wire to slide thru easily, but not big enough for it to pull out when its doubled over.
That’s about it. Thanks Toland for pulling an idea out of the deep dark recesses of my cobweb filled brain and making me go spend a whole 4 bucks and ˝ hours time in the shop. Now I got a tool that I always want when changing a tire… but never had (or at least haven’t had in about 25 years) until now.
Ciao,
C
So... how's tricks?
creeper is offline   Reply With Quote
Old 06-14-2007, 05:28 PM   #2
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,687
Nice work!
Here's where I bought one before for $10:
http://pitposse.stores.yahoo.net/airvalvepuller.html
potatoho is offline   Reply With Quote
Old 06-14-2007, 05:30 PM   #3
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Theirs is prettier than mine.
So... how's tricks?
Old 06-14-2007, 05:39 PM   #4
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,687
Mine is still in the bag LOL. But I have something to show you.
It has a core remove/install tip! Though it isn't knurled.
Old 06-14-2007, 05:43 PM   #5
toolfan
Broken Hearted
toolfan's Avatar
Oddometer: 9,543
Why not a little bit of safety wire around a valve core?
(more of cheap-ass klr solution)
toolfan is offline   Reply With Quote
Old 06-14-2007, 06:07 PM   #6
warnabrother
.. if you see the Rozzers
warnabrother's Avatar
Oddometer: 2,022
ummm.. I change all my own tyres and have never had a problem getting the valve through the hole.. nor thought how neat a valve puller would be...
I fit the tube inside the tyre first, line up the hole on the rim.. poke the valve through the hole.. tighten the nut.. fit tyre..
what aren't you guys doing that you need a special tool to fit the tube ???
I am not trying to be a smart ass... just interested why you'd need a tool...
Good tech regardless
bikeless...
warnabrother is offline   Reply With Quote
Old 06-14-2007, 06:45 PM   #7
flux_capacitor
I know a shortcut!
flux_capacitor's Avatar
Oddometer: 9,619
It would come in handy when changing a tube I would think...not necessarily a tire depending on your method. I know I'm gonna make one of these to carry in my fender bag. Nice work, Creeper. Just so happens I have one of those cheap core tools in the garage that never gets used...until now.
flux_capacitor is offline   Reply With Quote
Old 06-14-2007, 06:49 PM   #8
warnabrother
Oddometer: 2,022
I just use my lever to lift the backside of the tyre up.. line the valve up with the hole and down she pops...
Never knew people had "issues" fitting them...
Oh well.. great tool anyways..
bikeless...
Old 06-14-2007, 06:54 PM   #9
SinFrenas
banal leakage
SinFrenas's Avatar
Oddometer: 959
ditto, i've never had any issues with it either...
until the other day. took about 35 minutes and 2 skinned knuckes before that joker popped thru.
i'll be copying this fella's excellent idea this evening, for sure!
Welcome to the jungle, Kevin!
"Life is a good thing. It's a better thing when you have a bike." -Gaspipe
SinFrenas is offline   Reply With Quote
Old 06-14-2007, 08:05 PM   #10
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
About the response expected. A bit of ... and a bit of
It's just a tool, and like most tools... value is in the hand of the user.
It's all a matter of what you've experienced in your little bite of the world that determines a tools value.
For them what like it and will duplicated it, good on ya’… and I hope you never have to use it on a mountainside single-track in the snow.
For them that don’t see the value... no worries.
C
So... how's tricks?
Old 06-14-2007, 08:42 PM   #11
warnabrother
Oddometer: 2,022
C
I totally agree.. and as mentioned.. am not trying to be a smart ass.. it's just that I am intruiged that you have had trouble enough seating the valves that you designed a tool for it.. which is an awsome tool.. just I never heard of people having trouble fitting them before.. but there are obviously guys out there that do have trouble.. and I have not been listening hard enough..and to them.. this tool is awsome...
Good on ya mate... top jop.. and up there for thinking
bikeless...
Old 06-14-2007, 09:19 PM   #12
Pally McGee
Reality's Bitch
Pally McGee's Avatar
Oddometer: 3,351
Because if there is an angle someone finds to make a buck, they'll use it, and marketers figure out a way of convincing us we need it. I'm still trying to figure out why we need to wear gloves while working on our bikes. Used to be a time when a little grease under the fingernails was worn proudly, like a merit badge, or a symbol of passage. Nope, I can't see a reason to use one of those fancy stem-pullers. If you install your tubes and tires correctly, you'll never need them.
Love one another. Its really all we have thats worth anything at all.
Pally McGee is offline   Reply With Quote
Old 06-14-2007, 09:25 PM   #13
warnabrother
Oddometer: 2,022
are you serious... who does that ??
pretty sure its illegal in Australia.. if not, your mates would call you all sorts of homosexual names till the day you died anyway...
bikeless...
Old 06-14-2007, 09:27 PM   #14
Pally McGee
Reality's Bitch
Oddometer: 3,351
Exactly, Mate! Now pass me that jar of Vegemite and a lager!
Old 06-14-2007, 09:43 PM   #15
toolfan
Broken Hearted
toolfan's Avatar
Oddometer: 9,543
I was able to take the stem part out of a valve stem, then replaced it with a piece of safety wire - and to make it extra pennytech, I used a used piece of safety wire!!
No pics, but I just used side cutters to cut both ends of the little stem off, the I used two pairs of pliers, one holding the body and one holding the bottom of the little stem - a quick yank and I had a hollow body. Then I just took a piece of safety wire and doubled one end over, then put the other end through the body - the doubled up end was big enough to lodge in the body. I suppose if one were spunky they could twist the wire and make it all pretty and stuff. Or, if one were not lazy they could post a picture for all adventure riders to see...
Times are GMT -7.   It's 07:27 AM.
