04-14-2008, 08:04 PM
#721 |
Bronze Age Fall Guy
Oddometer: 5,122
Very cool report. I agree the motor is a tractor! Just point and shoot.
Hate gets you nowhere. |
04-16-2008, 07:52 AM
#722 |
Aspiring human
Oddometer: 2,133
I finally had to learn how to upload and imbed videos onto stuff for my mini ride report on the ADVrider dinner in Charlotte this past weekend, viewable on the link in my signature, page 69.
So, here's a couple boring vids of me toodling around town. I'll try to make some more action-packed ones in the future. (gotta practice those wheelies to make that happen...) BTW, the Charlotte dinnner ride was the first long distance trip I mae on this bike, and it did very well, holding up to 65mph+ for extended periods (hours) and for a round trip distance of over 350 miles. One thing I realized while pondering the engine bugs is that using a thin gasket paper, even a paper gasket from an aftermarket gasket set on the rocker box, is not acceptable. The Honda gasket is a thick 3-layer embossed aluminum, and the thickness is important because the rocker box has to clamp down tight enough on the cam bearings and the gasket surface, and if the gasket is thin, it will clamp down on the bearings and still leave a gap at the gasket faces. So I'm definetly buying a stock Honda rocker box gasket. Anyone who's had their rocker box off their XL should be able to dig this information. What kind of gasket are you all using on yours? Oh yeah, I almost forgot to add, I set a new personal top speed on the XL: 90mph.
1987 Yamaha XT600 2KF (German) STOLEN: RED XL600 in Portland I do heavy-duty textile repair, upholstery, and design/manufacture bags. |
04-16-2008, 06:28 PM
#723 | |
Oddometer: 903
90mph Toldja these were great bikes. I had developed a bit of an oil leak from my decompression shaft seal in the rocker box as well as a bit of a weep in the front of the rocker box gasket right above the spark plug area. Anyway, I just got back from the local Honda store this afternoon with the new seal and $43 gasket. That's one expensive gasket, but this time I'll take extra care to make sure it goes together right and all the bolts get torqued correctly.Other than that, nice vids. Work on those wheelies. It will be rack fabricating time soon. |
04-16-2008, 08:33 PM
#724 |
Bronze Age Fall Guy
Oddometer: 5,122
I have reused that metal rocker cover gasket with copper spray as a sealer and have had no problems.
04-16-2008, 09:40 PM
#725 |
Aspiring human
Oddometer: 2,133
Yeah I might just reuse the metal one I had originally on the head with my spray on copper coat too rather than pay $30+ ofr a new one.
Greg, that's the same area I got a leak on mine both times I've had it together and running. Because it's the exact same area for the both of us, I think it's intrinsic to the fiber gasket being used instead of a Honda aluminum gasket. This time around, I'm using thinner material too. I think it has to be thicker than the gasket paper in order to be clamped on those two bearings and still have enough sandwiching on the gasket faces, you know? If the cover is tightened down onto those bearings, and it's not hitting gasket because it's too thin, it would cause a leak, and the gasket were too thick, it would cause the cam bearings to be loose. What do you think of this evaluation, Greg, and what kind of gasket material were you using before? Looking forward to rack time. I worked on my Pannier boxes a little, cleaning up the insides and killing mold with bleach. I'll get you some more details about the design, I can't wait!
04-17-2008, 07:41 AM
#726 |
Ride On!
Oddometer: 2,829
Yeah, I'm still excited about those racks, too. Good luck finishing all your university stuff, Greg.
'03 XR650R, '04 Honda Sabre, '83 XL600 Supermoto (Project) XR600 rebuild http://www.advrider.com/forums/showthread.php?t=188797 XL600 rebuild http://www.advrider.com/forums/showthread.php?t=224984 |
04-20-2008, 11:36 PM
#727 |
Aspiring human
Oddometer: 2,133
Rack Templates Are Here!
So we are all ready to design-a-rack using these template illustrations I made. So if anyone's got a design bug, they can take one of these. You can PM me if you want the fullsize file of these e-mailed to you. I just took a pic of the side of the bike, converted it to greyscale, bumped the contrast, and traced it right off the computer screen. I'm sure you whizzes out there have a much better and more effficient way. The design I'm visualizing but haven't drawn yet is one with two components. The first: a rack, similar to Gregster's but a bit smaller, lower, and not extending as far back. Second, a Pannier "yoke" of sorts (panniers remvable from it as well), that I can attach to the rack with its own braces that swoop forward and down to the frame, levering some of that additional weight off of the lower frame near where the two tubes meet at a "v", probably requiring welding a bolting point to the frame. Check out post #19 on page two of this thread to see the design that inspired me to take this approach. That thread has some great rack designs in it.
04-21-2008, 05:25 PM
#728 |
Oddometer: 820
crosspost.. problem with my XL..
Brandon Reed 2009 Husqvarna TE610 |
04-22-2008, 10:25 AM
#729 |
Bronze Age Fall Guy
Oddometer: 5,122
I did a 150 mile round trip on my 600 Sunday. I was mostly going 65mph touching 70 once in a while. With 15/50 gears I got 53mpg. I have to sit waaay back on the seat to get it to ride stable at the highway speeds. Sitting close to the tank will produce some intermittant headshake.
04-22-2008, 11:04 AM
#730 | |
Oddometer: 820
04-28-2008, 02:50 PM
#731 |
Aspiring human
Oddometer: 2,133
News: I've done my first draft of the rack and pannier rack. They will be separate racks so pannis are removable. This rack is going to be fabricated by Gregster starting soon, assuming he's still up to it. I give him artistic license to deviate from the drawing, and am giving several other models which served as my inspiration as to how I should go about the design. I will be having my frame welded with tabs to mount the pannier rack's lower support bars to.
Key notes to Greg: Please build so that: -top surface is at least level or slightly slanted forward when bike is loaded with rider weight (160#) and ~40# cargo. -seat may be removed easily with racks in place or at least with top rack in place. -center of gravity as low as possible -No paint or final grinding neccesary, as I have grinder with various discs and flap wheel, and acess to a blasting cabinet, so I can do the final stuff. ![]() Here's a nice pannier bolt mounting system: ![]() Here's my inspiration for the panniers and it has an offset to the lower support bars which may need to be replicated. I don't mind whether flat or tube stock, or whatever kind of stock is used for that part. ![]() And finally, please look at the post your pics of xr650 L racks and bags thread, which has my favorite rack designs, the noteworthy ones are posts # 19, 32, and 34. Thanks!
04-28-2008, 05:40 PM
#732 |
Oddometer: 152
the motor , mine makes the same whiney noise i guess thats normal -
04-29-2008, 07:23 AM
#733 |
Aspiring human
Oddometer: 2,133
Greg, hold up on the rack... I just found a fellow ADVer locally who has a shop we can use, so I may end up fabbing it here... I think ERE109 still wants one soon, I will post with updates on if this works out.
04-29-2008, 07:52 AM
#734 | |
De Oppresso Liber
Oddometer: 30,377
"I claim to be frightened of horses but do so only to get out of attending parades. It's peculiar but ...it works. The Horses get it. RESISTANCE IS NOT FUTILE. IT'S VOLTAGE DIVIDED BY CURRENT |
04-29-2008, 08:52 AM
#735 |
Ride On!
Oddometer: 2,829
Yeah, I'm still interested in a rack, so keep us posted.
