Old 06-28-2007, 11:23 AM   #1
rick danger OP
Off the wagon
rick danger's Avatar
Oddometer: 4,868
Measureing handle bar "sweep"
Just looking for a set of bars. Where is the sweep measured from? Am I right in thinking its the amount the bars are bent backward? Would it be measured from the part in the middle (where they clamp) To the bar ends? Looking down from above. Is this also known as the bend? Or is that the sweep and the rise? Thanks
'08Husky TE 610 '07 R12GSA '07 KTM 950sm '92 GOLD WING '77 HUSKY 390 CR '72 Honda xl 250 '71 Honda sl 125 '79 HUSKY390cr '75 Can Am 250 MX-2 '70 Honda CT 70
'05 R12GS.....R.I.P. (rest in pieces)
rick danger is offline   Reply With Quote
Old 06-28-2007, 07:32 PM   #2
buffallodan
buffallodan's Avatar
Oddometer: 1,702
http://www.renthal.com/fatbar.asp
Click on Applications for a diagram of sweep, height, and rise. I thought height and rise were the same but I guess not...
Dan
buffallodan is offline   Reply With Quote
Old 06-29-2007, 03:57 AM   #3
rick danger OP
Off the wagon
Oddometer: 4,868
Thanks, So the larger the sweep number the more pulled back I guess?
Old 06-29-2007, 05:45 PM   #4
lost-ona-dirtbike
Oddometer: 87
correct.
keep in mind that if you compare measurements from different companies ... they don't all measure their bars the same. Some use different terminology too.
lost-ona-dirtbike is offline   Reply With Quote
Times are GMT -7.   It's 05:21 AM.
