06-16-2010, 09:36 PM
#31 | |
transcontimental
Oddometer: 5,644
It happened to me just a little while ago. After tons of head-scratching, it turned out that the problem was the O2 sensor. $66 and easy to install. My bike was surely in "limp-home" mode. Full rich mixture.
Alaska to Tierra del Fuego. Hall of Wisdom How To Diagnose Problems. Sticky Latin America Ride Reports. Drowned near San Blas. Crazy Girlfriend Stories. Front Page Photo. IBA #28229 |
06-17-2010, 12:20 AM
#32 | |
Syndicated
Oddometer: 11,286
06-17-2010, 02:36 AM
#33 | |
Oddometer: 128
I will play with it a little more. Not sure what the others are saying about using a hammer and harness under the tank. That must be on the 1150's. |
06-17-2010, 02:57 AM
#34 |
steptoe
Oddometer: 2,158
before you all confuse yourselves, look at the thread start date.
www.gsshop.co.uk |
06-17-2010, 02:59 AM
#35 | |
Oddometer: 128
06-18-2010, 04:06 PM
#36 | |
transcontimental
Oddometer: 5,644
Sure looks like the full-rich default mode is "Limp Home."
06-18-2010, 04:33 PM
#37 |
Syndicated
Oddometer: 11,286
I understand |
06-18-2010, 06:59 PM
#38 | |
transcontimental
Oddometer: 5,644
And if the bike limped home, 250 miles in 5 hours running at maximum speed, what else would you call it, other than "limp home" mode?
06-18-2010, 07:15 PM
#39 |
Syndicated
Oddometer: 11,286
You don't understand your logic. |
06-18-2010, 08:58 PM
#40 |
Mod-U-Later
Oddometer: 13,516
Well kewl.
Poolside used some smilies to add an extra layer of insight into what he really means. Sorta kinda… Because I'm not really sure what he means but I can tell he really means it. ![]() JJ
QUOTE from vermin I lie to myself because I am the only one who continues to believe me. |
06-18-2010, 09:07 PM
#41 |
transcontimental
Oddometer: 5,644
If a year ago you guys had told me that in The Spring Of '10 I'd be obsessed with O2 sensors, Dutch fault-code tables, and phantom vacuum leaks manifesting as mythological limp-home modes programed by clairvoyant German engineers...
06-18-2010, 09:23 PM
#42 |
Syndicated
Oddometer: 11,286
I feel ya brother! Welcome to my world. |
06-19-2010, 12:19 PM
#43 |
Oddometer: 1,727
Bananaman, any U-Toob before and after videos on the perceived performance increase from replacing the lambda sensor?
We want to believe but... A fault in the TPS, but not the lambda sensor can trigger limp home mode. I write from from personal experience with a damaged TPS on an r1100 w/mo 2.2. A sampling of incidents and ecu theory reported in various forums worldwide also suggests that it is unlikely that a bad lambda sensor would limit your engine rpm or top speed. The fact that you are now able to reach redline (are you?) after simply replacing the lambda sensor is coincidental. Perhaps you had a plugged tank vent that cleared itself or a mouse nest in the airbox that finally got sucked past the valves? What was the max rpm before the lambda change and how many rpms do you perceive to have gained by replacing the lambda sensor? For benefit of the less technical here, there are certain things we ought to suspect first when a single spark oilhead experiences loss of power. We know enough about the operation of motronic 2.2, as well as the non-ecu issues that we can now quickly resolve common r11xx performance problems without buying unnecessary parts or labor. Faulty lambda sensors do not cause sudden, dramatic loss of engine power. At best they cause declining fuel economy for those riders that spend a lot of time cruising at steady state. Non cat bikes masquerading as cat-equipped bikes: One inmate queries from Mexico and another from Oz: "Why do I have a cat but no o2/lambda?" A; NO, you do not have the cataclysmic avertor device on your R1100GS. You have a factory collector/pre-muffler that LOOKS like a cat, but is not a cat. It is an empty can, perhaps with baffles but not with rare earth metal catalyst. Should you buy a lambda sensor? Perhaps you are concerned about the plight of drowning polar bears. If that is the case, by all means, order a complete oem U.S. spec exhaust for your non-U.S., non-cat 1100. Hey, I'll trade you mine and throw in a brand new lambda sensor! Please re-cycle your CO-pot and old oem non-cat exhaust by sending it to me. I promise to keep it out of the landfill. Lambda sensors are required to prevent damage to the cat. No cat> no lambda sensor required. Limp Home re-visited: To understand what limp home mode feels like, simply unplug your TPS. Compare that to a disconnected o2 sensor. vintagerider screwed with this post 06-19-2010 at 02:31 PM |
06-19-2010, 04:41 PM
#44 | |
Syndicated
Oddometer: 11,286
Poolside screwed with this post 06-19-2010 at 04:48 PM |
06-19-2010, 07:01 PM
#45 |
Mod-U-Later
Oddometer: 13,516
Uh just to clarify…
Turn OFF the bike then plug or unplug a sensor. But not while the engine is running… This has been a public service announcement courtesy of the ADV technical department… ![]() JJ
QUOTE from vermin I lie to myself because I am the only one who continues to believe me. johnjen screwed with this post 06-19-2010 at 07:23 PM |
