View Results:
0 0%
Voters: 0. You may not vote on this poll
Old 04-08-2006, 08:28 AM   #1
CarbonCat OP
CarbonCat's Avatar
Oddometer: 1,575
Pissed EWS Immobilizer antenna threadfest
Yesterday evening went out to restaurant(friends owned).
she still haven't seen my bike. well , we come outside and she is "wow , that bitch is tall, blah, blah, blah. I want to hear her sound"
so i put the key into the egnition lock wait for the sequence and nothing!
EWS! and the yellow triangle come on screen. - FUCK!!!
i pulled the key off the ring, since it together with the seat key(it's HP2). tried again - nothing.
so i pulled the bike into the restaurant, and left it there for the night, took her SV650 and came home.
I'm going to try today the secong plastick key, and i pray and hope that it's gonna work.
FUCK! i hope it's not a ring on the egnition , cuz the closest dealer is 120mi from me.
Any of you experienced same problem in the past? any suggestions?
Thanks a lot!
BMW R 1200 GS HP2
BMW R1200 GS Adv
Motorcycles are not my lifestyle - they are my life!
CarbonCat is offline   Reply With Quote
Old 04-08-2006, 08:37 AM   #2
GB
Mod Squad
GB's Avatar
Oddometer: 57,129
EWS is german acronym for the security encoded key and transponder.
Do you have a factory alarm on it? That could be the culprit.
If you don't have a factory alarm, people who have reported this problem before ended finding that the transponder ring around the hey hole needed to be replaced. Some dealers were clueless and spent much time looking for other things.. and in the end it came back to the ring around the key hole which "challenges" the key for the correct chip code to permit startup.
Let us know what you end up finding out...
Old 04-08-2006, 08:40 AM   #3
GB
Mod Squad
GB's Avatar
Oddometer: 57,129
If the bike dudn't start with the plastic key and you're still getting the EWS, call them for roadside assitance and pickup of the bike.
I don't know if this will help, but maybe if you disconnect the battery for half an hour and reconnect it and see if this helps...
Old 04-08-2006, 08:43 AM   #4
CarbonCat OP
CarbonCat's Avatar
Oddometer: 1,575
i know that part, and i hope it's a key.
no, it's GS HP2, doen't have any alarms. i didn't put any.
i'm afraid that's the issue(the fucking ring)
BMW R 1200 GS HP2
BMW R1200 GS Adv
Old 04-08-2006, 08:45 AM   #5
CarbonCat OP
CarbonCat's Avatar
Oddometer: 1,575
i will try the plastick key today, i hope it works!
yes i have the roadside card i will call them. i don't like the idea of my bike being a $20K statue in a Russian restaurant.
BMW R 1200 GS HP2
BMW R1200 GS Adv
Old 04-08-2006, 08:52 AM   #6
Renazco
Formerly AKA Boejangles
Renazco's Avatar
Oddometer: 4,742
Did you check that the kill button wasn't on??
Seats www.renazco.com
Parts & Accesories www.renazcoracing.com
Renazco is offline   Reply With Quote
Old 04-08-2006, 09:06 AM   #7
CarbonCat OP
CarbonCat's Avatar
Oddometer: 1,575
checked it , i never use it, but i checked it.
BMW R 1200 GS HP2
BMW R1200 GS Adv
Old 04-08-2006, 03:30 PM   #8
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,312
The EWS message pins it to the immobilizer system. It could be the key, the ring antenna or the BMS unit, but the antenna is most likely. In a way that would be better for you (you wouldn't lose one off the ten possible key IDs) but it would sure be easier for you to just fire it up with the plastic key...
Heck, maybe it's a bad connection at the antenna connector.
Old 04-08-2006, 04:55 PM   #9
CarbonCat OP
CarbonCat's Avatar
Oddometer: 1,575
OK, just came back from the restaurant....
FUCK, it was not the key!
i tried the second key and nothing.... disconected the battery waited for 10 min , connected back and nothing. i guess on tuesday i'm going to call roadside assistance and let them take the bike to the nearest dealer - 120mi .
BMW R 1200 GS HP2
BMW R1200 GS Adv
Old 04-08-2006, 04:56 PM   #10
CarbonCat OP
CarbonCat's Avatar
Oddometer: 1,575
is that something i can easily check? where is that POS???? is it an easy access, or half bike has to be taken apart?
thanks!
BMW R 1200 GS HP2
BMW R1200 GS Adv
Old 04-08-2006, 06:12 PM   #11
DirtMerchant
DirtMerchant's Avatar
Oddometer: 1,466
Just a thought
Couple suggestions
Have you checked the battery connections? Try jump starting it, I have used a car that IS NOT running when mine would not start; turned out the new software fixed that issue.
Also, check the wires that plug into the underside of the ingnition, I had this problem and that is what the tech told me after I had it hauled in. He said it clicked in place.
Have you done any work to the bike lately? GPS, Lights or etc? If so check the area you were working; something may have gotten disconnected.
BMW will send someone to get it but being that far away they may not cover 100% of the towing fee and I doubt they are going to bring it back to you.
Rodney
DirtMerchant is offline   Reply With Quote
Old 04-08-2006, 06:21 PM   #12
CarbonCat OP
CarbonCat's Avatar
Oddometer: 1,575
Originally Posted by DirtMerchant
Couple suggestions
battary connectors are tight, but i didn't try to jump start it.
i didn't do it, but i swing there tomorrow and check it out.
nope, bone stock.
Rodney
i know....
thanks
BMW R 1200 GS HP2
BMW R1200 GS Adv
Old 04-08-2006, 06:34 PM   #13
AntonLargiader
Oddometer: 4,312
Sorry, but I don't have an HP2 here to check! But you should be able to follow the wires pretty easily. The ring antenna is under the ignition lock. So the problem is in:
- ring antenna or cable
- antenna connector plug (where it plugs into main wiring harness)
- main wiring harness
- connector to BMS-K
- BMS-K
Most likely the antenna. Some have gone bad on other bikes.
Old 04-08-2006, 06:48 PM   #14
Renazco
Renazco's Avatar
Oddometer: 4,742
- BMS-K
I'll check mine but what the heck is a ring antenna?
Old 04-08-2006, 07:33 PM   #15
CarbonCat OP
CarbonCat's Avatar
Oddometer: 1,575
as far as i understand the ring antene is the black plastick ring around the ignition slut. i will try to look for what ever is under that and see if i can see something loose.
the main thing that scaries me now what hapenneds if shit like that hapenneds in the middle of nowhere. and BTW middle of nowhere are my favorite places to ride. another thing that is kinda stupid, they charge $20K for bike that has nothing, besides being a pure bike, so what the fuck they put that shit on it.
BMW R 1200 GS HP2
BMW R1200 GS Adv
Times are GMT -7.   It's 04:53 PM.
