View Results:
0 0%
Voters: 0. You may not vote on this poll
Old 05-15-2008, 09:23 AM   #1636
xlcr
Stop being a dick, dick.
xlcr's Avatar
Oddometer: 4,895
Originally Posted by Wallowa
And why is it less expensive?
Volume!!!
Volume!!!
Volume!!!
xlcr is offline   Reply With Quote
Old 05-15-2008, 09:53 AM   #1637
Wallowa
Oddometer: 5,409
Now XLCR That Is Funny!
Originally Posted by xlcr
Volume!!! Sick..
Volume!!! Sick..
Volume!!! Sick..
Hope you are wrong of course..
"In Wallowas"
2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!" After 2014 BOM my bike is forthwith the "GS McGee"!
Wallowa is offline   Reply With Quote
Old 05-15-2008, 05:34 PM   #1638
dometop
Oddometer: 51
Has anyone with a "#247" been stranded with the "EWS"? [Of course not doubting that it is 'the solution'! And why is it less expensive?]
The $60 reduction in the price is a revealing indication of how big the problem is. The less money the dealer charges back on the warranty claim the less impact on BMW's warranty budget.
dometop is offline   Reply With Quote
Old 05-15-2008, 07:39 PM   #1639
gsmoto31
Miami&Maggie
gsmoto31's Avatar
Oddometer: 72
Creative accounting!
This was more or less the explanation my dealer provided me earlier this month when I returned my 136 spare antenna for a "new" 237 antenna and got a $60 refund!
2009 BMW R1200GS (mountains)
2008 BMW R1200GSA (touring)
2009 BMW R1200R (commuting)
gsmoto31 is offline   Reply With Quote
Old 05-15-2008, 08:05 PM   #1640
xlcr
xlcr's Avatar
Oddometer: 4,895
Lower payout for waranty claims will look good on the quarterlies and provide quantifiable proof of improved reliability.
Some MBA is getting a bonus this year!
Old 05-15-2008, 08:15 PM   #1641
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,456
Interesting, I was on another forum and found this: LINK
Apparently there's a recall in Australia for the rings. Hmmn.
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is online now   Reply With Quote
Old 05-15-2008, 08:25 PM   #1642
Wallowa
Oddometer: 5,409
Hmmmm...Trust With Verification.
One Tech Manager sez doesn't make a recall...wish that it were true...if true it would hopefully open the flood gate and include not just the '08s..
"In Wallowas"
Old 05-15-2008, 10:36 PM   #1643
SocalRob
SocalRob's Avatar
Oddometer: 14,101
I think I've got it figured out. The new part number "247" will work 24 hours per day 7 days a week. The old ring "136" only worked 13 hours per day 6 days a week.
Thats why the errors were so random.
Rob
'07 White (the coolest color) GSA rider
'13 Husky Strada & '14 KTM 690 Enduro
SocalRob is offline   Reply With Quote
Old 05-16-2008, 12:20 PM   #1644
DaveT
Irv Seaver Parts
DaveT's Avatar
Oddometer: 417
from BMW Technical 2May8:
Subject: K2X (R1200) models all; EWS fault display in instrument cluster.
Situation: Motorcycle does not start. "EWS" is intermittently or permanently displayed in the instrument cluster.
Cause:
1. The battery was previously disconnected and was reconnected before the ignition was switched on for the first time.
2. There are increasing failures of the EWS ring aerial on motorcycles manufactured on or after 18.9.2006
Measure:
In rare cases, the BMS-K or BMS-K software may not have been booted completely correctly when the ignition is switched on. A fully booted BMS-K always shows the gear indicator in the instrument panel, provided that the gearbox potentiometer in NOT faulty.
1. If the "EWS" display appears in the instrument panel and the lowbeam headlight lights up when the ignition is switched on for the first time after the battery has been connected, it is NOT a ring aerial fault. It is a booting error in the BMS-K. Do NOT replace any parts.
Once the ignition has been switched on for a second time, the EWS system functions normally again.
In the event of an EWS complaint, please ask the customer whether the battery had previously been disconnected and whether the fault occurred the first time the ignition was switched on.
2. Please carry out interactive diagnostics on the EWS system using GT1. Move (pull, push, kink, etc.) the line, or wiring harness, during measurement of the EWS ring aerial to the BMS-K. Check for overtightened cable ties that may have cut into the wiring harness or otherwise damaged one or more lines. If you cannot find a fault by means of interactive diagnostics, GT1 will 1st prompt you to replace the EWS ring aerial. Proceed with the replacement of the EWS ring aerial. Please do NOT replace the BMS-K.
Dave Townsend
Parts Mgr, Irv Seaver BMW Motorcycles
Orange CA USA
DaveTownsend@IrvSeaverBMW.com
2005 R1200GS
2007 G650X-Challenge
DaveT is offline   Reply With Quote
Old 05-16-2008, 01:04 PM   #1645
Wallowa
Oddometer: 5,409
A translation Please?
Cause:
Measure:
So if the "EWS" comes on and the bike is immoblized and it is not the first time after the battery had been disconnected then the "aerial" is to be replaced?
So, we are to...replace the antenna if you get a "EWS" and the GT1 sez to replace?
Anything new here? Certainly not a recall mentioned in Oz...
Dave thanks for posting this from BMW Tech...
"In Wallowas"
Old 05-16-2008, 03:16 PM   #1646
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Quote: (Originally Posted by ridesumor)
[EWS failure...] Yep! About a two weeks ago... Had BMW Roadside tow to nearby dealer. Dealer has now replaced the "ring" to no avail, ordered an ECU, got the wrong one, and now another ECU due on TUES. Almost two weeks have elasped.
Quote: (Originally Posted by jpalamar)
And while the following is not necessarily directly related, Jim/Poolside has an old ECU from my '06 K12R. It's a perfectly good ECU BTW, but the reason the dealer had to put in a NEW ECU is simply because I wanted a spare key. Whatever code was supposed to be in BMW's database tying VIN and ECU together did not exist.
Nothing could be cobbed together to tie a VIN, ECU, on an existing bike. Seems nuts, and not relevant to this, unless, who knows.
OK...pundits of "it is the antenna" [which seems reasonable] what say ye about this?
Forget the pundits. Read what the BMW factory has to say.
From the 1200GS Technical Training manual:
Immobilizer code data structure.
The codes used during the handshake are generated from an Immobilizer Rolling Code table assigned to the VIN at the time of manufacturing. The BMS-K and corresponding ignition keys are encoded with this unique data making them an electronically mated pair for one particular motorcycle.
The [10 ignition key] code table [factory coded into the ECU] provides the codes for each key and a source for BMS-K to check the generated code for each key. Of the three [transponder] keys supplied with a new motorcycle, each one is uniquely identified (key #, ie: 1, 2, or 3). Each key additionally then has a unique immobilizer code.
During the key on sequence, the BMS-K first identifies the key sending the code data and then confirms the transmitted immobilizer code for that key. There is the possibility of a maximum of ten keys per system possible. However they must be ordered specifically by the VIN, and activated with the GT1.
Ten total keys can be used, per bike. The ten keys are coded into the ECU at the factory. Then activated at the dealer by the GT1 Diagnostic Computer.
Maybe the dealer is unaware of the EWS system capabilities. Maybe they are also unaware of the EWS manual override built into the GT1 software.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 05-16-2008, 03:51 PM   #1647
HMR71
Significant Pickle
HMR71's Avatar
Oddometer: 342
Interesting. Did anyone else get 3 keys with their GS? I only got one.
... and yes, I've already had the antennae failure.
'07 BMW 1200GS
'98 BMW 1100RT
'05 WeeStrom (Deerstrike Victim)
'05 KTM 950ADV (gone)
Assorted other bikes that I regret selling.
HMR71 is offline   Reply With Quote
Old 05-16-2008, 04:18 PM   #1648
Wallowa
Oddometer: 5,409
Translate For Me Please...
Ok...first as posted here...I and most owners only got two keys. A "real one" and a funky plastic one. That nothwithstanding where do you glean that there is a manual over ride for the EWS? Would love that, but I only see that there are 10 assigned key codes to the VIN and they can be activated by the GT1.
"In Wallowas"
Old 05-16-2008, 04:34 PM   #1649
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
You are starting to sound like an industry shill there Phil.
Old 05-16-2008, 05:54 PM   #1650
Wallowa
Oddometer: 5,409
Ah.. Discovered!
For a kid who grew up in Reno the word shill bust out a big smile! Naw I hate koolaid....
So PS what did you mean about a means of deactivating? An assumption if it can be activated it can also be deactivated? Hope springs eternal.
"In Wallowas"
Times are GMT -7.   It's 03:40 PM.
