View Results:
0 0%
Voters: 0. You may not vote on this poll
Old 05-27-2008, 08:17 AM   #1876
jpalamar
jpalamar's Avatar
Oddometer: 3,080
Originally Posted by buzzardchaser
Can anybody tell me if someone has reported a failer with the new antenna part #247. Could this be the final fix? Don't want to read thru 1700+ post. Does anybody have a failer with that part number? My 08' gsa craped out at 700 miles and I got a new antenna #247. I keep a spare antenna #247 with me anyway, but if my bike were to crap out again, would my back-up work since it is the same part number??
You may have provoked some confusion. Your bad ring was replaced with a 247 and you also have a spare 247, correct? Nothing wrong with that logic. I have a 247 in 2 out of three cycles and I still carry a spare 247. Not sure why some questioned that!
2007 R1200GS Adv DMC Hack
2014 R1200WCGS
jpalamar is offline   Reply With Quote
Old 05-27-2008, 08:42 AM   #1877
Wallowa
Oddometer: 5,480
Some Just Don't Believe This Is Real..
[quote=jpalamar]You may have provoked some confusion. Your bad ring was replaced with a 247 and you also have a spare 247, correct? Nothing wrong with that logic. I have a 247 in 2 out of three cycles and I still carry a spare 247. Not sure why some questioned that![/quote]
Not necessarily about the question of the failed antenna being a #247...but the dis-belief that the EWS problem is really a problem still permeates the air..
Man if #247 is a fix...I will be all over that! Getting stranded where I ride is not an option..
"In Wallowas"
2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!" After 2014 BOM my bike is forthwith the "GS McGee"!
Wallowa screwed with this post 05-27-2008 at 08:47 AM
Wallowa is offline   Reply With Quote
Old 05-27-2008, 10:46 AM   #1878
perobins
perobins's Avatar
Oddometer: 147
Picking up a spare Ring Antenna this week while I am in the USA. Just in case!!
perobins is offline   Reply With Quote
Old 05-27-2008, 10:53 AM   #1879
rideLD
The further the better!
rideLD's Avatar
Oddometer: 5,408
Originally Posted by worthydog
The poll didn't allow to register more than one EWS failure.
Thats alright. The Orange Crush guys will more than make up for it.
Karl | 2014 BMW R1200GSW Adventure | 2009 BMW G450x
Originally Posted by SchizzMan View Post
We pay Motorrad to design weight off the bike then pay TouraTech to bolt it right back on.
rideLD is offline   Reply With Quote
Old 05-27-2008, 12:36 PM   #1880
skmiller47
ImaFrayedKnot
skmiller47's Avatar
Oddometer: 8
Prior to understanding EWS failure and reading the threadfest, I experienced three (maybe four) intermittant failures. In all cases I switched off, then on again and had ignition. I believe that I had also shut the ignition by the kill switch, then key. And I continued to do so, though I don't any longer. This all ocurred at about 7k on an 07 built in 10/06. Since those incidents there have been none other. The OE antenna is a xxx-121.
After sorting the hysteria from the fact (or lack of) with this issue I felt it pudent to buy and store along a spare ring (247).
I found it interesting that the dealer I support (and respect), trade with does not stock the ring in any incarnation nor has ever replaced one. The next nearest dealer stocks (at the time I bought one) seven.
I voted NO in the survey as none of my experiences were the
"death knell".
Steve
07 r1200gs
02 r1150rs
74 CZ red frame
all others sold
Agoura CA
"You can sheer your sheep many times, but skin 'em only once" ......Moomat Ahiko
skmiller47 is offline   Reply With Quote
Old 05-27-2008, 02:24 PM   #1881
motoreiter
Oddometer: 1,245
Several people have asked fo the PN for the EWS harness; I haven't seen it posted so thought I would do so: 83300402327. If it matters, note that apparently this harness is classified as a tool rather than a part. Cost ~ $111.
motoreiter is offline   Reply With Quote
Old 05-27-2008, 02:41 PM   #1882
Wallowa
Oddometer: 5,480
What Is Purpose Of This "Survey"?
"death knell".
Again why are we indulging in this 'mock' survey? What is the purpose and hoped outcome?
The above, "No failure" vote is puzzling..."three maybe four intermittant failures? but since they were not "death knells" they were not failures?
I agree with hysteria statement sorta...there is zero justification for hysteria...but then I can't understand why folks keep trying to play down or minimize these EWS strandings and failures...I guess if you look the other way it doesn't exist..
This tread should by moved the antenna threadfest....
"In Wallowas"
Old 05-27-2008, 03:45 PM   #1883
Wallowa
Oddometer: 5,480
Thanks...A Question On Use..
Tell me again how we use this? To "permanently" wire in a spare antenna?
Thanks...
"In Wallowas"
Old 05-27-2008, 05:15 PM   #1884
GB
Mod Squad
GB's Avatar
Oddometer: 56,848
Might as well, it's outlived it's purported purpose. We'll merge it with the EWS threadfest .
Old 05-28-2008, 09:17 AM   #1885
JohnTz
HP2 Rider
JohnTz's Avatar
Oddometer: 156
Thanks...
+1
Don't trade them in, wear them out!
'12 Honda VFR1200
'12 KTM RC8R
'08 Suzuki Burgman 400
'79 Vespa P200E
JohnTz is offline   Reply With Quote
Old 05-28-2008, 09:29 AM   #1886
PRW
living @ 11.5740741uHz
PRW's Avatar
Oddometer: 1,092
When Im riding my motorcycle, Im glad to be alive and when I stop riding my motorcycle, Im glad to be alive. -Neil Peart
2008 R1200GS (Slate Gray Metallic Matt)
2003 R1150GS (Night Black)
PRW is offline   Reply With Quote
Old 05-28-2008, 09:38 AM   #1887
skmiller47
ImaFrayedKnot
skmiller47's Avatar
Oddometer: 8
In my absence of knowledge re the ongoing and serious EWS issue, I considered my experience to be an "interruption", interference only momentary. Each circumstance immediately corrected itself. Concerning? Yes. Could I duplicate the incident? No. The proverbial "fault not found". And now 3k miles have passed since these incidents.
Had I not been exposed to other's issues, I'd still be happily (and ignorantly) riding down the road, like now, without further incident (assumed). But having become informed, even without further incident, I bought a spare.
With regard to BMW's responce (read none) something should be initiated. In my understanding of recall foundation, I'm not sure this qualifies, but I believe a service action for replacement at next opportunity would be appropriate. That is considering the actual cause of fault is determined and that the replacement component proves to be faultless.
The vote part I consider "entertainment", as the thread has a large dose woven within.
Steve
07 r1200gs
02 r1150rs
74 CZ red frame
all others sold
Agoura CA
Old 05-28-2008, 05:27 PM   #1888
BMW Kurt
Bluesman
BMW Kurt's Avatar
Oddometer: 11,011
$82.20 at Chicago BMW. I think this tool may be convenient, but not necessary.
"We blew it." -- Wyatt in Easy Rider
BMW Kurt is offline   Reply With Quote
Old 05-29-2008, 09:49 AM   #1889
JohnTz
HP2 Rider
JohnTz's Avatar
Oddometer: 156
Kurt,
Can you please explain how do you use it? What does it do?
thanks,
John
'12 Honda VFR1200
'12 KTM RC8R
'79 Vespa P200E
Old 05-29-2008, 10:00 AM   #1890
jpalamar
jpalamar's Avatar
Oddometer: 3,080
Originally Posted by JohnTz
Kurt,
thanks,
John
If you understand the concept of disconnecting the harness from the 'key' antenna ring and using the spare, the harness is nothing but a long(er) extension cable that enables you to put the new ring/taped/zip-tied key in a more convenient space (e.g. under your seat) rather than this new ring with key dangling from a cable/handlebar. Neatens things up and [perhaps] gets the new ring out of harms way and is aesthetically more appealing. I thought I would get one, but decided to pass on it FYI.
2014 R1200WCGS
Times are GMT -7.   It's 01:06 PM.
