View Results:
0 0%
Voters: 0. You may not vote on this poll
Old 07-05-2007, 09:18 AM   #181
Bonebag
ADDvrider
Bonebag's Avatar
Location: Wisconsin..Hot,Cold and everything in Between
Oddometer: 5,381
Originally Posted by ClearwaterBMW
i believe he's wrong
afterall...
you have to have a ring antenna that recognizes only YOUR keys
i believe it has to be activated....
if that isn't true.... he's the only one on earth I know who has THAT information
Isn't the Antenna..just that..an antenna...
It's the bike's CPU that knows what key is what..no the Antenna?
Bonebag is offline   Reply With Quote
Old 07-05-2007, 09:23 AM   #182
Some Dude
what attitude problem???
Some Dude's Avatar
Oddometer: 4,757
afterall...
It's strictly a receiver and thats it, there is no logic or hard drive or anything to the antennae other then being a pathway for the key's code to get to the theft deterrant system, no programming required. The BMSK is already programmed with the correct key codes and as long as it gets that information it's good to go. While some of the shit on these things is rocket science, the ring antennea is not. Furthermore if the BMSK recognizes a failing EWS it will generate a code and then the GT1 at the dealer comes into play to clear that fault code. However on the couple that have failed around here, only 50% of them generated a component failure code.
Just some dude on the internet,..
Some Dude is offline   Reply With Quote
Old 07-05-2007, 10:39 AM   #183
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,285
afterall...
Before, you sounded pretty certain. :)
Just as Bob describes, the antenna is just a part, like any other sensor. And every tech who's gone through training knows this, not just that one dude.
Old 07-05-2007, 10:46 AM   #184
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,752
Nice to know. Now a couple stragegically placed antenna rings around the country, and overnight mail, and problem solved!
I am feeling MUCH better about this situation now.
I might even spring for one. Maybe we could have an ADV antenna pool?
Jim
Old 07-05-2007, 11:02 AM   #185
GB
Mod Squad
GB's Avatar
Oddometer: 56,839
wouldn't that be pathetic?
How about an antenna group buy?
Bobby: Thanks for the info on how to unplug the antenna.
Old 07-05-2007, 11:06 AM   #186
JimVonBaden
"Cool" Aid!
Oddometer: 53,752
It IS sad the even "I" sometimes fall into the internet fear frenzy, being that I am usually the one cautioning against it.
The difference with this one is, for me, that there is now warning. I can fix most things, and see them coming, but this is a knockout blow that is not detectable.
Oh well, I am likely worried about nothing, and am not really THAT worried. Bobby says most of them happen to low mileage bikes, and that doesn't apply to mine!
Jim
Old 07-05-2007, 11:21 AM   #187
Pir8te
over forty victim of fate
Pir8te's Avatar
Oddometer: 1,449
is it possible
Bobby
If I follw this thought
then could you place the EWS ring and antenna together in a out of the weather place on the bike and then use a regular key to start the bike ?
Pir8te is offline   Reply With Quote
Old 07-05-2007, 11:21 AM   #188
Some Dude
Some Dude's Avatar
Oddometer: 4,757
Jim
There's a spare one heading up the interstate towards Road America in the Safari side bag of an HP2 right this very moment
Old 07-05-2007, 11:25 AM   #189
Some Dude
Some Dude's Avatar
Oddometer: 4,757
Originally Posted by Pir8te
Bobby
Correct, but I do not feel failures are weather related as much as electrical component failure percentages. It truly is a rare event, but show stopper non the less if it does happen. I'd worry about it maybe just a tad more then Dr ABS's concerns in the scale of things. Difference here is it's not a safety issue and you can plan for the inevitable as it's easy to fix and pack with you. It would definitely be a piece to pack if let's say a group of R12's were heading on a long road trip. Just be careful removing or cutting the tie wraps holding the wiring harness in place around the ignition switch/antennae area. We are fixing a K12GTtoday that another dealer replaced the antennae on a little bit ago and just barely clipped one of the ignition wires, it broke on a road trip yesterday while the gent was in our neck of the woods, we're fixing it now.
Old 07-05-2007, 11:49 AM   #190
BriKielyGSman
BigBadBri
BriKielyGSman's Avatar
Oddometer: 511
Mileage
Larry's bike had 11,000 miles on it when it crapped out. He said if it would have happened about two days earlier, he would have needed a helicoptor to get him out!!!
The dealer in Edmonton only had the part by fluke-it was for another customer.
I know I will be taking a spare to South America in September. My bolts are drilled out already and I just have to make sure I have the proper tools for the swap.
www.bckgs.blogspot.com - don't be scared - check it out!!
BriKielyGsMan's South America Ride Report - Two Up.
http://www.advrider.com/forums/showthread.php?t=259451
BriKielyGSman is offline   Reply With Quote
Old 07-05-2007, 12:02 PM   #191
BriKielyGSman
BigBadBri
Oddometer: 511
got a call
Just got a call from the dealer- says they cannot just order that part. Need to prove ownership etc with BMW before they can even order it. Hence the reason that no one stocks it??
Old 07-05-2007, 12:02 PM   #192
Redbull Addict
I need another one...
Redbull Addict's Avatar
Oddometer: 1,262
this is really good to know. Mine crapped out on my first DV trip at 1100 miles and I was stranded about 160 miles from home. The EWS light came on and I thought I was finished. As odd as it sounds I kept playing with the engine kill switch and I replaced my key with the plastic one and the bike started up. I rode it home without shutting it off. the next day it started up fine. Went to the dealer who did not find a fault. It's been 8 months now and 5K miles later and no repeat. I still wonder if it will ever show up again. I just might spring for it also.
Redbull Addict is offline   Reply With Quote
Old 07-05-2007, 12:24 PM   #193
gpothoven
whatever
gpothoven's Avatar
Oddometer: 2,129
Thanks again for the valuable info. You guys know or suspect what is causing the problem or how to avoid it?
gpothoven is offline   Reply With Quote
Old 07-05-2007, 12:30 PM   #194
JimVonBaden
"Cool" Aid!
Oddometer: 53,752
"Oh dealer, my EWS just went out, I need another one, but can't get the bike in there. Can you ship it to my friend's house in..."
There are ways... Besides, stupid comment from the dealer. If the key is still needed for it to work, what is the point in not selling one? Useless without the original key!
Jim
Old 07-05-2007, 12:36 PM   #195
gpothoven
whatever
gpothoven's Avatar
Oddometer: 2,129
Ignore your dealer and order from here: www.maxbmwmotorcycles.com
Model: R1200GS ADV Diagram #51_5341
No Part Number Description Qty Each
01 51257700072 steering lock housing BUY 1 $111.00
02 61317675111 ignition/light switch BUY 1 $56.00
03 51252313544 fracture bolt (M8) BUY 2 $2.00
04 07119904919 flat washer BUY 2 $0.50
05 51252313185 o-ring BUY 1 $2.00
06 61357696463 ring antenna BUY 1 $155.00
07 51257692011 covering cap BUY 1 $8.20
08 61117651630 screw (M3X20) BUY 2 $0.75
Times are GMT -7.   It's 04:58 AM.
