View Results:
0 0%
Voters: 0. You may not vote on this poll
Old 07-05-2007, 01:08 PM   #196
adamr
adamr's Avatar
Oddometer: 143
Originally Posted by BMW Atlanta
Furthermore if the BMSK recognizes a failing EWS it will generate a code and then the GT1 at the dealer comes into play to clear that fault code. However on the couple that have failed around here, only 50% of them generated a component failure code.
Do I need to clear the fault code before the bike will start (assumming I've replaced the antenna)?
adamr is offline   Reply With Quote
Old 07-05-2007, 01:32 PM   #197
ClearwaterBMW
The Examiner
ClearwaterBMW's Avatar
Oddometer: 4,744
Send a message via AIM to ClearwaterBMW Send a message via Skype™ to ClearwaterBMW
It's strictly a receiver and thats it, there is no logic or hard drive or anything to the antennae other then being a pathway for the key's code to get to the theft deterrant system, no programming required. The BMSK is already programmed with the correct key codes and as long as it gets that information it's good to go. While some of the shit on these things is rocket science, the ring antennea is not. Furthermore if the BMSK recognizes a failing EWS it will generate a code and then the GT1 at the dealer comes into play to clear that fault code. However on the couple that have failed around here, only 50% of them generated a component failure code.
i appreciate the education... thanks
so....
how long IS the backorder on the ring antennas these days?
Greg
'07 K1200 GT
'11 R1200 GS Adventure with a DMC M72DX Sidecar
live life like you mean it... but take your family and friends (and DOGS) along for the "ride"
ClearwaterBMW is offline   Reply With Quote
Old 07-05-2007, 01:46 PM   #198
Some Dude
what attitude problem???
Some Dude's Avatar
Oddometer: 4,609
Send a message via AIM to Some Dude
Nope, bike will run just fine with a stored fault as long as whatever component caused the failure is not failing any more.
Just some dude on the internet,..
Some Dude is offline   Reply With Quote
Old 07-05-2007, 01:52 PM   #199
adamr
adamr's Avatar
Oddometer: 143
Thx, lots of good info here.
BTW, mine failed at 1500 miles.
Old 07-05-2007, 01:59 PM   #200
bemiiten
SWM Adventuer
bemiiten's Avatar
Oddometer: 4,150
I'm happy to hear that the antenna can be repaired without needing to ship the entire bike to a dealer. That makes all the difference to my perception of the machine. Still will be out of luck if the parts are on backorder.
bemiiten is offline   Reply With Quote
Old 07-05-2007, 02:08 PM   #201
Bonebag
ADDvrider
Bonebag's Avatar
Location: Wisconsin..Hot,Cold and everything in Between
Oddometer: 5,168
I just ordered one from Max...it's in stock and on it's way
Bonebag is offline   Reply With Quote
Old 07-05-2007, 02:26 PM   #202
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,285
Will someone post up a coupla nice pictures of the EWS antenna electrical connector? Unplugged and plugged. Also close focused pictures of the end of the connector on the wire and he connector socket on the antenna since you're there.
You'll be glad you did.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List
Poolside is offline   Reply With Quote
Old 07-05-2007, 02:30 PM   #203
ClearwaterBMW
The Examiner
Oddometer: 4,744
true....
but, you HAVE to have the original DRILLED out first....
and replace with the specific bolts mentioned above
otherwise... you will have that new ring antenna "in stock" but not be able to utilize it
Greg
'07 K1200 GT
Old 07-05-2007, 02:31 PM   #204
Bonebag
ADDvrider
Bonebag's Avatar
Oddometer: 5,168
good Idea...
How's this one..I should have my Antenna by the end of next week. I'm leaving on a trip out to next weekend otherwise I would not have spent the money on this part..especially since it would be covered by warranty. How about we start a small list on who has these antennas as spares so if someone is in dire need..one of us could overnight the baby to help them out
Old 07-05-2007, 02:33 PM   #205
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,488
Originally Posted by Bonebag
good Idea...
Good idea:
Originally Posted by JimVonBaden
Nice to know. Now a couple stragegically placed antenna rings around the country, and overnight mail, and problem solved!
I am feeling MUCH better about this situation now.
I might even spring for one. Maybe we could have an ADV antenna pool?
Jim
Old 07-05-2007, 02:35 PM   #206
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,285
You post pics, Mongo make fix. Mongo know about radio.
Old 07-05-2007, 02:37 PM   #207
Some Dude
Some Dude's Avatar
Oddometer: 4,609
Originally Posted by ClearwaterBMW
true....
Wrong again, you can utilize it, it just wont be pretty and it may take a few jerry-rigged tie wraps to getrdun successfully. The location for the antennae will not be optimal, however as long as the antennae is in close proximity to the key when the switch is engergized it should work just fine.
Old 07-05-2007, 02:45 PM   #208
ClearwaterBMW
The Examiner
Oddometer: 4,744
while i DO thank you for your information
i do NOT appreciate the "WRONG AGAIN" remark
it's offensive (at least to me)
you are a dealer.... and you should speak to us as if we were at your counter in your shop
so.... please remember that you should be a bit nicer to the MANY of us on the forum who've spent plenty of money at your dealership.... LIKE ME
thanks for the info
i appreciate being set straight
Greg
'07 K1200 GT
ClearwaterBMW screwed with this post 07-05-2007 at 03:17 PM
Old 07-05-2007, 02:49 PM   #209
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,285
Pictures = Solution Go take some pictures Bobby.
Old 07-05-2007, 02:55 PM   #210
Some Dude
Some Dude's Avatar
Oddometer: 4,609
Mod edit: We can all get along
Stop you're crying You're just on a roll today with what seems to be pretty solid assertions by yourself, perhaps refraining from making statements and asking questions would be a better approach?????
and it is what it is so stop whining, would you rather go on incorrect assumptions and not have anyone correct? It's not meant personal, it's just straight to the point. You can take it as egotistical, but it's just my jackass playful personality This is ADV Rider afterall, not some stuffy regulated site correct?
GB screwed with this post 07-05-2007 at 04:17 PM
Times are GMT -7.   It's 07:02 AM.
