View Results:
0 0%
Voters: 0. You may not vote on this poll
Old 07-14-2008, 06:35 AM   #2791
cjack
cjack's Avatar
Oddometer: 858
Originally Posted by Wallowa
Can the active antenna [one plugged in] pick up and read the key in the ignition? Do you really need that spare key laying in it? Have you tried it without spare key?
When I tried holding the active antenna ring near the ign (and key) I got various results depending on how close I put the ring. Some have found it to work reliably, but I found it works better to place a spare key in the active antenna.
My other bike is a BMW
Jack
RA & MOA #224
cjack is offline   Reply With Quote
Old 07-14-2008, 07:36 AM   #2792
Wallowa
Oddometer: 5,452
Thanks...Good Info.
Thanks for actual experience with keys/antenna/proximity.
Gyro...If you do have an antenna failure it is the first 2005 I have heard of having one..but as you say with all the posts on this forum and numerous other ones who knows..I could have missed it.
It was my understanding also that keys do not "contaminate" keys but two keys can confuse the antenna..
Also buried in these posts are "EWS' warnings generated by dead or dying battery....not in my owner's book, but folks have reported it.
"In Wallowas"
2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!" After 2014 BOM my bike is forthwith the "GS McGee"!
Wallowa is offline   Reply With Quote
Old 07-14-2008, 07:59 AM   #2793
PacWestGS
Life Is The Adventure!
PacWestGS's Avatar
Oddometer: 10,866
My bike's in getting the new RF ring and computer updates. I also purchased a spare RF antenna just in case (cheap insurance).
Also, as it was explained to me the spare antenna does not need to stay connected if the main one fails. Remove the two little Torx screws and pull the circut box, unplug it and plug the wire into the new antenna. Put one key in ignition and hold the other key near the ring. Start bike - then unplug and remove the spare antenna and place in safekeeping spot until needed again. If at that point you get home without turning the bike off well, you only need to do this once.
The bike runs, you only need the antenna during start-up.
Russ
The world is a dangerous place to live, not because of the people who are evil, but because of the people who don't do anything about it. (Albert Einstein)
PacWestGS is offline   Reply With Quote
Old 07-15-2008, 04:08 AM   #2794
st247
st247's Avatar
Oddometer: 103
Numbnuts, wrong bloody thread.
st247 screwed with this post 07-15-2008 at 10:02 AM
st247 is offline   Reply With Quote
Old 07-15-2008, 06:28 AM   #2795
cjack
cjack's Avatar
Oddometer: 858
Originally Posted by bonox
May I ask where you guys are reading the number from?
I have a 2007 model (09/2006 plated), for which the square antenna block with the wires running to it (and sitting in front of the key barrel)
reads
4135 7696463-10
PBT GF20 < REC25
FCC ID QB4 1417121
Have I got a different one to the 136, 207, 247 models, or am i not looking in the right spot?
The first one to fail somewhat was the 463. Then came the 207 and the 136 which seems to fail before you get out the door. All are involved in the Campaign.
[quote=Phil}
Phil
"In Wallowas"[/quote]
That was also the subject of a note by BMW to the dealers that they should check if the customer had a flat or disconnected battery. This could generate an EWS warning, and simply turning off the ign and back on should clear it in this case. The message to the dealer was not to consider this event as a fault of the EWS and no further action needed to be taken.
Jack
RA & MOA #224
Old 07-15-2008, 07:40 AM   #2796
PRW
living @ 11.5740741uHz
PRW's Avatar
Oddometer: 1,092
Originally Posted by Gyromaniac
After an hour of trying, waiting, trying again, I figured the key needed electrolytes, so I . . . ahem . . . wiped it under my armpits (I was camping, remember) and I'll be darned if it didn't start up.
So, what is the official, legitimate fix for thie idiotic EWS problem when you're way the hell away from your spare key?
TIA
The new legitimate solution for EWS! Failures: Make sure you always have nasty, sweaty, stinky armpits and you won't ever need to worry about carrying a spare antenna ring!
When Im riding my motorcycle, Im glad to be alive and when I stop riding my motorcycle, Im glad to be alive. -Neil Peart
2008 R1200GS (Slate Gray Metallic Matt)
2003 R1150GS (Night Black)
PRW is offline   Reply With Quote
Old 07-15-2008, 11:20 AM   #2797
PackRat
Huey Guns
PackRat's Avatar
Oddometer: 1,455
Originally Posted by Signal
, But somehaow there HAS to be a way to go "back", and simply remove the EWS for a plain-old-key system
Surely you jest - the lawyers will not let them!
Common sense isn't!
"Packrat" IBA# 11205, AARP, ATP, CFI, A&P, USMC
__________________________________________
Rigor Mortis will be the first indication that I've grown up!!
Yungas Rd.-Bolivia, Alaska '08 - Labrador '10 -
PackRat is offline   Reply With Quote
Old 07-15-2008, 01:03 PM   #2798
PNW08
Oddometer: 14
one key works
Mine just failed while getting off the wa. state ferries into seattle. Nice push since I was late getting on I was in the back . Had to push the full length then up the ramp with my GSA loaded. They did help push up the ramp thank god. Though they had to remind me that it is usually HD's that are pushed off not BMW's.
I have been packing a spare antenna ever since the forum has been reporting the failures. I hooked up the spare put my plastic key in the ignition put the spare over the top off the plastic key and she started right up. There is enough of a lip on the spare to keep it in place while over the plastic key. No need for a second key laying there. Been running like this for a week now till I can get into the dealer no problems.
PNW08 is offline   Reply With Quote
Old 07-15-2008, 01:34 PM   #2799
xlcr
Stop being a dick, dick.
xlcr's Avatar
Oddometer: 4,895
Sorry if this has been covered; I quickly scanned the 180+ pages on this topic.
This morning, after camping out at 5,300 feet near the divide in Montana, my 2005 1200GS gave me the EWS warning; I'd slept on top of my Aerostich, with several keys in the pocket; now I see my rider's guide says that's a no-no. After an hour of trying, waiting, trying again, I figured the key needed electrolytes, so I . . . ahem . . . wiped it under my armpits (I was camping, remember) and I'll be darned if it didn't start up.
TIA
Brawndo: It's got what keys crave!
xlcr is offline   Reply With Quote
Old 07-15-2008, 05:53 PM   #2800
Racegun
Single Track Mind!
Racegun's Avatar
Oddometer: 2,566
Question
Originally Posted by rideLD
If your 07 has more than 6000 miles on it, chances are good that if it were going to fail it would have already. Check your vin against the campaign chart because some of the early 07's were not even effected. Carrying a spare is probably a good idea but there's no need to run down to the dealer and delay your trip.
My 07 has 22,000 miles on it and I have no concerns about my EWS going south on the 3000 mile ride I am leaving on next week. My VIN is listed in the "campaign" but I'm really not worried. These things fail early in their life.
ARE YOU going to bring spare antenna ring?
Cheers!
Dave
Racegun is offline   Reply With Quote
Old 07-15-2008, 05:58 PM   #2801
PacWestGS
PacWestGS's Avatar
Oddometer: 10,866
All done, I can leave my Rosery at home now...
Russ
Old 07-16-2008, 04:50 AM   #2802
ylexot
Super Genius
ylexot's Avatar
Oddometer: 780
ylexot is offline   Reply With Quote
Old 07-16-2008, 05:54 AM   #2803
Remy
Woe is uh a me bop!
Oddometer: 880
I left mine at the shop yesterday to have the various campaign issues done. There was a guy there with an '07 and a little over 7000 miles. He was from Missouri and had an EWS failure on Sunday.
Remy is offline   Reply With Quote
Old 07-16-2008, 05:58 AM   #2804
jpalamar
jpalamar's Avatar
Oddometer: 3,080
Did you make him 'Show You?'
2007 R1200GS Adv DMC Hack
2014 R1200WCGS
jpalamar is offline   Reply With Quote
Old 07-16-2008, 06:03 AM   #2805
Remy
Woe is uh a me bop!
Oddometer: 880
Heh heh heh! No, but I did watch them push his bike to the service area. He was a nice guy and took it all in stride.
Times are GMT -7.   It's 10:06 PM.
