View Results:
0 0%
Voters: 0. You may not vote on this poll
Old 07-18-2008, 09:40 AM   #2821
stevie88
That's gotta hurt
stevie88's Avatar
Oddometer: 19,116
Originally Posted by Wallowa
Steve...do as I do in my shop..my '07 GSA is always on the BMW [expensive but it works] battery charger pluged into the power outlet behind seat..or it is being ridden!
I have the semi expensive BMW charger, you know, it's the one that the Can-bus system tells to pound sand, hooked directly to the very black battery right now. BTW, when I bought my RT in 05 I purchased that charger from my dealer because it is supposed to work through the Can-bus.
stevie88 is offline   Reply With Quote
Old 07-18-2008, 09:44 AM   #2822
Wallowa
Oddometer: 5,409
Hmmmm..
Originally Posted by jpalamar
Hi Phil,
Just thought I interject some comments re: batteries and chargers. I have the expensive one and don't use it at all. It's a shortcoming on my part in that I just don't trust the handshaking with the CAN-bus being consistent. Also, JVB has f*ed up my head (as have others) that leaving the bike on a charger is nonsense if you ride regularly, which we do in FL
I recently came back from a two week road trip and found the battery in my '07 ADV tits up! (garage talk for NFG). Trekked[the bad battery] it to BMW Daytona and was informed that yup, it's NFG. I was also told the black ones (mine was black) were failing a lot more than gray ones They gave me a gray one. So, back to JVB and my Deltran Battery Tenders that are supposed to stop sulfation a la float charge, blah, blah. Did I fry the battery? Hmmmm? Good question, likely will never know for sure. So have compromised my regimen, I now only wait until the Battery Tender renders a glowing green/full-charge and I disconnect the damn things. Thanks Jim, for screwing with my head!
And I offer the following comment that I did not originate: With a small enough data sample one can prove just about anything!
Following the protocol of hooking up the BMW battery charger for use of the outlet and with "Glass Matt" batteries I have never had any problems with the initiation ["hand shake"..it is very simple] or having the charger run the battery through the correct charging sequences...nothing against any other brands but the BMW sequencing charger flat works....but I do know that using an incorrect charger or allowing them to totally discharge can ruin the battery.
So far it is working great for me..
"In Wallowas"
2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!" After 2014 BOM my bike is forthwith the "GS McGee"!
Wallowa is offline   Reply With Quote
Old 07-18-2008, 09:50 AM   #2823
tagesk
Tuscan rider
tagesk's Avatar
Oddometer: 3,227
Thumb
Originally Posted by SCQTT
Nope, possibly a Euro requirement, but not mandated here.
It might be changing, but BMW theft here was very tiny.
The people looking for used parts are so anal about where they come from and the history of how it was used that it is too much trouble to move used parts. (I think thats a good thing) Like I said that might be changing.
Sportbikes are stolen here just for their bodywork. HDs are hard to hold onto as well.
Regardless of how many bikes gets stolen, and regaardles of whetehr we here or you there like it, according to documents posted here a few thousand posts ago by the Honorable Mr. Poolside, a theft-prevention system has been made mandatory by DoT. BMW complied. We on the Old Continent are not pleased.
On another note: Calling the Honorable Mr. Poolside!
"Now that BMW is recalling the faulty antennas, and the EWS error will nto be seen again, is there any chance at all that we will ever get to know the procedure for manual override?"
I solicit your comment.
[TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk is offline   Reply With Quote
Old 07-18-2008, 05:14 PM   #2824
xlcr
Stop being a dick, dick.
xlcr's Avatar
Oddometer: 4,895
I don't think the anti-theft requirement applies to motorcycles. I've searched for DOT waivers for motorcycles and nearly all are for approval to divert euro-spec bikes to the US market. There are plenty of waivers for passive theft-deterrent system on automobiles, but none for bikes.
My guess is that BMW took it upon themselves to (poorly) implement some flashy feature from their car line as a sales gimmick and it's biting them in the ass.
xlcr is offline   Reply With Quote
Old 07-18-2008, 06:18 PM   #2825
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
That's right.
Motorcycle manufacturers generally do not design and build their own ECU. Instead they source their motorcycle ECUs from automotive ECU makers.
The ECUs are designed for automobiles, and the EWS Immobilizer software and hardware is already built-in to the ECU.
Immobilizer software and hardware *complete* with Immobilizer Manual Override.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 07-19-2008, 11:31 AM   #2826
cjack
cjack's Avatar
Oddometer: 857
Originally Posted by Poolside
That's right.
I have been informed of some failures of the latest newest ring...so it may be time for the ultimate fix. Immobilizer Manual Override.
My other bike is a BMW
Jack
RA & MOA #224
cjack is offline   Reply With Quote
Old 07-19-2008, 05:45 PM   #2827
Flash1034
Flash1034's Avatar
Oddometer: 334
I have had no failures since the recall or before for that matter. FYI
Flash
Flash1034 is offline   Reply With Quote
Old 07-19-2008, 08:04 PM   #2828
Wallowa
Oddometer: 5,409
Can you be more explicit? Hate being kept in suspense waiting for the 'other shoe to fall'.
"In Wallowas"
Old 07-19-2008, 08:53 PM   #2829
cjack
cjack's Avatar
Oddometer: 857
No suspense. I just know a mechanic at a major dealership who has had to replace a couple or few of the newest number...247. He told me to continue to keep a spare handy. Probably a good idea anyway.
As for the override idea, it kind of torques me off that we have this issue and I think it would be best (although I don't know all the issues) if we had a manual override with a pin #.
Jack
RA & MOA #224
Old 07-21-2008, 05:17 AM   #2830
PRW
living @ 11.5740741uHz
PRW's Avatar
Oddometer: 1,092
Jack - while I suspect that the ECU likely has the inherent capability, I believe that BMW has not leveraged the feature with any user I/O mechanism/procedure to enter an override code sequence.
When Im riding my motorcycle, Im glad to be alive and when I stop riding my motorcycle, Im glad to be alive. -Neil Peart
2008 R1200GS (Slate Gray Metallic Matt)
2003 R1150GS (Night Black)
PRW is offline   Reply With Quote
Old 07-21-2008, 05:39 AM   #2831
jpalamar
jpalamar's Avatar
Oddometer: 3,080
Unless software and/or the charger has changed, once the CAN-bus 'port' closes, this charger for all intents and purposes cannot serve as a long term charger. That is, the LEDs show full charge, but the port never re-opens even tho' parasitics are drawing current. My understanding is that some of the dealerships (e.g. Daytona) where customers leave their bikes on this charger all summer and return in the fall (snowbirds) they have found their batteries dead; not so with the BMW/Deltran Battery Tenders directly wired.
2007 R1200GS Adv DMC Hack
2014 R1200WCGS
jpalamar is offline   Reply With Quote
Old 07-21-2008, 07:54 AM   #2832
Wallowa
Oddometer: 5,409
Please Explain..
John,
Sorry I did not follow that....are you saying that the BMW battery charger listed in the Owner's Manual [don't have number right now] that allows charging through the accessory outlet port may fail to charge the battery even if the correct intialization sequence was followed? I have been using mine for over a year and during the winter there isn't any riding here, so it has sat on the charger for at least 5 months without being run. Perhaps I am just mis-understanding. If folks are finding dead batteries after leaving it plugged in..my bet is that they never correctly hooked it up...as you know a very specific sequence is required.
Oh yes you mentioned the LED showed full charge..it periodically cycles through all the LEDs hence there should be times when the green light is not on...
"In Wallowas"
Old 07-21-2008, 03:30 PM   #2833
BMWRich
BMWRich's Avatar
Oddometer: 1,575
Well,I guess 3X's a charm!
Just heard about friend who has posted here in the past about having "two a'ring failures" just lost another one. Luckily he had an extra one with.
Supposedly he an his wife,(the wifes bike is the one with the multiple failures) are still on the road coming home,so info is still sketchy.
I'm curious as to what the "a'ring part # is" that failed.
Man talk about havin' bad luck....
2007 GS Adv
Everybody likes a little ass,..but nobody likes a smartass...
BMWRich is offline   Reply With Quote
Old 07-21-2008, 03:45 PM   #2834
alfaris
MOTERO TORERO
alfaris's Avatar
Oddometer: 1,154
Eh?
does anyone have reports of any 2006 HP2 Enduro with EWS failures? i still do not know anyone.
09 KTM 530 EXC
07 XR650R
alfaris is offline   Reply With Quote
Old 07-21-2008, 05:23 PM   #2835
CATGS
Bourbon consumer
CATGS's Avatar
Oddometer: 714
Failure
Well, my 08 failed on the way out to Gillette.. Good thing I bought a 247 as a back-up on the way out. I was in the middle of no-where Nebraska when it let got. My 08 GSA failed with roughly 2000 miles. Sturgis BMW wouldn't get me in to fix, so I am still riding on the 247 spare. Oh, joy....
DMP
____________________________
http://www.springfieldmilers.com/
CATGS is offline   Reply With Quote
Times are GMT -7.   It's 11:17 PM.
