View Results:
0 0%
Voters: 0. You may not vote on this poll
Old 01-15-2011, 11:25 AM   #3196
Pathfinder2
Oddometer: 4
No power
I have broused the multiple comments about ring issues of which I experienced on my previous 1200 GS adventure and had factory recall fixed on my F8gs. However, todays problem is different in that when I turned the key on my f8gs (it has 29K maintenace failure free miles) I got nothing. Nothing in the instrument panel, no lights, no horn, nothing. One of my more knowledgable friends gave it a look and gave the handle bars a few lock to lock pushes and miracle; all is well. The ignition came on, instrument panel responded as normal and engine started like always. Now I have a concern with why and when will it happen again. Stuff don't fix itself normally. Any suggestions on cause or potential fixes would be appreciated.
Pathfinder2 is offline   Reply With Quote
Old 01-15-2011, 12:38 PM   #3197
Synisalo
Adventure wannabe
Synisalo's Avatar
Oddometer: 103
Id say you have a loose / chaffed wire in the harness form the ignition switch. Best track that down pronto before it leaves you stranded.
I often wonder why I am still alive with all the dumb things I have done... Then logic gets the better of me, and I wonder why I am not dead.
Synisalo is offline   Reply With Quote
Old 01-15-2011, 06:21 PM   #3198
Pathfinder2
Oddometer: 4
Thanks. I will start the search.
Old 04-19-2011, 08:46 PM   #3199
CrustyAPO
CrustyAPO's Avatar
Oddometer: 439
Originally Posted by genka View Post
This thread has been inactive for a long time, which is great. I didn't read everything, but it seems that all ring failures had been on new bikes. I have a 2007 with "bad" part#. If the ring has survived until today, should I be concerned or can I assume that I got a quality part?
Genka,
Recently, a friend who tows for a local repair shop had a call for a BMW bike that wouldn't start. He knew I might be able to troubleshoot it so he asked me to look at it. It was a brand new, 2007 F800S that was purchased in Nov of 2010. The owner had only put the first 236 miles on it over a warm weekend (3/9/2011). When it quit on him it was showing "EWS" on the LCD display so I knew what the problem was before it got to my house. When it got to my house, I checked the Antenna Ring part number and it was a #247. Then I looked at the fasteners holding the ignition switch and they were socket head cap screws, so I knew it had been replaced. So I ordered a new antenna ring from Max BMW and installed it, problem solved. I called Max back, and told them what happened and they said they would cover it under warranty and send me a replacement antenna. I'm telling you all of this because I just wanted to let you know that the #247 antenna rings are not immune to failure. This bike had obviously had it replaced as part of the recall, but was never ridden until the new owner got it out this spring. I can't believe the original replacement lasted only a short time.
Yeah, and maybe I'm a Chinese jet pilot.
CrustyAPO screwed with this post 04-19-2011 at 10:37 PM
CrustyAPO is offline   Reply With Quote
Old 04-20-2011, 04:56 AM   #3200
genka
SUV hater
genka's Avatar
Oddometer: 1,625
Well, anything can fail, but I wanted to get rid of the part with unusually high failure rate. I'm glad that BMW covered it even after warranty expiration.
Форум мотоциклистов в США http://www.xytopok.net/mvnforum/listthreads?forum=31
genka is offline   Reply With Quote
Old 04-20-2011, 05:04 AM   #3201
saitman
Oddometer: 15
I believe is the antena ring!!
saitman is offline   Reply With Quote
Old 05-23-2011, 07:48 AM   #3202
fuhgawee
Thats a road?
fuhgawee's Avatar
Oddometer: 1,584
EWS failure this weekend 110 miles from home. 07 gs 22k, orig. owner.
Ring was replaced lil over a year ago but not with the 247 module. Now I'm
1) trusting BMW for solving the problem.
2) not doing my homework and carrying a spare ring,
right beside the spare final drive and fuel bypass wiring.
I have to laugh, mins before I stopped for lunch I thought I love this bike, I
dont care if they are prone to breaking down.
fuhgawee is offline   Reply With Quote
Old 03-02-2012, 05:25 AM   #3203
leafman60
Oddometer: 1,855
Just amazing ! What if another brand was having all these troubles ? We'd be making fun of them big time !!!
leafman60 is offline   Reply With Quote
Old 03-02-2012, 05:37 AM   #3204
drmajor
drmajor's Avatar
Oddometer: 534
Ews
I had my EWS replaced. Been OK so far and not sure, but think it was the new part #.
Do you know the part number for the new one?
Seems I heard there was a hard wiring work around in emergency??? anybody know how to by-pass this thing to get home?
drmajor is offline   Reply With Quote
Old 03-03-2012, 10:46 PM   #3205
tagesk
Tuscan rider
tagesk's Avatar
Oddometer: 3,227
Thumb
It is likely that if we knew of such a procedure, this thread would not have 3200 messages in it.
[TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk is offline   Reply With Quote
Old 03-04-2012, 12:32 PM   #3206
marty hill
The Energizer Bunny
marty hill's Avatar
Oddometer: 4,271
I remember seeing a work around posted when this was a big problem. No idea where it hiding/younger and smarter members will have to find it. My failing memory tells me that one could attach the spare without undoing the old one till you got home.
TaSK, as an aside I am now riding my GS to Knoff in orlando to be shipped to Heidelberg. Late may to Toscana!
ride till you can't.
1200GS/black
Boxer Cup Replika/red-white-blue
Semper Paratus
marty hill is offline   Reply With Quote
Old 03-04-2012, 04:12 PM   #3207
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,536
There is no work around unless you consider replacing the existing antenna with a replacement that is temporarily cable tied to the bike a workaround. Some did that until they could get to a place where they could drill out the safety screws. If your antenna goes you MUST have a replacement antenna if you want to start the bike. That was true up to the '09 models. I assume it is still true today.
marchyman is offline   Reply With Quote
Old 03-04-2012, 04:35 PM   #3208
marty hill
The Energizer Bunny
marty hill's Avatar
Oddometer: 4,271
That is what I was referring to/a temp fix to get you home. I never had a problem but others found it useful and they posted.
1200GS/black
Semper Paratus
Old 03-05-2012, 01:33 AM   #3209
tagesk
Tuscan rider
tagesk's Avatar
Oddometer: 3,227
Thumb
I'll start searching for suitable wines.
If that's OK with you
[TaSK]
IBA: 33616
Old 03-05-2012, 03:13 AM   #3210
marty hill
The Energizer Bunny
marty hill's Avatar
Oddometer: 4,271
[TaSK]
My daughter and I met Miriam from Brescia when she was in San Francisco on her ride. I look forward to meeting you and your wife as I visit. We are so lucky to be able to ride our moto's and make new friends! Oh yes, very OK!
1200GS/black
Semper Paratus
Times are GMT -7.   It's 06:28 PM.
