Old 12-01-2011, 06:30 PM   #5101
lookfar
from the land of OZ
Oddometer: 641
Originally Posted by amf4399 View Post
heat gun and peanut butter
Do you have any pics of the rear fender before you started?
My plastics have surface cracking and was wondering if the heat gun will repair the cracks?
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL250R
1985 XL600R 1988 XR600
lookfar is offline   Reply With Quote
Old 12-01-2011, 07:04 PM   #5102
amf4399
amf4399's Avatar
Oddometer: 63
I am trying to find those pictures. The heat gun worked great. I had some scratches that the gun smoothed out. Not sure how bad the cracks are but one possibility would be , and I saw this on youtube, would be to melt the two cracks together , then sand, then use the heat gun. What surprised the most about the heat gun was the amount of color it brought back. When I sanded it it turned almost white. The heat gun I got at harbor frieght for around $15
amf4399 is offline   Reply With Quote
Old 12-02-2011, 07:25 AM   #5103
bdcorrigan
bdcorrigan's Avatar
Oddometer: 650
I just got done rebuilding my carbs and now at idle there is a hiccup every once and a while, Air fuel screw? I backed it out 2 full turns. or could the coil possabilly not send the current to the plug?
bdcorrigan is offline   Reply With Quote
Old 12-02-2011, 11:22 AM   #5104
sh0rtlife
Oddometer: 796
how often is the every once in a while?.....if you up the idle does it go away?....could be as simple as cutting the frayed bit off the end of the coil wire and re-threading the end...or a lil something left in the carb still goofing things up
sh0rtlife is offline   Reply With Quote
Old 12-02-2011, 11:32 AM   #5105
Pigford
British
Pigford's Avatar
Oddometer: 971
These are older technology big singles with 100mm dia. pistons and they do tend to have an uneven idle I've had a couple of XL & XR 400/500/600's and many of them "stumble" a bit on idle, just nature of the beast. If it runs pretty good don't worry about it too much.
Have you removed the resistor in the plug cap yet ?
Pigford is offline   Reply With Quote
Old 12-02-2011, 12:26 PM   #5106
bdcorrigan
bdcorrigan's Avatar
Oddometer: 650
The resistor cap is off the plug. and yes when i pull the idle up it goes away, What does the pilot screw do on these anyway? is it the air fuel mixture? Could that have something to do with it? and yes i did turn it out 2 full turns.
Old 12-02-2011, 05:34 PM   #5107
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,797
The intake manifold can crack and the oring inside can dry rot and leak air. Make sure it is ok.
The air screw under the carb is pretty sensitive and needs to be at a reasonable setting for the idle to be good. I think mine is at 2 turns out.
Hate gets you nowhere.
Old 12-02-2011, 05:41 PM   #5108
bdcorrigan
bdcorrigan's Avatar
Oddometer: 650
IF and big if it is the CDI are there any aftermarket ones I will get one anyway but I dont want to get a used one unless i have to.
Old 12-02-2011, 05:44 PM   #5109
lookfar
from the land of OZ
Oddometer: 641
See here
http://www.ebay.com/itm/Ricks-Electr...item1e690809a2
Stu in FNQ
1985 XL250R
Old 12-02-2011, 05:48 PM   #5110
bdcorrigan
bdcorrigan's Avatar
Oddometer: 650
I have a 86 will that work
Old 12-02-2011, 05:52 PM   #5111
lookfar
from the land of OZ
Oddometer: 641
Should do, providing the plugs are the same. I used a CDI from a XR400 in my XL6 to see if my CDI was buggered...it was
Managed to get a NEW unit from Honda
Chuck it in and see....
Stu in FNQ
1985 XL250R
Old 12-02-2011, 05:58 PM   #5112
bdcorrigan
bdcorrigan's Avatar
Oddometer: 650
I will give it a try thanks
Old 12-03-2011, 07:23 AM   #5113
Reposado1800
Juicy J fan!
Oddometer: 5,797
Be careful. I think that is listing for the XL600V which is the vtwin transalp.
Old 12-03-2011, 08:42 AM   #5114
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,094
Check compression. Mine used to do that before I replaced the valves and piston.
Carter Pewterschmidt is offline   Reply With Quote
Old 12-03-2011, 09:11 AM   #5115
Aaron from Texas
Aaron from Texas's Avatar
Oddometer: 489
This has been used by other forum members, and has proven to work well. Much cheaper than the other unit...
http://www.bikebandit.com/arrowhead-...di-box?mg=8438
1987 Honda XL600R
ftwtexas.blogspot.com
Aaron from Texas is offline   Reply With Quote
Times are GMT -7.   It's 07:34 AM.
