Old 12-03-2011, 10:06 AM   #5116
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
That looks a lot like the CDI given to me by a fellow inmate. Mine was made in Argentina and supposedly has a raised rev limit. It wasn't working on his bike for some reason and I haven't tried it on mine yet. If it works, I'll keep it as a spare. If it doesn't, I'll depot it and see what's inside.
http://www.dze.com.ar/en/producto/15...nda%20XR%20600
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma is offline   Reply With Quote
Old 12-03-2011, 04:05 PM   #5117
brucifer
brucifer's Avatar
Oddometer: 2,460
Doing a little work to mine.
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-2001 Husaberg FE650E-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
brucifer is offline   Reply With Quote
Old 12-03-2011, 06:09 PM   #5118
El Brad
Leave it long on top
El Brad's Avatar
Oddometer: 448
Thumb Only if you are man enough....
http://ventura.craigslist.org/mcy/2731650591.html
" THE TRUTH IS, IF WE HADN'T DECIDED
TO BE YOUNG FOREVER, WE'D BE OLD "
El Brad is offline   Reply With Quote
Old 12-03-2011, 06:26 PM   #5119
brucifer
brucifer's Avatar
Oddometer: 2,460
Originally Posted by El Brad View Post
The only thing I see wrong with his ad is the bike isn't a 6 speed.
Old 12-03-2011, 06:51 PM   #5120
dixda
dixda's Avatar
Oddometer: 21
Originally Posted by el brad View Post
Originally Posted by brucifer View Post
the only thing i see wrong with his ad is the bike isn't a 6 speed.
x2. KD
dixda is offline   Reply With Quote
Old 12-03-2011, 06:56 PM   #5121
dixda
dixda's Avatar
Oddometer: 21
Has anyone here tried the DC Plastics repro fenders and stuff on their 83-87's?
If so, how did you like it compared to the real deal?
TIA, KD
Old 12-03-2011, 08:32 PM   #5122
Ghost_Mutant
looking for bionics
Ghost_Mutant's Avatar
Oddometer: 713
Nice ,
Tell us more about which swingarm, shock, and linkage you used for this upgrade. How did you deal with alignment and offset of the frame mounting points?
Ghost_Mutant is offline   Reply With Quote
Old 12-04-2011, 06:47 AM   #5123
brucifer
brucifer's Avatar
Oddometer: 2,460
Originally Posted by Ghost_Mutant View Post
Nice ,
How ya doin' GM?
The swingarm and brake assembly are all XR650L. The swingarm being an '07 and the brake stuff from a '93. The linkage is the stock XL600 pieces. The shock is '88 XR600.
The stock XL shock would work but I wanted something with a little more adjustment.
It's all bolt-on. I'll need to make a spacer for the left side of the linkage where it bolts to the swingarm and also one for the left side of the top shock mount.
I'm gonna fab up a longer reservoir hose and mount it back where the tool kit box normally is on the back left frame tube.
Do you happen to know if it makes any difference how the reservoir is mounted? It's mounted vertically stock (as you know) but I'll need to mount it horizontally.
You didn't ask but the front end is '93 CR500. Just had to swap out the steering stem from an '84 CR500 because of the lower bearing diameter.
brucifer screwed with this post 12-04-2011 at 08:37 AM
Old 12-04-2011, 07:43 AM   #5124
Ghost_Mutant
looking for bionics
Oddometer: 713
Doing good Bruce, and really enjoyed riding my bikes earlier this year before the snows hit. Now I'm gearing up to do some more mods. One of which is switch out the steel swingarm for aluminum.
I've got a swingarm from a 87 dual carb XR6 and I've been trying to think of how to keep the newer linkage that has the needle bearings. I was wondering how you handled that, and I see and you kept the stock XL link with the solid bushings. So you're going to fab a spacer and forgo the stack of washers
I don't think I can use the newer link parts without relocating the dogbone mount by removing and rewelding on the frame. I might do that, but haven't made up my mind yet. I also have a White Bros aluminum swingarm and it fits using the stock 84 link parts, but its heavier than the 87 Honda swingarm. It also needs a special rear axle, something between the stock XR and the longer XL. With either of my aluminum swingarms I have to make modifications to get it working
The external reservoir on the 84 XR5 is mounted horizontally on my frames where the XL has the oil/air separator located. Mine looks a lot like the 88 in your photo, but I understand that the newer shocks have more adjustment points. So I'll leave open the possibility that mounting position matters with yours, but I doubt it.
There is much confusion about which 'newer' forks to swap in. I'd like to keep the front wheel and use the stock brake caliper for a fork swap. But I'm not sure if the CR500 forks were the best performing versions of the upside downs. Did you have to change the steering stops to use these 93 CR5 forks?
Old 12-04-2011, 07:49 AM   #5125
brucifer
brucifer's Avatar
Oddometer: 2,460
I did not have to change the steering stops.
Regarding the stem swap. I forgot to mention that a fabricated bushing was required due to the smaller diameter '84 stem and larger '93 lower clamp.
brucifer screwed with this post 12-04-2011 at 07:59 AM
Old 12-04-2011, 08:00 AM   #5126
Schrauberklaus
***ifyer
Schrauberklaus's Avatar
Oddometer: 380
From with Bike is the Fork ?? How much work to make it fit ???
Klaus
___________________________
Honda XL 600 R(S) 84 , Honda XR 600 Dual Carb. 87
Honda XR 280 R Sumo 04 , Honda XR 250 Baja 98
Yamaha Speed MX ( 2 Stroke ) 01 ,CRF250L 13
Schrauberklaus is offline   Reply With Quote
Old 12-04-2011, 09:10 AM   #5127
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,088
In all that how did that guy not mention that it takes the love child of Thor and Conan to kick start the bike and anyone else who attempts it will see the instant disintegration of their ankle and knee.
Carter Pewterschmidt is offline   Reply With Quote
Old 12-04-2011, 10:54 PM   #5128
Humboldt Brad
new Adventure rider
Oddometer: 20
I'm not shure why everyone says there so hard to kick. does everyone really have that problem?
Humboldt Brad is offline   Reply With Quote
Old 12-05-2011, 11:04 AM   #5129
sh0rtlife
Oddometer: 796
i can be on the other side of mine reach over the seat and start it with my arm..first shove...ive started it bare foot with just my toes....and so long as ive got the choke in the right spot(thanx to the winter) if fires on the first prod every time...its really got me wondering why everyone seems to say they will take your ankle off...fires up better than every other bike ive had/have with the exception being my 86 sx200fourtrax
sh0rtlife is offline   Reply With Quote
Old 12-05-2011, 02:09 PM   #5130
bdcorrigan
bdcorrigan's Avatar
Oddometer: 647
The 4 Pack of XL's, 2 86's and 2 87's
Name:  New Image.jpg
bdcorrigan is offline   Reply With Quote
Times are GMT -7.   It's 02:58 PM.
